I have to Jiggle my key for 5 min for it to turn over, What's wrong with her? - AcuraZine - Acura Enthusiast Community
Thread Tools Search this Thread
Old 01-12-2009, 03:11 PM   #1
B A N N E D
Location: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
Well yesterday in NJ my car was covered in a sheet of ice , so after i chiped the ice off enough to open the door I tried starting it and the key would not turn over. I checked to make sure the steering wheel was locked and it was in park and still nothing, so I jiggled and jiggled the key and steering whhel, and finally it turned over and started, Today the same thing, so I sprayed some wd40 in the ingnition and no help. It takes me like 5 min of jiggling everytime i want to start my car and my wrist is starting to hurt what can be wrong?
Thanks guys!
StonedCL is offline   Reply With Quote
Old 01-12-2009, 03:25 PM   #2
Trolling Canuckistan
black label's Avatar
My guess is that the key is worn and no longer stops in the key hole where it is supposed to. My Prelude does the same thing, you have to put the key in, then pull it back out about 1 mm and it is lined up properly. The other possibility is that you have ice in the keyhole. I would guess that isn't actually your problem because the WD40 would have taken care of it.
black label is offline   Reply With Quote
Old 01-12-2009, 03:40 PM   #3
B A N N E D
Hopefully its just they key and not the ignition cuz I do have the 2nd key at home which was barely used , i will try that when I get home.
If it is the Ignition how much $$ you guys think it is to replace?
Old 01-12-2009, 04:30 PM   #4
Registered Member
02CLNOS's Avatar
maybe about $100 to recode the ignition cylinder
02CLNOS is offline   Reply With Quote
Old 01-12-2009, 04:42 PM   #5
double din time!
SlickShiftNall6's Avatar
Try that other key hopefully it should work. Sounds like the your key is worn down. But if its not that your probably screwed.
SlickShiftNall6 is offline   Reply With Quote
Old 01-12-2009, 07:16 PM   #6
B A N N E D
Quote:
Does scewed mean like $200 of more like $1000?
Old 01-12-2009, 07:54 PM   #7
Regional Coordinator (Texas)
nspec_ya4's Avatar
just spray some WD40 or similar lube on the key and insert that in the cylinder. Keep putting the key in the ignition and turning it over and taking it out.
nspec_ya4 is offline   Reply With Quote
Old 01-13-2009, 09:18 AM   #8
B A N N E D
I did spray wd40 on the key and in the keyhole, and no luck.
I tried my second key and still no good but better, I have noticed that if the key is not in all the way it will start.
Old 01-13-2009, 10:43 AM   #9
Wide Body 3.2 CL-S
krazykrnboi's Avatar
ignition lock cylinder seems to be worn.
krazykrnboi is offline   Reply With Quote
Old 01-13-2009, 12:33 PM   #10
typeR's Avatar
could it be the chip reader
typeR is offline   Reply With Quote
Old 01-13-2009, 04:58 PM   #11
Weiners, EVERYWHERE!!
civicdrivr's Avatar
Quote:
Agreed.
I don't believe the lock cylinders are that expensive. You can usually get a locksmith or maybe a really old guy at the dealer to match it to the key.
civicdrivr is offline   Reply With Quote
Old 01-13-2009, 05:38 PM   #12
Registered Member
AnthraciteBeast's Avatar
Quote:
I'm going to say screwed as $200.
AnthraciteBeast is offline   Reply With Quote
Old 01-13-2009, 09:12 PM   #13
CL6
My only car is a Bus
CL6's Avatar
Only the really old guy?
Quote:
Originally Posted by civicdrivr View Post
Agreed.
CL6 is offline   Reply With Quote
Old 01-13-2009, 10:10 PM   #14
civicdrivr's Avatar
Quote:
Haha, I knew I would have to elaborate on that.
The OGs at the dealers usually know how to repin a cylinder, whereas the new kids will stare at you funny and wonder where the pins are.
Old 01-14-2009, 12:20 PM   #15
Wide Body 3.2 CL-S
might want to get this fixed soon cause it might not turn at all one day...
Old 01-14-2009, 06:30 PM   #16
Registered Member
Old 01-14-2009, 07:57 PM   #17
nspec_ya4's Avatar
if u can get the lock cylinder out all the way.
Tear it apart until u have the pistons and the cylinder left. Then insert the key into it and see how they line up. If any of those pistons are poking out, pull it out and clean it up. If that still doesnt work, then insert the key again, and grind them until they're flush w/ cylinder.
I had to do that to my 89 supra. I only had one key and that was for the ignition, the doors used a different key. So I did all that and it worked pretty well.
I think I have pictures of it somewhere in my computer. If i find them, they'll be on here.
Old 01-14-2009, 09:14 PM   #18
Registered Member
Oh1TypeS's Avatar
Just buy a remote starter dude....done, problem solved.
Oh1TypeS is offline   Reply With Quote
Old 01-15-2009, 01:00 AM   #19
Wide Body 3.2 CL-S
Quote:
a remote starter and not add the brake pedal disengage? not safe.... -_-'' lol... and i think that costs more than replacing the ignition cylinder. but its an idea.
Old 01-15-2009, 02:28 PM   #20
B A N N E D
Even if you do get a remote starter, dont you still have to insert the key and turn it, I know in GM cars when u engage the remote start you have to put the key in and turn it before u can drive off!
BTW my keys seem to be working fine now, It all started happening when me car had a sheet of ice on it and since i put it in the shop at work one day and it seems to work fine now, maybee it was just frozen up in there somewhere..
Old 01-15-2009, 05:22 PM   #21
Wide Body 3.2 CL-S
well u can make it so u dnt have to put the key in the ignition. which was the thing about not doing the brake pedal disengage. well now that its working, this thread is done lol. glad it worked for you without spending money
Thread Thread Starter Forum Replies Last Post
2016 RDX Elite explained for people looking for their first luxury vehicle rockyboy Second Generation RDX (2013+) 161 05-09-2016 09:07 PM
September 27th Sunday - Touge.ca Cayuga TMP track event 5-8pm/Dusk! #20 of 20+ Events Mugen TSX Eastern Canada 0 09-16-2015 10:52 PM
Rental Review: 2016 Hyundai Sonata Hybrid PortlandRL Car Talk 2 09-14-2015 01:01 PM
Tranny only 2 years old, pressure switches already bad??? HeloDown 3G TL Problems & Fixes 4 09-08-2015 07:51 PM
2015 TLX Fog Lights - Only on when headlights set to auto? prox 5G TLX Problems & Fixes 6 09-01-2015 03:03 AM
Tags
32, 32cl, acura, cl, copy, diy, engine, ignition, jiggle, key, made, make, start, switch, worn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
