RL Calipers Fit behind 05 TL 17" rims!
Old 12-27-2009, 03:21 PM
  #41
B A N N E D
friesm2000's Avatar
and what rotors are those, i know they are off of a 350z with brembos, but what brand and stuff
those SS lines will defineltly help the brake pedal feel, cause i know they did when i did mine (and it was just them and nothing else)
also when you do the lines and calipers, leave the brake reservoir cap ON (and top off the reservoir before hand too)(it creates a little vacuum, where the fluid can not drain anymore)(so less air is introduced into the system), cause it will help keep all the fluid from just draining out when you change the stuff out
Old 12-27-2009, 04:06 PM
  #42
CH46ESeaKnight's Avatar
They are also EBC. I think they are the Ultimax rotors not the 3GD Sport.
E30, I had some reds on my other car and they are some of the best pads I've had, but they do dust a lot. Not a big deal for me. But man can they grip! I'm guessing your really going to like that set up!
Old 12-27-2009, 04:16 PM
  #43
wham bam thank you ma'am
Rajca's Avatar
i also have red stuff pads all the way around on my cl, love them to death. made a huge diff, even with my stock calipers and drilled and slotted rotors. now im only getting red stuff pads.
Old 12-27-2009, 04:42 PM
  #44
CLsuperhero's Avatar
how much better are these calipers over nsx or legend ones?
I don't know anything about the RL brake setup... how many pistons are on each caliper and what is the diameter?
Old 12-27-2009, 04:44 PM
  #45
Rajca's Avatar
tl/cl oem- single piston
nsx/legend- dual piston same size rotor
rl- 4 piston, bigger rotor
so twice as good as nsx/legend
and look twice as bad ass
Old 12-27-2009, 04:55 PM
  #46
B A N N E D
friesm2000's Avatar
and rl caliper is lighter too for less unsprung weight (aluminuim vs cast iron), but the weight savings is basically offset by the bigger rotors though, so basically the same total weight, just with bigger rotors
Old 12-27-2009, 05:00 PM
  #47
GO RANGERS!!!!!!!!!!!!!!!
e30cabrio's Avatar
Received 1,766 Likes on 1,230 Posts
The Z rotors are 11lbs each.
I doubt the stock rotors are much less.
We'll have to wait for someone to weigh the stock ones as mine have been gone for a year.
Old 12-27-2009, 05:14 PM
  #48
B A N N E D
friesm2000's Avatar
right here: http://bremboaftermarket.com/En/Car_...IDMaster=11423
it says 8.1 kilos (or 17.8 pounds) for the factory brembo replacements, so IDK, if true then you are saving wait there too
Old 12-29-2009, 01:43 AM
  #49
Moderator Alumnus
BigLizard's Avatar
damn, if I still had my CL I would definitely do this upgrade.
Old 12-29-2009, 05:30 PM
  #50
e30cabrio's Avatar
Brake fluid has landed!
Old 12-29-2009, 05:35 PM
  #51
B A N N E D
friesm2000's Avatar
why??? (with having it shipped), i am pretty sure i have seen it for sale at my local dealer when i was there for other parts, and i get it basically at wholesale too
Old 12-29-2009, 08:32 PM
  #52
StreetKA's Avatar
how much did you pay for custom brackets ?? nice job. whats the offset of TL rims ?
Old 12-30-2009, 03:09 PM
  #53
07HR350Z's Avatar
I like the brake upgrade but I'm wondering how this will affect your front/rear brake bias. What type of brakes do you have in the rear? And are you running a proportioning valve. Also, with the larger rotors and calipers, is the OEM master cylinder strong enough to handle the extra demand?
Old 12-30-2009, 03:25 PM
  #54
B A N N E D
friesm2000's Avatar
the bias would be off, so the rears should be upgraded too, or at least re-proportioned
and how would they be stressing the master cylinder, if anything it would be easier on it, from the lower pressure required, due to the brakes being more effective
  #55
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,134 Likes on 4,804 Posts
The same question can be asked of the Rotora BBKs.
Old 12-30-2009, 03:34 PM
  #56
B A N N E D
friesm2000's Avatar
you are not wanted here, so get back to your vacation :bastard:
that is also why it is really nice that they actually make a rear BBK for our cars, to match the fronts
Old 12-30-2009, 07:09 PM
  #57
Rajca's Avatar
called my bro up at work. $188 for a caliper. not bad at all
Old 12-30-2009, 07:12 PM
  #58
civicdrivr's Avatar
Rebuilt Im hoping...
