03 cl 6 speed clutch recommendation
Old 10-03-2015, 04:01 PM
KingBattle's Avatar
So yesterday I was driving my car and what I think is a bad t-out bearing went bad. The car isn't moving or anything or making noises when I push it in gear after engaging the clutch. It's acting as if it's in neutral. So with that being said I'm looking at replacing the clutch kit. First question how complicated is it to do on the cls?
Second what clutch do you guys recommend? The car will be stock in performance mods.
Old 10-03-2015, 06:21 PM
3.5 psi
gnuts's Avatar
Stick with oem. The other option is like four times the price and is performance oriented.
Old 10-03-2015, 08:53 PM
Received 1,733 Likes on 1,390 Posts
I agree with gnuts. You can get the LUK OEM equivalent clutch kit and flywheel at rockauto for well under $400 shipped. Since you did not mention current mileage, it would be prudent to replace the rear main seal (91214-P8A-A01), as well, while you are there.
Old 10-04-2015, 06:21 AM
KingBattle's Avatar
it has right at 117k miles on it, question, how hard is it to do the clutch on these ill try to do some research on it as well. should I replace any of the mounts while im in there as well?
Old 10-05-2015, 08:49 AM
Scottyknows007's Avatar
If you know what your doing it isnt too bad. I replaced it for the first time back in May and it was a headache! Next time I would probably just buy the parts and take it to a shop to do the labor.. but that's just me. But as Zeta said I would deff replace the rear main sale while you are right there!
Old 10-05-2015, 10:43 AM
mattcl-s's Avatar
I am also looking at a getting my clutch done mines around 184xxx does anyone know the part number for the one on rock auto? there's four clutches not sure what one it is.
Old 10-05-2015, 01:33 PM
teh CL's Avatar
^ the one that says LUK
mattcl-s (10-05-2015)
Old 10-05-2015, 02:15 PM
mattcl-s's Avatar
thanks!
Old 10-14-2015, 01:21 PM
mattcl-s's Avatar
got a clutch , flywheel, and rear main seal for 380.00$ now just need to find shop to put it in
akbears15
15
11-05-2015 07:06 AM
P1zzaman
09-17-2015 04:56 PM
TxRzrBk
09-17-2015 01:07 PM
jrleclerc88
09-17-2015 10:26 AM
Desert Ridge
09-05-2015 09:47 AM
Quick Reply: 03 cl 6 speed clutch recommendation
