Am I being ripped off??
Old 03-16-2017, 11:54 AM
Angrybear's Avatar
Hello,
in Jan of this year I bought Acura 3.2 CL-S 6mt. it had 185k miles.
after buying it, it started making a chirping/squeaking sound when clutch was NOT engaged. Upon engagement, the sound goes away.
additionally, it has gotten increasingly difficult to shift the car into first or reverse. It takes ALOT of force and does not feel good.
The dealer where I bought the car replaced the clutch.
i took it to a local transmission shop, and he said the transmission is toast, needs this that and synchro. He wants $2500... im
pretty sure he is trying to gyp me. Anyone know if this is a serious problem worth the replacement of
the whole unit, or could replacing key parts also fix the issue?? Google tells me it's done bearings inside the tranny.
Help!
Old 03-16-2017, 11:59 AM
Received 16,260 Likes on 11,971 Posts
if the throwout bearing in the clutch wasnt replaced when the clutch was installed, that could very well be your noise...because that's exactly the symptoms of a bad throwout bearing
Old 03-16-2017, 12:06 PM
Angrybear's Avatar
What about the difficult shifting? The inability to shift into 1st or reverse. There's too much resistance. When the engine is off, the tranny shifts like butter
Old 03-16-2017, 12:10 PM
you can try changing the fluid.
if that doesnt resolve it, maybe the synchros are failing.
you can rebuild the synchros.
and the last resort would be tranny swap.
but you could get a junk yard tranny for cheap.
Old 03-16-2017, 12:13 PM
Angrybear's Avatar
Ughhhh I love this car, but I think I'm gonna get rid of it. I can't afford to continue fixing it.
Old 03-16-2017, 12:16 PM
that's all cars,man.
cars are machines. if a part wears out, it needs to be replaced.
$2500 is a lot cheaper than a brand new $30k car
Old 03-16-2017, 12:24 PM
Received 8,584 Likes on 6,630 Posts
I'll take it off your hands for $1000
justnspace (03-16-2017)
Old 03-16-2017, 12:38 PM
Angrybear's Avatar
Ill have to make a decision. I've replaced so much on this car. Would hate to do half or about the same to the next used car I buy. Sigh...
Old 03-16-2017, 12:40 PM
Angrybear's Avatar
Right... I bought the car for 4000 in January. Then I've spent about a grand in
getting a lot done like timing belt water pump tires alignment fluids changed. New battery...
y would I sell it for a 1000?
Old 03-16-2017, 12:42 PM
Because
Old 03-16-2017, 12:43 PM
Angrybear's Avatar
Because
im not giving it away...
Old 03-16-2017, 12:44 PM
Angrybear's Avatar
It runs n drives just fine
lol it was a joke, buying it for $1k
but yes, all that maintenance is apart of car ownership.
if you purchase another car for $4k, there's NO telling how much more $ you'll put into it.
Old 03-16-2017, 01:12 PM
Old 03-16-2017, 10:20 PM
Humberwho's Avatar
They are great cars. You already took care of a biggy with the timing belt. At this point my advice would be to see what other issues are going to be coming up. Are there maintenance records from previous owners? With 180k on it, they have probably already taken care of some of the peripherals, PS pump, radiator etc. Also, you may have no choice but to fix it as not many folks will buy it with that big of an issue at a price where you break even. There are usually a couple 03 CL6's on autotrader with under 100K on them for 8000 or so. Anyway assuming there are not other big issues, I think fix it, drive it long enough to recoup your expenses and then reevaluate at that time. All imho. Hope it works out for you. Edit: There are a bunch of "you shoulda" things to say about the purchase but that won't help you so I am just trying to give an objective opinion for where you are now and moving forward.
Old 03-17-2017, 07:16 AM
Angrybear's Avatar
thank you for your response.
I really want to keep it for my car collection.
Its really powerful, bone stock, I've yet to lose a race.
the ps pump was changed when I got it.
Not sure about radiator. Alternator looks orig.
im not sure when the tranny will fail, I drove it all across the eastern seaboard for the last 5k miles after I bought it.
Old 03-17-2017, 07:17 AM
Angrybear's Avatar
I'll see how I feel ina couple weeks....
Old 03-17-2017, 08:07 AM
johnboy1313's Avatar
Once upon a time, I had an '89 Nissan Pulsar that had these same issues. A new throwout bearing cured it all.
justnspace (03-17-2017)
Old 04-14-2017, 02:36 PM
8th Gear
laylow3down's Avatar
sounds like my clutch when it went out...had a hard time going into 1st and going from 2nd to 3rd.. change the tranny gear fluid when I did the clutch... nice and smooth since I did it
