2003 Acura TL-S cat delete
Old 09-30-2016, 08:29 PM
5th Gear
Miguel Sahagun's Avatar
Hey kinda new here,
I've had my 03 for a while now and it makes pretty good HP, thing is, it doesn't sound as good when I'm reving it, kinda quiet, any way I can delete the cat but replace it just in case? Like a bolt on or something?
Old 09-30-2016, 10:31 PM
03 tls nc's Avatar
Yes for about $20 shipped you can order a test pipe for a 01 Accord V6 off Ebay. You will also want a 90 degree spark de-fouler for the O2 sensor should less than $20 as well.
It will soot up the back of your car and some say that it smells bad.
Old 10-01-2016, 08:26 AM
3.5 psi
gnuts's Avatar
You're better off having a shop weld on some mufflers or replace your mid muffler with an aftermarket one. You won't get a nicer sound from no cat in my opinion.
03 tls nc (10-01-2016)
Old 10-08-2016, 11:10 AM
J35 _ 5 Speed A/T
WHEEELMAN's Avatar
If the CL-s exhaust system is like the accord, you should just start with removing the "pre-muffler", that will add some exhaust note to it.
A Cat-Delete will make it louder, might add some rasp to it at higher rpm.
Doing both, will be end up being loud. might add some Drone too?
Old 10-08-2016, 12:40 PM
5th Gear
Alrready bought and put the test pipe on, not too much difference, V-tec kicks in higher rpm's, sounds a bit more free, will a J-Pipe help performance?
Old 10-08-2016, 02:31 PM
3.5 psi
gnuts's Avatar
VTEC kicks in at the same rpm always.
Our cars have traditional headers and they're the best power mod. If you're automatic, DC are quality.
ExcelerateRep
06-20-2022 09:21 PM
blackhorse21
11-14-2016 11:03 AM
hxrguitar
09-28-2016 02:57 PM
WhiteAcura2003
05-20-2016 12:33 PM
TRodrigues22
05-02-2016 12:30 AM
Quick Reply: 2003 Acura TL-S cat delete
