Black Rubber Piece In Clutch Reservoir
Old 08-13-2015, 06:08 PM
I Wanna Beer
TheWeez's Avatar
Just had to refill my clutch fluid as it was very low and the pedal travel was very little. The black rubber piece with the white plastic top was fully extended when I opened the reservoir. I assume this should be folded up rather than fully extended to where it takes up most of the room in the reservoir, displacing most of the fluid when filled and overflowing the cylinder?
Old 08-13-2015, 09:03 PM
I Wanna Beer
TheWeez's Avatar
Went back and took another look. Popped it back into itself. Must have had the suction pull it out with the reservoir almost empty. All good now.
Old 08-14-2015, 12:18 AM
01acls's Avatar
When the fluild level is down to the low mark that usually means the pads are due for a replacement. Keep an eye on the brakes.
Old 08-14-2015, 05:38 AM
I Wanna Beer
TheWeez's Avatar
This is the clutch, not the brakes. Same fluid, different reservoir.
Replaced all 4 brake pads in the past year so they should be good for quite a while.
Old 08-14-2015, 11:41 AM
01acls's Avatar
LOL
Ahh I think you might have a leak. Fluild should not go down. Plus the low pedal might be a symptom.
Old 08-14-2015, 12:30 PM
I Wanna Beer
TheWeez's Avatar
I'll watch and see. I've never added any fluid in all the years I've owned the car.
Old 08-14-2015, 02:08 PM
01acls's Avatar
If there's no leak then the master cylinder is worn out. You will need to replace it soon. Preferably on your terms and not stuck on the side of the road somewhere.
cycdaniel
12-17-2019 10:58 AM
james357
02-13-2016 02:37 PM
merc009
01-27-2016 10:34 AM
Oakes
Wash & Wax
11-12-2015 09:34 PM
nuldabz
09-03-2015 05:49 PM
Quick Reply: Black Rubber Piece In Clutch Reservoir
