need help with headlight situation
i might be buying an acura cl type s an the person im getting it from says that one of the headlights keeps blowing and tripping the fuse(im under the impression there are separate fuses for the different headlights. can anyone help me with this before i buy the car an have to sink a bunch of money into it?
any help woul be greatly appreciated. thanks in advance
I would check the ballast or look for a short somewhere. If there are separate fuses for the headlights, and I'm not sure if there are or not.......then it's a short or ballast issue. If you can fix that yourself then you can do it for a couple hundred bucks.
You can find them all over eBay for about $100. But if I were you, and I purchased the car, I would purchase 2 new ballast and bulbs and be done with it. Try theretrofitsource.com. Also it's not just a "bolt up" replacement. You have to take the bumper off as well as take the headlight off. Not difficult to do though.
I can understand that. The problem is that this is a used car. You take a risk like this when you buy used. I would assume for $700 the car has to be pretty run down. I guess if you have the mechanical know how then the choice is yours. If you don't have the knowledge or money to fix it yourself then the choice has already been made.
I think i'd worry more about the dying transmission than the ballast..
i can do mechanical work i just dont know about electrical systems and from what i unerstand it just needs the headlight fixed a paintjob and the driverside winow motor replaced and keep in mind im driving a 91 ford ranger that i paid 500 for 3 years ago
MikeekiM
04-18-2016 01:07 AM
