RL Calipers Fit behind 05 TL 17" rims!
Old 04-25-2010, 11:40 PM
  #201
lightjak_tsx's Avatar
nice
Old 04-26-2010, 12:08 AM
  #202
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,142 Likes on 4,809 Posts
Originally Posted by lightjak_tsx
nice
Insightful.
Old 04-26-2010, 06:10 PM
  #203
JBlueCLS6's Avatar
Just bought some RL Calipers, should be here Wednesday, hopefully NVA gets back to me soon on the brackets... I'm going to try using a 15MM spacer to clear the Stock CLS Wheels.
Old 04-26-2010, 06:15 PM
  #204
B A N N E D
friesm2000's Avatar
should make them sit quite flush too , and hopefully they fit
Old 04-26-2010, 07:41 PM
  #205
StreetKA's Avatar
i hope that they gonna fit behind my servos(18x7.5 ET42). i measured i have now like 27mm clearance from a stock caliper to one of the spokes
Old 04-27-2010, 12:33 AM
  #206
Boosted...
WBA-01's Avatar
So where is everybody getting there hands on these calipers.
Old 04-27-2010, 11:08 AM
  #207
civicdrivr's Avatar
Youre going to use extended studs right?
IIRC E30 had Servos and they didnt clear.
Old 04-27-2010, 11:32 AM
  #208
JBlueCLS6's Avatar
Yes sir, I think Eibach has a hubcentric 15mm spacer kit with extended studs around $100 bucks I'll get.
Just sent Paul payment, think I'm gonna powdercoat my calipers ABP or Red before I throw them on. What do you think the average charge should be on that?
Old 04-27-2010, 12:01 PM
  #209
StreetKA's Avatar
Yes but servos comes with offsets. 50 and 42. i have 42 thats why im confused.
e30 can clear this up which offset did you try ? thanks
Old 04-27-2010, 12:29 PM
  #210
civicdrivr's Avatar
Shouldnt be much. The calipers I bought were already powdercoated. Make sure you mask them off properly though. The previous owner of mine took them apart and sprayed the area where the two halves meet so it didn't seal properly. I had to grind off all the PC without damaging the seal seats. Fun times.
I just spoke with him and he said he bought Inspyres. The Servos are a toss up for fitment. It they have a high pad height then you shouldnt have a problem. The offset itself doesnt really matter, the spoke clearances do.
Old 05-05-2010, 09:27 PM
  #211
PKIM's Avatar
Originally Posted by anthracitecl
03 cls stockies needs at least 15mm spacers or maybe 20mm. I knew Rotora BBK needs 5mm spacer on stockies. so i tried 5mm on RL calipers, but it didn't work. and i tried 10mm. not even close! I was like f&*k this!! 01,02 cls stockies won't even clear inside of wheel. so you better find wheels to clear RL calipers. anyway this is one of the best upgrade so far!!!
If the stockies need 15mm-20mm spacers will we rub at all? or will we just sit flush?
Old 05-05-2010, 09:36 PM
  #212
wham bam thank you ma'am
Rajca's Avatar
stock height. with 15mm spacers u should sit flush
Old 05-06-2010, 09:03 AM
  #213
Not 4 Wheelin Anymore!
womey's Avatar
Also, I'd get spacers for the rear too. Flush sitting front wheels and hellaunflush rear wheels isnt a good look imo.
Old 05-06-2010, 10:28 AM
  #214
JBlueCLS6's Avatar
Won't be running stock wheels anymore. Scored something nice and the calipers will be back from the powdercoaters next week. Got them in lollipop blue which was close to the factory abp.
Old 05-06-2010, 06:52 PM
  #215
B A N N E D
friesm2000's Avatar
now, now; don't squeeze it so hard LMFAO
Old 06-19-2010, 09:01 PM
  #216
victorvu's Avatar
ok i have a question will the stock 03 wheels fit with these calipers?
