AC not working??? HELP - AcuraZine Community
Go Back   AcuraZine Community > AcuraZine CL Community > First Generation CL Discussion (1997-1999) > Problems & Fixes
Log In
LinkBack Thread Tools Search this Thread
Old 08-07-2009, 09:20 PM   #1
Registered Member
JDM97CL's Avatar
Trader Rating: (0)
My AC just stopped working out of no where. I have no clue what it is and i was wondering if anybody has any suggestions on what it may be. I was told i might need freeze on but idk.
JDM97CL is offline   Reply With Quote
Old 08-07-2009, 09:58 PM   #2
6spd FTW
Tehvine's Avatar
Trader Rating: (0)
Is the compressor kicking on? Should be noticeable when it does kick on at idle.
Tehvine is offline   Reply With Quote
Old 08-10-2009, 08:12 PM   #3
Registered Member
JDM97CL's Avatar
Trader Rating: (0)
Quote:
nope it doesnt
Old 08-11-2009, 01:10 AM   #4
Registered Member
Trader Rating: (0)
i have a question my a/c work and it blows cold air but not as that cold...it blows like the fan is just on? do i just need to put freion on it....
acura_honda_30cl is offline   Reply With Quote
Old 08-11-2009, 11:05 PM   #5
Registered Member
JDM97CL's Avatar
Trader Rating: (0)
Quote:
Yup.
Old 08-18-2009, 01:46 PM   #6
Registered Member
JDM97CL's Avatar
Trader Rating: (0)
so its the compressor???
Old 08-18-2009, 10:48 PM   #7
Old School Ridin Clean
WineRed2.2CL's Avatar
Trader Rating: (0)
yeah if its not blowing any air out
__________________
97 Acura 2.2 CL customization in progress
WineRed2.2CL is offline   Reply With Quote
Old 08-24-2009, 04:59 PM   #8
Registered Member
JDM97CL's Avatar
Trader Rating: (0)
Quote:
its blowing air just not cold
Old 08-24-2009, 05:53 PM   #9
Low and Slow
YtseJammer's Avatar
Trader Rating: (0)
Will it blow cold if you rev or floor the gas, or does it always blow hot? I'd put more freon in it and check for leaks. If you try to run the a/c for too long like this it may end up frying your compressor like it did with mine.
YtseJammer is offline   Reply With Quote
Old 08-24-2009, 08:58 PM   #10
Registered Member
JDM97CL's Avatar
Trader Rating: (0)
Quote:
its always hot even if i rev it. But my car was in a accident before and i donr kno if it was fixed or not. because it did work, its jus not cold
Old 09-04-2009, 08:49 AM   #11
Registered Member
Trader Rating: (0)
Did you figure out the a/c? My car a/c isn't working as well.
__________________
1997 Acura 2.2 CL 5spd
khmerpride is offline   Reply With Quote
Old 09-04-2009, 11:05 AM   #12
Registered Member
JDM97CL's Avatar
Trader Rating: (0)
Quote:
Nah i didnt i guess nobody knos what it is.!
Old 09-04-2009, 06:01 PM   #13
Registered Member
Trader Rating: (0)
Ah, well if you ever get it diagnosed by a shop, let me know how it goes. I need to get my a/c checked too.
__________________
Old 09-04-2009, 07:18 PM   #14
Registered Member
JDM97CL's Avatar
Trader Rating: (0)
ight man no dought but its probly not guna b for awhile cuz its about to be winter for me so... but ill still find it out and ill let you kno.
Old 09-04-2009, 11:34 PM   #15
Registered Member
Trader Rating: (0)
Lol, yeah, I don't plan on fixing mine till spring too. My a/c compressor still turns on and works, but it has a leak somewhere, haven't gotten it checked out yet. I just hope it's not a major component broken somewhere and that it's just a hose or something leaking.
__________________
Old 09-07-2009, 01:31 AM   #16
Registered Member
JDM97CL's Avatar
Trader Rating: (0)
see ur lucky lol i cant here mine turn on so i dont kno whats going on
Old 09-07-2009, 01:30 PM   #17
Trader Rating: (0)
if it blows air at least. Refill it with r 34 refrigerant, But buy the whole kit with a gauge that tells you if your low on freeze to high or got a leak.
Good luck
__________________
Old 09-07-2009, 01:43 PM   #18
Registered Member
JDM97CL's Avatar
Trader Rating: (0)
thanks man
Old 09-10-2009, 11:09 PM   #19
Registered Member
Trader Rating: (0)
Try connecting 12 volts to wire on compressor- if clutch on compressor kicks on-check the relays hanging off radiator. If it doesn't it's probably the compressor.
acurahb is offline   Reply With Quote
Old 07-28-2010, 03:27 AM   #20
Master of the Commode
Trader Rating: (0)
Any resolution ever come of either situation?
arsouders is offline   Reply With Quote
Old 08-02-2010, 11:59 AM   #21
Registered Member
Trader Rating: (0)
Thanks for the information WineRed2.2CL. My A/C blows cool air not cold. The shop wanted $175 to charge it. Thinking of getting the kit and doing it myself!
shadow1185 is offline   Reply With Quote
Old 08-17-2010, 08:56 PM   #22
New Member
Trader Rating: (0)
somethings wrong with my a/c. it works perfectly fine with cold air but its leaking cold water by there the passengers foot would go... while driving, when i turn hard it leaks water inside as well. can anyone tell me how to fix this? i've already invested $500 on the a/c... its starting to piss me off. :p
littlekoreanboi is offline   Reply With Quote
Old 08-18-2010, 11:37 AM   #23
Registered Member
sickcl480's Avatar
Trader Rating: (0)
Quote:
Your evaporator core is leaking either because the tube that drains the water out of the car has fallen off or because the evaporator is cracked. Basically itís a big black box you can see if you look under the passenger dash that should have a tube coming off the front and routes the condensation out of the cabin and drains onto the road. Hopefully that helps.
sickcl480 is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
Triangle with "!" at startup, and VSA light after 30-40mph. Help! mada51589 Problems & Fixes 27 01-24-2016 03:42 PM
SOLD: 19 inch Work Vs-Tx acurajj Car Parts for Sale 5 09-19-2015 04:47 PM
TL: Radio not working Luis J. Rodriguez Audio, Video, Electronics & Navigation 2 09-12-2015 11:00 PM
High Beams won't work spidermankb Problems & Fixes 1 09-09-2015 06:19 PM
'08 TL - Window buttons do not work on all doors (using key in lock works) ahsm Problems & Fixes 3 09-09-2015 09:35 AM
Tags
ac, acura, air, blowing, cold, condenser, fan, inop, kno, mdx, problem, rsx, tl, tsx, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Acurazine.com content, comments, or advertising. Acurazine.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Acurazine.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
