P2R 3inch Cat Back installed
Old 11-28-2008, 08:52 PM
  #121
typeR's Avatar
ok done with the back and fourth take it to PM ! now or the thread gets locked down and both get a warning ! this is not just directed at you but your buddy TOO!
Old 11-28-2008, 09:02 PM
  #122
typeR's Avatar
Originally Posted by RUF87
SWEET !!
. . . and looks like you'll be setting the bar for a new N/A best track time.
Ruf
my time will never be beat !
Old 11-28-2008, 09:05 PM
  #123
CLS6SpeedNupe's Avatar
Next season might prove different...lol but you have set the bar for me indeed
Old 11-28-2008, 09:11 PM
  #124
typeR's Avatar
soon ill try to track my old car down by the vin and see if i can whip her back in shape ... i planned turning some of those comp knock off hearers into true mids ... using burns collectors electric water pump dry sump oil pump ... minor head work ... bump compression ... convert to the RL mid section dual flow exhaust pipe and get that baby with 2 wheel drive by throwing a phantom grip in the open diff
Old 11-28-2008, 09:12 PM
  #125
BANNED
NVA-AV6's Avatar
Moes exact build.....
Rebuilt J32A2
02 MDX crank and rods
05 RL Pistons
Ported heads and intake
So, yes he is a J35 with 11:1 compression , don't let him try to fool you all.....
Old 11-28-2008, 09:15 PM
  #126
typeR's Avatar
Rebuilt J32A2
05 RL Pistons
so whats he saying different ?
Old 11-29-2008, 08:49 AM
  #127
ThinJim's Avatar
I won't say it's impossible, but to put a dry sump on the present configuration of the CL, FWD, will be a challenge. Do you think you can find your old car?, there so cheap now, just find a used one and start again.
Old 11-29-2008, 01:07 PM
  #128
typeR's Avatar
oh i know , either i will be in a cls again soon frick 6 -7K is crazy , and i would love silver auto w/nav but my old car has the stroker on it , it would be nice to pick up where i left off
Old 12-04-2008, 06:31 PM
  #129
Sideshow's Avatar
Quick question-
I have a 3.2 NA CLS with most bolt-ons including the RT cat. I want to put on a mangaflow catback (ie resonator, mufflers and tips) but I am wondering about pipe diameter. In the past, most folks went with a 2.5 inch pipe into 2.25 piping at the Y muffler split. Then CLS6SpeedNupe went with a 3.0 inch into a 2.5inch with excellent gains on a 3.5 conversion. Does anyone see a problem with my running a 2.5 inch system from the Cat all the way back to the muffler tips?
Old 12-04-2008, 07:33 PM
  #130
Originally Posted by Sideshow
Quick question-
well your RT is more than likely 2.25 and if you have headers that should be 2.5 so basically you are talking about 2.5-2.25-2.5 I say ditch the RT cat and get the 2.5 catback so your running 2.5 from the header to the mufflers.
Old 12-05-2008, 02:58 AM
  #131
4drs just wanna have fun!
Accord_V6_400m's Avatar
Comptech j-pipe: 2.0"
RT cat: 2.0"
Old 12-05-2008, 08:26 PM
  #132
Lives On BOOST
krisdlm's Avatar
rt cat w/ s/c = about 15hp loss. Did a dyno w/ and w/out it and I gained approximately 15 hp
Old 12-05-2008, 08:48 PM
  #133
Sideshow's Avatar
Damn!
15hp loss at the wheel...that sux!
I realize that you were boosted at the time so perhaps I am not losing nearly as much HP, but even so I feel like a chump for buying the RT cat...how did I get sucked into the hype?
Sounds like I should just do what CLS6SpeedNupe suggests and get a mangaflow cat and run 2.5 piping all the way out the back. Thanks for the insight krisdlm
Old 12-05-2008, 10:12 PM
  #134
Damn!
Don't feel too bad I bought one too, its not too bad for NA especially when you consider its similar to the stock cat if not better and the Comptech j-pipe outlet size on the collector is only 2.0" anyway.
Old 12-06-2008, 10:41 AM
  #135
EL19's Avatar
I thought the size of the stock cat was 2.25 though? Is it 2.0?
Old 12-06-2008, 08:15 PM
  #136
I think its 2.25" on the outlet of the cat and 2.0" on the inlet, the gaskets are actually different sizes on both sides of the cat.