Old 06-19-2010, 11:42 PM
  #217
civicdrivr's Avatar
No.
Old 06-20-2010, 03:48 AM
  #218
victorvu's Avatar
guess off to look for 3rd gen wheels.
Old 09-29-2010, 11:30 PM
  #219
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
whats the cost breakdown? --calipers, bracket, rotor, lines and fluid
how does it compare in price to Excelerates 6 piston wilwoods?
Im running enkei 18"s on the 01TL so clearance should be ok
Old 09-29-2010, 11:39 PM
  #220
I Drive Like A Dick 8≈
Nersh7's Avatar
IIRC the price after everything is slightly less, I don't know the actual cost breakdown though.
Old 09-30-2010, 01:26 AM
  #221
13.2@106mph G37 RWD Sedan
kdawg8526's Avatar
iirc i remember reading earlier around 700 bucks or so and i thought the excelerates wilwood brake kit had only 4 piston
Old 09-30-2010, 02:33 PM
  #222
civicdrivr's Avatar
The Wilwood kits come in either 4 or 6 piston varieties. The 6 piston costs over $1k though.
Look at spending around $700. The biggest variable is the calipers themselves. Check out Car-Part.com for calipers. You want 05-07 RL.. I heard there was a slight difference in the 08-up but Im not sure what it was.
Old 09-30-2010, 04:03 PM
  #223
p.diddy's Avatar
i spent $650 for my RL bbk.
Old 10-01-2010, 03:33 PM
  #224
Blazin Si's Avatar
For those with the BBK, are you guys experiencing any issues with the ABS system? StopTech has a really great article that addresses the problem. http://stoptech.com/tech_info/wp_abs_bigbrakekits.shtml
Basically, it explains how your ABS system uses an algorithm containing some very specific numbers to minimize stopping distance and allow vehicle control under hard braking. Going to a larger rotor and pad set up has adverse effects on the performance of the system.
I had upgraded the 10", single piston brakes on my '97 2.2CL with the NSX set up. I believe the 2nd gen are similar to 1st gens in that the front ABS sensor counts the teeth on the axle. The actual speed of the wheel might not directly effect the system, but the beefier brakes have increased bite and probably effect the pulsing of the caliper.
I haven't done any hard braking since the upgrade other than immediately after the install, I had bed-in the pads and rotors by following StopTech's procedure. That was until last week, when I was traveling at roughly 75 mph on the highway and suddenly had to stand on the brakes. The front right wheel locked up. It didn't release until I had let off the brake pedal at around 50 mph.
I'm a bit concerned about this problem and wanted to know if any of you had come across it?
Old 10-01-2010, 04:12 PM
  #225
civicdrivr's Avatar
I havent run into any issues, only once in a panic stop at a high rate of speed (read - illegal) and ABS kicked in for a moment then I backed off a bit. Im sure the balance of the ABS is thrown off a bit.
Old 10-01-2010, 06:30 PM
  #226
Blazin Si's Avatar
Did the car react as it did when when it had the stock brakes?
I personally never had to apply the brakes hard enough to engage the ABS prior to that day. At least on dry pavement anyways. So I don't have much to compare it too. Locking one wheel for as long as it did has me a bit worried.
Old 10-01-2010, 06:42 PM
  #227
civicdrivr's Avatar
Not much different. It stopped the car though, and thats the important thing. Went from about 95 to 45 pretty quickly. I didnt have just one lock up on me, I think all locked up a bit, because when I slammed on the brakes the car got a bit squirrelly.
Old 10-01-2010, 06:49 PM
  #228
Blazin Si's Avatar
95 to 45 is a bit more intense. My car stayed straight, but I didn't have to do any evasive maneuvering other than applying the brakes.
