Replaced the clutch now i have issues.. HELP!!
So I replaced the clutch with the LUK about two days ago. A buddy and I did the job but now I have some issues. When I test drove it I noticed that it will not go in 5th or 6th gear. This was not an issue before I took the trans out so I know its something I did while putting this thing back together. I have been reading that you have to bleed the clutch fluid reservoir and that may cause it. I also read that low trans fluid can cause this but that sounds odd.
Second problem is the speed ohmmeter isn't working. I goes up between 20-30 mph and then back to zero but most of the time it just stays at zero.
Other than those two major things it runs good, let me know if you guys have any input. I might look to put it back on the lift tomorrow morning to replace the fluids to see if that helps.
Also I may have messed up the speed sensor. I'm just going to buy a new one and put it on a lift and see if that fixes it.
tjwgrr
27
11-24-2015 06:45 PM
jroca
10-22-2015 11:11 AM
