What might cause car to tremble when sitting idle? - AcuraZine Community
Go Back   AcuraZine Community > AcuraZine CL Community > Second Generation CL Discussion (2000-2003) > Problems & Fixes
Log In
LinkBack Thread Tools Search this Thread
Old 01-29-2007, 01:11 PM   #1
Registered Member
Eddie Kain's Avatar
Trader Rating: (0)
I can really feel it when in the drivers seat, but not so much while in the passenger seat. Its like a wave pattern. Trembles 2 seconds, goes away 2 seconds, Trembles 2 seconds, goes away 2 seconds, etc.
Any ideas as to why this is happening? More recently, I have been having problems with the vehicle stalling at startup, as well as acceleration problems.
I took the car into carmax and all they said was the egr valve was bad.
Would that bad valve be the culprit to all of these malfunctions?
__________________
2001 Teffeta White Acura CL-S Auto.
Eddie Kain is offline   Reply With Quote
Old 02-10-2007, 04:36 AM   #2
Registered Member
miker_types's Avatar
Trader Rating: (0)
^ bump, my car kinda does the same thing at idle, it shakes a bit
miker_types is offline   Reply With Quote
Old 02-10-2007, 02:53 PM   #3
fuzzy02CLS's Avatar
Trader Rating: (2)
Dirty, or bad IAC valve. Common problem. Search for the threads on it. It's not hard to clean or replace yourself.
fuzzy02CLS is online now   Reply With Quote
Old 02-11-2007, 03:07 AM   #4
Registered Member
Trader Rating: (0)
ty, ty, imma research this, that shake drives me crazy some times
Old 02-11-2007, 07:22 AM   #5
superfob's Avatar
Trader Rating: (0)
I cleaned my IAC and the stalling went away but it still trembles a little but not that much.
Try cleaning it, and see if it goes away.
superfob is offline   Reply With Quote
Old 02-12-2007, 10:42 AM   #6
Registered Member
Eddie Kain's Avatar
Trader Rating: (0)
The error code that I got was my EGR Valve, not my IAC. I had it replaced, it stopped stalling, but I still have the suttle shake while idle.
Old 02-26-2007, 12:55 AM   #7
Registered Member
Trader Rating: (0)
their is always the possibility of a broken motor mount
fenixxishot is offline   Reply With Quote
Old 03-01-2007, 09:06 PM   #8
Registered Member
Trader Rating: (0)
I have the same shake everyone's talking about. When sitting in park you feel a shudder vibration that comes and goes...comes and goes.......about every sec or two.
I just got 105K service done....timing belt, drive belts, plugs, check for valve noise, etc. The car feels like brand new again!!! I decided to have the PS fluid replaced as well and boy does it make a difference! Steering is awesome now...just like on day one.
And replacing the spark plugs didn't fix or change the vibration, so I'm guessing it isn't related to that....same as before, so not exactly sure. The engine and trans mounts were also checked and other than a little dry rot, no issues with them.
So not sure on the cause.......maybe a slowly dying ignition coil??.....or something else?? Perhaps we'll determine the cause based on other's input and repairs they have had done....good or bad.
djarovsky is offline   Reply With Quote
Old 03-01-2007, 09:36 PM   #9
Registered Member
Trader Rating: (0)
I also did a search and found lots of threads......lots of people seem to have this issue, reported with varying mileage on their cars. The majority seems to suspect bad engine mount(s) and others have many other opinions.
I hope someone on this board knows the root cause.
Old 03-06-2007, 02:52 AM   #10
New Member
Trader Rating: (0)
hey guys I had the exact same problem and went to three different shops, nobody could figure it out! However I got the problem fixed today down in El Monte. Suprisingly it was a rookie, about in his early 20's, who figured out the problem. Young, but he was talented!The Acura CL has two fans infront of the engine, he rotated them with his fingures and showed me that the right fan wasn't spinning on track, it was sorta wobbling. After I got it replaced today the annoying vibration was gone! Cost about $180 to repair. Goodluck guys!
jacksonlan33 is offline   Reply With Quote
Old 05-16-2007, 11:19 PM   #11
Registered Member
Trader Rating: (0)
I just had my tranny replaced and now I think the idle shake is gone. Feels smooth now. I wonder if the trans install moved something.
Old 05-17-2007, 06:38 PM   #12
Registered Member
Trader Rating: (0)
Im glad it wasnt just me i have the same problem on my car. I can feel the vibration but its not that bad and only if you feel for it. I could live with it but i would love to figure it out and fix it
stunna10125 is offline   Reply With Quote
Old 05-17-2007, 11:02 PM   #13
Registered Member
m733l's Avatar
Trader Rating: (1)
Quote:
which fan did you replace? both?
m733l is offline   Reply With Quote
Old 05-20-2007, 04:08 PM   #14
Honda Tech
jrmoskal's Avatar
Trader Rating: (0)
Quote:
Yep, mine does it too, It's at the dealer right now getting a new front mount. I put the car on the lift and at only 51k the front mount is wet with oil from being broken.
The A/C compressor kicking on and off will lower the idle and create a slight vibration as well.
jrmoskal is offline   Reply With Quote
Old 05-29-2007, 06:34 PM   #15
Sold My Car
ClaraTypeS's Avatar
Trader Rating: (0)
Honestly this might sound like its rediculous. The same thing happend to me. Car would go into low idle like it might die out. Then it would correct itself. One time, the check engine light and VSA light turned on. I was like WTF?! I kinda backtracked to what I did wrong. About a month earlier I installed new Irridum NGK spark plugs and nothing more. It ran excellent after that. So I thought it couldnt be. Then I could remember filling up at some shitty ass gas station. I usually put 91 octane at Chevron or Shell. Once I ran out of the gas I got from the shitty station I filled up with Chevron and it never happend again. I filled up many times after that at another Chevron or Shell and it still never happend. What im trying to say is maybe you got a bad Batch of gas or youre not putting Premium fuel in it. Is it still doing it?
ClaraTypeS is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
Share your best MPG and how you achieved it. peti1212 Acura ILX Discussion 14 09-24-2015 01:22 PM
Over heating blues Bahamanurse1 Second Generation TL (1999-2003) 17 09-10-2015 11:05 PM
2000 Acura TL 3.2 Reverse (Only) Slips Under Load Mike Bertram Second Generation TL (1999-2003) 9 09-10-2015 10:27 AM
P0300 Random Misfires NSolace Problems & Fixes 1 09-03-2015 09:14 PM
A/C problems dlknight Problems & Fixes 4 09-03-2015 08:54 PM
Tags
acura, ages, car, feels, idle, jumping, light, park, shuddering, sitting, smooth, transmission, tremble, trembles, tsx, wobbling
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Acurazine.com content, comments, or advertising. Acurazine.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Acurazine.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
