Need your help: Changing Auto Transmission Fluid - AcuraZine Community
Go Back   AcuraZine Community > AcuraZine CL Community > Second Generation CL Discussion (2000-2003) > Problems & Fixes
Log In
LinkBack Thread Tools Search this Thread
Old 05-25-2009, 11:02 AM   #1
Registered Member
Brittonj85's Avatar
Trader Rating: (0)
I am on a time budget and could not find any other thread as simple as mine. I just wanted to ask what type of transmission fluid do I need to purchase, how many quarts and what type of filter should I purchase. If there are any preferred brands that I should choose from please let me know.
My specs: 2003 Acura CL Type S, 5spd Auto.
I went to Pep boys and someone told me to get ATF-Z1 and Acura CL do no have filters. I wanted to verify this with someone who knows about Acura CL first.
Thanks!
Brittonj85 is offline   Reply With Quote
Old 05-25-2009, 11:20 AM   #2
wham bam thank you ma'am
Rajca's Avatar
Trader Rating: (8)
get the honda auto trans fluid from your local acura/honda. dont use anything else. we have an internal filter and a small external filter. but ive only read that one person changed the external filter. its really small. to change the internal filter out u need to take apart the trans. just do the 3x3: drain old fluid, put in new fluid (about 3quarts), drive around so u can get into all gears and do this procedure 3 times.
when u drain it, u drain about 3 quarts, maybe a tinch more, so put in 3quarts of new fluid each time u drain the old fluid out. get 10quarts to make sure u dont run low.
__________________
02 SSM TL-S:: TOTALED by mother nature
03 SMR CL-S6:: Boosted & Sprayed
Rajca is offline   Reply With Quote
Old 05-25-2009, 11:31 AM   #3
Registered Member
Brittonj85's Avatar
Trader Rating: (0)
Sweet! You are the man. I will wait until tomorrow to get the fluid from Acura sense everyone over Maryland is closed today. I haven't changed my transmission fluid sense I had the car, for about 2 years but I did notice that the level was low, maybe too low because I can barely see it but I can feel on the dip stick that fluid is there. It's not brown, a bit red but not very clear to the eye but it does smell like tranny fluid. The transmission shits fine in high rpm but far as low is a small thumb as if I was a newbie driving a stick.
When you changed your fluid, you only did the flush and not replaced the filter? I wonder when should the filter be replaced?
Thanks.
Old 05-25-2009, 12:07 PM   #4
Rajca's Avatar
Trader Rating: (8)
did u check the fluid like the owners manual says to do it?
i only changed the fluid in my tl-s. the filter is inside and no way to get it. and the external is like a secondary filter. it goes through the main one inside the trans then the one outside the trans.
__________________
Old 05-25-2009, 12:35 PM   #5
Registered Member
Brittonj85's Avatar
Trader Rating: (0)
Good idea, I will take a look at the owners manual.
Thanks,
Old 05-25-2009, 01:50 PM   #6
B A N N E D
Trader Rating: (1)
Location: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
There IS a external Filter I have one laying around, I never got to install it.
I posted about this B$ if you search u will find the part #.
I have it at home in the bag with the part # on it but will not be home for awile.
StonedCL is offline   Reply With Quote
Old 05-26-2009, 09:13 PM   #7
Registered Member
Brittonj85's Avatar
Trader Rating: (0)
Sweet!!!! I just had my transmission service done today. The car runs great! It's like a brand new car. The transmission shifts perfect and the car rolllllls as if I was trying to speed.
I just had one question about the transmission recall. A friend of mine said if anything happens to my car until I reach 100,000.00 miles I can take it to Acura to be replaced. Is that true?
Nothing is wrong with my transmission now, it was just dirty. I never checked with the dealership if they changed the transmission fluid when I bought the car. I just seen the car on the lot and drove it home that night. I knew I should have checked over the car more but I was on a time budget, had to be on a date that night. Anyway, I love this car. I can't wait until I get my lower springs!!!
Old 05-26-2009, 09:14 PM   #8
Registered Member
Brittonj85's Avatar
Trader Rating: (0)
I wouldn't mind buying it but I don't really see myself getting the filter changed any time soon but thanks.
Old 05-27-2009, 01:21 PM   #9
Registered Member
CL-S24's Avatar
Trader Rating: (0)
Did you do the tranny fluid swap at the dealer? If so, how much?
CL-S24 is offline   Reply With Quote
Old 05-27-2009, 03:04 PM   #10
B A N N E D
Trader Rating: (1)
Quote:
I did it a wayne acura an PAA in the past they charge $90-$120 to flush 3 quarts and add 3 new ones THEY DO NOT DO A 3 X 3 NOR DO THEY CHANGE THE FILTER (THEY DONT EVEN KNOW IT EXISTS) I argued with the parts manager and 2 techs for 10 min about a tranny filter they said it did not exsist untill I gave them the part # then they said (its not a filter its a strainer WTF) IDIOTS! If they where to do a 3 X 3 I would guess they would charge $300 - $400 and if you wanted the (Strainer changed w/that) IT would prob be $400 - $500! I have done alot of RESEARCH on out auto tranny and I am on my 3rd one and had the car over 9 years and im not in warrenty anymore so want to keep it running as long as possible.
