Alternator Bracket Break... - AcuraZine Community
Go Back   AcuraZine Community > AcuraZine CL Community > First Generation CL Discussion (1997-1999) > Problems & Fixes
Log In
LinkBack Thread Tools Search this Thread
Old 01-07-2012, 10:54 PM   #1
1998 Acura CL 3.0 Premium
jws247's Avatar
Trader Rating: (0)
So a couple of days ago I started up my CL and heard something on the serpentine belt screaming, so I pop the hood and discover that the belt is loose. I immediately assume that the belt tensionor is my problem, so did my mechanic friend, $60 dollars and many hours later I still had a loose belt... Out of desperation and a need to get to work the next day I just put a belt on that was about an inch shorter, worked like a charm, but today after close inspection I realized that my problem was the top mounting bracket for the alternator had snapped in half. All the junk yards around here are closed tomorrow (sunday) and I don't get off in time to hit one up after work next week. I really don't wanna just let the alternator ride with one bolt for very long, Does anyone know where I could buy one online? I found a universal mounting bracket on auto zone's website but it looks like cheap crap... It's a '98 CL with 3.0
jws247 is offline   Reply With Quote
Old 01-09-2012, 11:18 AM   #2
Registered Member
timeizmoney22's Avatar
Trader Rating: (0)
Danny Sadoski timeizmoney22 da1arm3dbandit
Maybe http://www.oemacuraparts.com/
__________________
Ebay CAI w/K&N filter,Magnaflow 14832 Muffler,Neuspeed Sport springs, 17's with 215/45/17 Toyo's,DRT Sport slotted rotors,Legend Calipers, ST front Swaybar, Tanabe upper strut bar
06 TSX w/nav-tints, ISC Coilovers, UR Stock Diameter Crank Pulley, Injen CAI
timeizmoney22 is offline   Reply With Quote
Old 01-11-2012, 11:39 AM   #3
Registered Member
ExShinobi's Avatar
Trader Rating: (0)
http://www.facebook.com/profile.php?id=637548891 ronin Shinobi
Ive had an issue with this b4 on mine, but my alt is an oversize high amp to support the system. Bracket snapped at the corners cuz of hvy weight and red-lining more than i needed to. I actually just went and had welder fix it. no probs since. just have to keep an eye on it
ExShinobi is offline   Reply With Quote
Old 01-11-2012, 07:24 PM   #4
jws247's Avatar
Trader Rating: (0)
Fixed
[UPDATE]
So I finally got the alternator bracket monday, I called a local Honda dealership and luckily they had one in stock (Only about $16 as opposed to $38.64 @ acuraoemparts.com) and that's where my luck ran out... the shorter belt that I put on exerted too much tension on the one bolt that was holding my alternator on and it snapped off in the block. I had to take it to a mechanic to get the remainder of the bolt out of my engine ($140). On the bright side, the new bracket I got from honda seems a little more heavy duty than the original. I could also see that this had happened before on the car and they just spot welded the bracket back together.
a pic of the old bustedbracket
Click the image to open in full size.
here's the new one
Also if you order it from www.oemacuraparts.com (thanks to timeizmoney22) the top bracket is the one I circled in red, part# 31113-P8A-A00.
Old 01-01-2016, 06:01 PM   #5
Registered Member
Trader Rating: (0)
JWS247 my acura cl braket broke today. You mentioned getting the bracket in town for a reasonable price $16 Could you give me the name where you got the bracket (part is alternator stay #31113-P8A-A00)
jbpost52 is offline   Reply With Quote
Old 01-01-2016, 06:02 PM   #6
Registered Member
Trader Rating: (0)
Old 01-01-2016, 07:10 PM   #7
jws247's Avatar
Trader Rating: (0)
Quote:
Well I'm not sure where you're located so it may or may not be a drive for you to Tennessee but I got mine at Redell Honda of Murfreesboro. Any certified Honda or Acura dealership should have a parts department that can hook you up with the part though. FYI the alternator ended up breaking loose again (on the engine block side not the bracket) and I got rid of the old CL.
Similar Threads
Thread Thread Starter Forum Replies Last Post
FS: 2003 Acura CL-S 6MT ABP ★★Location of Vehicle : Edmonton, AB, Canada★★ rp_guy Member Cars for Sale 1 10-22-2015 03:58 PM
SRS after collision brboy Second Generation RL (2005-2012) 5 10-05-2015 12:34 PM
Check Engine Light and P0683 Code mars First Generation TSX Discussion (2004-2008) 1 09-28-2015 12:03 PM
Starter Issues with 05 RL agupta3224 Second Generation RL (2005-2012) 4 09-22-2015 09:08 PM
Tags
30, 31113p8aa00, 97, 98, accura, acura, altenator, alternator, block, bolt, bracket, break, broke, cl, honda, snap
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Acurazine.com content, comments, or advertising. Acurazine.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Acurazine.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