Old 12-30-2009, 07:21 PM
  #59
Rajca's Avatar
from the dealer i believe. will ask him when he comes home
Old 12-30-2009, 08:06 PM
  #60
Rajca's Avatar
their remans. o well. still will do the job.
Old 12-31-2009, 10:41 AM
  #61
Ultra Negro
OperationDarkie's Avatar
so did you make that bracket it or was it made for you? if so let me know I might be interested in doing this myself.
Old 12-31-2009, 01:05 PM
  #62
Rajca's Avatar
it was made by nva av6.
Old 12-31-2009, 05:05 PM
  #63
e30cabrio's Avatar
Calipers new fluid & SS Lines are in, feels great!
Old 12-31-2009, 05:12 PM
  #64
B A N N E D
friesm2000's Avatar
holyshit
Old 12-31-2009, 05:17 PM
  #65
civicdrivr's Avatar
holyshit
You have a strange infatuation with ankles
Old 12-31-2009, 06:07 PM
  #66
Rajca's Avatar
what kind of ss lines did u use? for the cl?
Old 12-31-2009, 06:16 PM
  #67
e30cabrio's Avatar
Russell, it says CL/TL on the box.
Old 12-31-2009, 06:17 PM
  #68
Rajca's Avatar
ok kool. so my rotora ss lines should work with these right?
Old 12-31-2009, 10:06 PM
  #69
lowrd on tein CS biatch
CL-S progression 01's Avatar
i dunno man lines are ok i guess.
then u lose the pedal feel
Old 12-31-2009, 10:08 PM
  #70
Rajca's Avatar
i like a stiff pedal
  #71
e30cabrio's Avatar
From the TL?
I am pretty sure you can.
The SS lines make the pedal firmer, no loss of modulation feel.
Old 12-31-2009, 10:19 PM
  #72
B A N N E D
friesm2000's Avatar
From the TL?
and if any thing more responsive, cause you don't have the slop of the rubber lines expanding so easier to modulate, due to it responding immediately to your foot
Old 12-31-2009, 10:36 PM
  #73
yea but all things considered I'd say for daily drivers the stock lines are good enough for what ppl will be asking for. no doubt.
stainless steel lines are way to strong for daily driving brake input so why get them... plus they can deteriorate in the future since the coating on the metal isn't sufficient to last a long time. I had that shit on my probe and only lasted like a year with my driving.
so I don't think they are as good as people make them out to be cause they are not.
I bought the really good ones and they still ended up breaking like a pos. so honestly they are not all the talk people make them out to be.
I dislike them to be honest, they are not long lasting thus they are money wasted in my humble opinion.
Old 12-31-2009, 10:40 PM
  #74
e30cabrio's Avatar
Please stop posting your erroneous opinions as fact.
Quality DOT Certified SS Lines are better than oem rubber.
I have a set in my 90 BMW that have been in there for much longer than you have been driving and they are great.
No one is asking you to install them or like them, you can keep your oem lines.
Old 12-31-2009, 10:48 PM
  #75
Rajca's Avatar
Old 12-31-2009, 10:49 PM
  #76
maybe I bought cheap ass fucking lines then man, cause mine simply deteriorated over the course of not even a year man it was rediculous.
fuck it must be the shitty lines i had installed
damnit i got screwed with so many parts on my probe it is not even funny man. it's like eveything i bought was cursed before I got it. it makes no sense like i bought the best shit i could get my hands on and it just fell to crumbs asap. fucking probe i knew it was cursed
Old 12-31-2009, 10:53 PM
  #77
e30cabrio's Avatar
That is possible.
Rajca here is a closeup of the label on the SS box:
Old 12-31-2009, 10:57 PM
  #78
B A N N E D
friesm2000's Avatar
yeah i love my ss brakelines on my DD, with the increase responsiveness
there are also goodridge g-force brake lines too, that you could have gotten
Old 12-31-2009, 11:00 PM
  #79
Rajca's Avatar
ok. bc i got the rotora ss brake lines from the 99-03 tl and 01-03 cl. so one less thing i need. now im just working on my lip kit. so as soon as it warm outside their will be major exterior changes taking place
Old 01-01-2010, 12:52 AM
  #80
p.diddy's Avatar
what year RL does this come from also what trim level if it matters? im wondering if i should go this route instead of the Rotora bbk. is rotora better or bout the same cause their both 4 piston.
Quick Reply: RL Calipers Fit behind 05 TL 17" rims!