Old 12-08-2008, 11:47 AM
  #137
TQ > MPG
Joe5.0's Avatar
If you cant crack 13's next spring you should just sell the car j/k (kinda)
Nice numbers, those are great for a N/A V6 no matter what the mods.
Old 12-14-2008, 06:34 PM
  #138
Cosmic Cowboy
g1underground's Avatar
Originally Posted by poisx7
is ur shop in maryland ??
since Nupe did most of his work in ur shop ??
I wud like to know.
X2.....I don't think that question was answered. I'm curious too.
I need a quality shop willing to work with mods.
Old 12-16-2008, 11:01 AM
  #139
cbr169's Avatar
maybe will not be beat by another auto
Old 03-07-2009, 06:37 PM
  #140
Just posting a quick dyno update for this year before I install my new mods within the next weeks and dyno again to hopefully pick up a lot of usable power.
Nothing has changed since last dyno in november besides addition of a o2 extender to stop CELs for coming on, which oddly has caused the car to run a little leaner since install.
Old 03-10-2009, 07:11 PM
  #141
Pinho's Avatar
when is ur next dyno day
Old 06-23-2009, 02:29 AM
  #142
Chamorro
dave586270's Avatar
Amazing, can't believe the numbers for N/A
Old 05-12-2011, 10:14 PM
  #143
AARONSredTYPE-S's Avatar
Originally Posted by jproy
Just look for the two hoses coming off the Tstat housing under the TB that both go to the TB. The Tstat housing is what the upper radiator hose connects to on the engine block. The two hoses that connect to the TB are identical in size. When you pull them off you will know you have the right ones because a little green coolant will spill out. Don’t worry about the tiny spill. Be quick about it. Obviously if you spill a huge amount take the proper procedural precautions but you would have to be a retard to lose a ton of coolant. My Outlaw Engineering spacer kit came with a fitting to connect the two ends of hose from the Tstat housing if you didn’t want to use the TB spacer. If you don’t have access to one just get some more hose of the same size and connect the two nipples on the Tstat housing with the one hose or one of the OEM hoses if they are long enough. If you look at it you will understand. Call me if you don’t. Jim
damn, i need to do this..
this is great numbers, especially for NA..
nice work
Old 05-13-2011, 08:27 AM
  #144
I NEED TO DYNO SOON AND SEE WHERE IM AT.
Im wondering what kind of numbers i'll be at
Old 05-13-2011, 09:11 AM
  #145
I got the Shifts
phee's Avatar
that nupe guy was such a douchebag
Old 05-13-2011, 09:49 AM
  #146
really, lol
made great flippin numbers though...
Old 05-13-2011, 11:25 AM
  #147
3.5 psi
gnuts's Avatar
yes he was an idiot. You know he was stroked right? 3.5L with lots of supporting mods.
Old 05-13-2011, 03:53 PM
  #148
oooh, now that makes sense
Old 07-10-2011, 05:40 PM
  #149
I wonder what this exhaust sounded like, because the sizing looked perfect for a car with full bolt-ons
Old 07-10-2011, 06:39 PM
  #150
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,144 Likes on 4,811 Posts
Man, I forgot how much of a douche Nupe was.
IIRC, he blew his engine and blamed Paul for it, even though the asshole didnt break the engine in properly. Wonder what happened to that car since he was banned from here and v 6 p??
Old 07-13-2011, 03:50 PM
  #151
Not 4 Wheelin Anymore!
womey's Avatar
Last I saw car was in the shop with no motor. I bought the exhaust but it was ridiculously loud and raspy. I added a vibrant ultra quiet resonator and an exoticspeed 18 inch resonator and it toned it down. The video is posted on here somewhere with XS headers and a HFC. I'm missing my Acura...
Old 07-13-2011, 06:36 PM
  #152
anthracitecl's Avatar
I remmember nupe...
Did you sell your cl womey?
Old 01-12-2016, 01:44 PM
  #153
GroundeDCustoM
GroundedCustom's Avatar
Sound clip.
We all got so absorbed with the back N forth bickerin
Its like one over sized text message, except the "be there in 10 min" part
Haa
Love this forum. No i reallly do. CL type Love
Old 01-14-2016, 11:20 AM
  #154
Lone Wolf
brian6speed's Avatar
Did you notice how old this thread is.
james357
02-13-2016 02:37 PM
IIDXholic
10-08-2015 07:53 AM
obert
09-03-2015 08:40 PM
Quick Reply: P2R 3inch Cat Back installed
