The 6-Speed mileage thread
#321
https://acurazine.com/forums/2g-cl-2001-2003-50/all-diy-rear-eng-mount-installers-cls-6-a-775901/
I've got 115K on my six speed, 70K of those are S/C'ed.
Timing Belt, water pump, TB tensioner, and TB pullies are next IF I'm successful at getting that dam crank bolt off. Have to use the starter method because of the stock size UR pulley.
#323
i did front mount 3 months ago and i dont want to do it again i go to my good mechanic that he wont charge me much for that... i just want to get all parts i need...
all mounts then fill them poly... headers are here, front camber kit, all parts for T belt, alternator, vavle adj... then ima give him a car for a day or two...
we'll see how long that clutch will last but next setup will be Luk flywheel P2R disc and oem plate and bearings also slave valve (?) removal
#329
Whats up with RDX owners?
139k
139,xxx currently bought it with @bout 120K on it...last yr
-changed the trans fluid, plugs, oil(2/3xs), rotate tires, timing belt, couple other maintenance issues..since buying the car.
-Runs like a champ
---mod
-changed the shift boot
-Runs like a champ
---mod
#337
120,6xx as of last night.
#344
87 800 clutch pedal is getting worse and worse, even when i rev the engine few times on neutrall clutch pedal become hard to depress and stiff - sometimes doesnt want to go back
fixed IMRC and car is now like a rocket again...
145mph to 55mph panic braking my front brakes are gone. ordered EBC rotors and redstuff pads. im still waiting for mounts from excelerate but this wont happen.
detailing needs to be done as well
im looking for link where i can get moog rsb links and armrest doesnt wanna close anymore
#347
123,7xx as of last night.
Street - get the locking plastic for the armest, PN 83407-S0K-A01
Its less then $10.
Its less then $10.
#348
#349
88 888 miles
here are the videos of broken and then good IMRC that i replaced
in the first video you can hear that weird noise of teeth grinding at 3800rpms
http://www.youtube.com/watch?v=T64kfrM74uo
http://www.youtube.com/watch?v=cmvYTt9YLak
and also picture of broken teeth
#351
125,140 as of last night.