IT is easier to change the tranny fluid then the OIL I think ANYONE can do it , The filter (strainer) on the other hand might take a little know how.
a Quart of tranny fluid (ONLY USE HONDA / ACURA Z1 ATF) is like $7-$9.
so go buy 3 quarts and flush 3 and refill 3 on your own unless you wanna do a 3 x 3 then buy 9 quarts and save yourself aa boatload of loot if u need help im in north JERSEY!
Old 05-27-2009, 03:14 PM   #11
B A N N E D
Trader Rating: (1)
Im pretty sure this is the part # for the tranny filter (strainer)
25450-P7W-003
Click the image to open in full size.
Old 05-27-2009, 03:19 PM   #12
B A N N E D
Trader Rating: (1)
Here is some pics to help install it!!
It is #9 in this PIC!
Some of you guys with a older transmission have this oil jet I have a newer (suposidly fixed tranny so DO NOT have the oil jet just a NUT there (this is where u fill the transmission fluid. If u have a oil jet there I belive u have a older transmission (this was acura's band-aid to the problem)
Make sure that while removing the steel fluid line not to damage the o-ring. I replaced mine when I replaced my filter. Be sure to coat it with trans fluid before installing the line.
Old 05-27-2009, 04:56 PM   #13
Registered Member
Trader Rating: (10)
sweet DIY, this should be put in the DIY thread.
im gonna do this at my 105k when i change my tranny fluid.
btw, there are honda ATF-ZR1 compatable fluids that exist.
aznboi2424 is offline   Reply With Quote
Old 05-27-2009, 10:06 PM   #14
Registered Member
Brittonj85's Avatar
Trader Rating: (0)
I didn't because they wanted to charge me 320. I guess it was my blue scrubs that I was wearing from work. I ended up buying 8 bottles and took it to this shop that this 2 Japanese guys own. I've always have taken my car there so I know the guys wouldn't screw me. They have even worked on my 1991 Acura Legend, 1995 Honda Civic etc. He only charged me $50 for the flush and showed me how dirty the fluid was and how to change it.
Old 05-27-2009, 10:08 PM   #15
Registered Member
Brittonj85's Avatar
Trader Rating: (0)
25450-P7W-003
Sweet! Dude you got me thinking about getting mine done. But I only have 50kmiles so I am not sure when it should be done. But the DIY looks pretty simple.
Old 05-28-2009, 04:57 PM   #16
Registered Member
CL-S24's Avatar
Trader Rating: (0)
Stoned and Brittonj, Thanks for the info and awesome DIY!
__________________
Kaixen 6000k's -- Eibach Pro-Kit -- 30/20 Tint -- M Spoiler -- Razo GT Pedals -- PIAA Road Lamps -- Interior LEDs -- Kumho Ecsta ASX's -- Brembo rotors (front/rear) -- Satisfied Pro Ceramics
Old 05-28-2009, 07:00 PM   #17
B A N N E D
Trader Rating: (1)
No problem..
I am glad to help EVERYBODY out because the favor was returned to me 10X!
This forum has saved me a sh()Tload of $$ and thought me alot about this car in the 8-9 years I have been a part of it and I am more then happy to share the info I learned on here. Some people get mad and tell others to search but alot changes monthly/yearly..daily.. Instead of people getting mad they should just answer the question if they know the answer or just do not post anything!
Old 06-05-2009, 09:06 AM   #18
New Member
Trader Rating: (0)
this is awesome. thank you
bartolo333 is offline   Reply With Quote
Old 05-10-2010, 12:03 PM   #19
Registered Member
apigo200x's Avatar
Trader Rating: (0)
hi!!
I had the same problem I change the filter but the oil was not atf z1 honda and two months after the filter is dead yet ...why?
thanks
apigo200x is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
Triangle with "!" at startup, and VSA light after 30-40mph. Help! mada51589 Problems & Fixes 27 01-24-2016 03:42 PM
CLOSED: 4G TL Going Back to Stock (coils, intake, mats, etc...) nanos Car Parts for Sale 26 11-12-2015 09:41 PM
ATF flush vs Drain & AWD Fluid change cobra10363 Second Generation RL (2005-2012) 27 09-21-2015 12:45 PM
2000 Acura TL 3.2 Reverse (Only) Slips Under Load Mike Bertram Second Generation TL (1999-2003) 9 09-10-2015 10:27 AM
Cracked Transmission Casing quake97 Problems & Fixes 2 08-30-2015 08:57 PM
Tags
2003, 98, acura, add, brown, cl, cls, dipstick, fluid, oil, quantity, quarts, replacing, tl, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Acurazine.com content, comments, or advertising. Acurazine.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Acurazine.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
