car wants to stall when giving it gas
Old 09-27-2014, 02:09 PM
1999 Acura CL 2.3
Gigolo's Avatar
Hello all
ok..replaced tps and iac but car still wants to stall when giving it gas..
what could this be??i was hoping after replacing those 2 parts it would solve the issue but it did not..
any suggestions?
thanx
Old 09-27-2014, 08:59 PM
Showmeyourtints's Avatar
Is the gas in the tank old? Maybe drain it and put some new gas in there.
Old 10-01-2014, 11:31 AM
1999 Acura CL 2.3
Gigolo's Avatar
no..not old
just changed the gas filter today...still not working
when u gie it gas it wants to stall..like gas isnt getting to where its suppose to
Old 10-01-2014, 10:34 PM
Check your injectors. Are they humming or making clicking noises? When you first turn the car on can you hear the fuel pump(when you turn key all the way forward without staring it)?
Old 10-05-2014, 09:45 PM
1999 Acura CL 2.3
Gigolo's Avatar
thanx for the hints...
but turns out its the ecu ...
i just ordered one..
will update post once installed and see if that solves it..
Old 10-16-2014, 06:08 PM
1999 Acura CL 2.3
Gigolo's Avatar
well its not the ECU..sent it out for a full on test and it came back as nothing is wrong..
anymore ideas??
Old 10-16-2014, 07:37 PM
'97 2.2cl
J_Wrenchin's Avatar
I'd say injectors or other fuel delivery? other than that I would check your spark plugs, check your plug wires, distributor, etc.
Old 10-16-2014, 09:53 PM
1999 Acura CL 2.3
Gigolo's Avatar
distributor is new..plugs are about a year old now..gas filter new,the fuel pressure was tested and its working..
could it be my map sensor is bad??i didnt replace that yet or mayb sum connection is broken when the tps was replaced??
thanx
Old 04-25-2015, 10:55 PM
3rd Gear
demebaker's Avatar
I'm having the same problem did you ever find out what caused this issue ???
Old 04-26-2015, 03:36 PM
Bagel Bomber
Mach30SiR's Avatar
I'm watching this also, my car will stall after starting, but just sometimes. Other times it's perfect. After I get the car into gear and going it never stalls again just after start. Cold/hot doesn't matter.
Old 04-26-2015, 07:49 PM
musiclevelz5's Avatar
Check your timing. It could be off a tooth?
Also check to make sure your not sucking in air after the map sensor. That can cause a mysterious power loss/engine dying.
peti1212
ILX
22
01-05-2022 05:14 PM
02-25-2020 09:57 AM
SpraykwoN
ILX
09-23-2015 11:44 AM
kuzdu
09-10-2015 08:42 PM
BlueAquarian
09-10-2015 02:18 PM
Quick Reply: car wants to stall when giving it gas
