Eibach sway bars
Eibach sway bars
I need some help replacing the sway bar bushings. can anyone tell tell me part numbers for both front and rear bars.
I am currently running eibach sway bars with stock end links.
Here are some pics of the end link that broke off as well as a bushing:
i found his but i don't know which which to choose from non-grease or grease
energysuspension.com | Sway Bar & End Link Bushings
3.5 psi
if you want to be able to grease them on occasion then get those. I'd just get the regular ones. Wrap the bar in plumbing Teflon tape where the bushing will touch and this will help stop any banging or squeaking.
spaceghostpurrp (04-28-2015)
Little update...
I just bought a pair of Moog front sway-bar end-links to go along with a new 29mm front Eibach sway-bar. The reason being my old Eibach front sway bar cracked, breaking off one of the oem end-links along with it.
My question is are mood end-links pre-greased from factory?
If not what grease should i use?
When I installed mine, they had a little from the factory. I could see it as I tapped the zerk fitting in; however, you are going to want to hit them with a little more.
Any type of heavy axle grease is fine, that's all I use on mine. Grease them just until you see it pass the rubber cover and wipe down.
spaceghostpurrp (01-20-2016)
@gnuts: Hahaha Idk bro. I was just cruising down a fairly flat road. The broken part of the bar (still attached to the end-link) was just dragging on the floor. Lol
ExcelerateRep
Sponsored Sales & Group Buys
09-22-2015 10:39 AM