Old 10-01-2010, 09:45 PM
  #229
RIP RBP
upnout's Avatar
I'm getting my car serviced by NVA this month. The pics of the RL calipers, damn they look good. I'm going to ask him what my options are. 3g TL with A spec wheels 5AT
good info in this thread
Old 10-01-2010, 09:54 PM
  #230
civicdrivr's Avatar
Shouldn't have a problem running them. The 5AT uses a similar brake bracket as us. The models with the "Brembos" dont use a bracket, the calipers bolt directly to the knuckle from behind. And you should be able to run the A-Specs. I can run them on mine.
Old 10-02-2010, 06:34 AM
  #231
GO RANGERS!!!!!!!!!!!!!!!
e30cabrio's Avatar
Received 1,771 Likes on 1,233 Posts
I had to stop quickly several times before and after the upgrade. The only change was much improved braking.
I'd have that caliper and it's line checked.
Old 10-19-2010, 04:12 AM
  #232
Mr. L.E.D.
KnightRyderV's Avatar
question regarding wheel position using the different rotors. my wheels are hellaflush and i cant afford any lower offset of the front wheels so when looking at e30's pics and seeing that the rotors hat is sitting virtually flush with the end of the hub kind of worries me because it looks as if the EBC rotors are acting like a 5mm spacer or somewhere around there.
then civicdrivr said his hub actually sticks out the same as oem if not more with Powerslot rotors. since 2nd CLs and 6th gen accords are pretty similar i figure i'd have the same fitment as you guys so i wanted to get this clear before i choose which rotors to buy.
the powerslot rotors do cost a little more so i really should just go with those to be on the safe side but i wonder if anyone else has noticed their wheels being a little lower offset (sticking out more) when using the EBC rotors.
Old 10-19-2010, 08:39 AM
  #233
Regional Coordinator (Texas)
nspec_ya4's Avatar
if thats the case, you can always have the machine shop shave off a mm or two from rotor and the wheel.
Old 10-19-2010, 08:44 AM
  #234
nspec_ya4's Avatar
If i remember correctly, in ur car, u also have to upgrade the master cylinder to make the nsx calipers work properly.
I haven't had a time when I had to "Slam" the brakes, but i came pretty close to it several times and these RL brakes do the job pretty damn good compared to OEM CL calipers. They feel like regular brakes unless u push down on them close to the slamming them.
Old 10-19-2010, 10:45 PM
  #235
'03 ABP YA4-S 6MT
rp_guy's Avatar
can someone PM me paul's info (phone or email is fine)
thanks
Old 10-19-2010, 10:49 PM
  #236
civicdrivr's Avatar
Im a bit confused, what exactly are you asking?
If youre asking about caliper to wheel clearance, it all depends on if the wheel is BBK friendly.
Old 10-19-2010, 11:26 PM
  #237
B A N N E D
friesm2000's Avatar
also wheel spacers can provide the needed clearence for a bbk, but then again you gotta pay to play
Old 10-19-2010, 11:40 PM
  #238
civicdrivr's Avatar
From what I gather from his post, he's already running an aggressive fitment.
Old 10-20-2010, 12:44 AM
  #239
kdawg8526's Avatar
thanks
u can pm him his user name is nva-av6
Old 10-20-2010, 05:29 AM
  #240
Mr. L.E.D.
I'm not worried about wheel clearance. I understand the clearance I need and I know I have it. I have ame tracer fs01 rims at a 31 offset so I have enough space.
From what I understand about the differnece between your powerslot rotors vs e30s ebc rotors is that the hub which the rim sits on is virtually gone on his setup but is still available on yours. And since the rims sit against the hat of the rotor, by theory my rims would sit exactly the same way they r now on my car if I use the powerslot rotors but if I use the ebc rotors then my wheels would stick out several mm more.
Do u happen to have a pic of your rotors installed on the car with the wheels off maybe if i had a picture to compare your rotors to the ones e30 posted.
Sorry if its still unclear. Worst case ill just spend a few more bucks for the powerslot rotors since u said u still have a hub for the rim to sit on.
Quick Reply: RL Calipers Fit behind 05 TL 17" rims!
