car wants to stall when giving it gas
1999 Acura CL 2.3
Hello all
ok..replaced tps and iac but car still wants to stall when giving it gas..
what could this be??i was hoping after replacing those 2 parts it would solve the issue but it did not..
any suggestions?
thanx
any suggestions?
thanx
Check your injectors. Are they humming or making clicking noises? When you first turn the car on can you hear the fuel pump(when you turn key all the way forward without staring it)?
1999 Acura CL 2.3
could it be my map sensor is bad??i didnt replace that yet or mayb sum connection is broken when the tps was replaced??
thanx
Bagel Bomber
I'm watching this also, my car will stall after starting, but just sometimes. Other times it's perfect. After I get the car into gear and going it never stalls again just after start. Cold/hot doesn't matter.
Check your timing. It could be off a tooth?
Also check to make sure your not sucking in air after the map sensor. That can cause a mysterious power loss/engine dying.
