Another ABS Thread - Where to Find Code Meanings?
My ABS light has been on for awhile and I'm hoping to fix it. I've replaced a few wheel sensors in the past with the help of these forums.
I've spent about 45 minutes looking at old threads to see if I can find the list of ABS codes for 1998 models, and can't find it. Some of the threads link to websites that are now dead.
Anyone remember where this list of code meanings is? I'm pulling these codes:
1-5
1-6
1-7
8-1
Thanks!
1-5
1-6
1-7
8-1
Thanks!
Found:
DTC Code Lookup
No DTC and ABS Indicator OFF: ABS indicator does not come on.
No DTC and ABS Indicator ON: ABS indicator does not go on (no DTC).
DTC ON for rest
1-1 Wheel sensor Front Right (open/short to body ground/short to power)
1-2 Wheel sensor Front Right (electrical noise/intermittent interruption)
1-3 Wheel sensor Front Left (open/short to body ground/short to power)
1-4 Wheel sensor Front Left (electrical noise/intermittent interruption)
1-5 Wheel sensor Rear Right (open/short to body ground/short to power)
1-6 Wheel sensor Rear Right (electrical noise/intermittent interruption)
1-7 Wheel sensor Rear Left (open/short to body ground/short to power)
1-8 Wheel sensor Rear Left (electrical noise/intermittent interruption)
2-1 Pulser Front Right
2-2 Pulser Front Right
2-3 Pulser Rear Left
2-4 Pulser Rear Left
3-1 Solenoid Front Right-IN (short to body ground/short to wire)
3-2 Solenoid Front Right-OUT (short to body ground/short to wire)
3-3 Solenoid Front Left-IN (short to body ground/short to wire)
3-4 Solenoid Front Left-OUT (short to body ground/short to wire)
3-5 Solenoid Rear Right-IN (short to body ground/short to wire)
3-6 Solenoid Rear Right-OUT (short to body ground/short to wire)
3-7 Solenoid Rear Left-IN (short to body ground/short to wire)
3-8 Solenoid Rear Left-OUT (short to body ground/short to wire)
4-1 Wheel Lock Front Right
4-2 Wheel Lock Right
4-3 Wheel Lock Left
4-4 Wheel Lock Left
5-1 Motor lock
5-2 Motor stuck OFF
5-3 Motor stuck ON
5-4 Fail-safe relay
6-1 Ignition voltage
6-2 Ignition voltage
7-1 Different diameter tire
8-1 Central Processing Unit (CPU) diagnosis, and ROM/RAM diagnosis
DTC Code Lookup
DTC ON for rest
4-3 Wheel Lock Left
4-4 Wheel Lock Left
5-1 Motor lock
5-2 Motor stuck OFF
5-3 Motor stuck ON
5-4 Fail-safe relay
J_Wrenchin (11-10-2014)
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
