2001 TL new fuel pump, gas comes out at pump and does seem to reach the front
Old 07-16-2015, 10:01 PM
Padre's Avatar
I have a 2001 acura TL 3.2 6. 14 years old 9,000 miles. Sat for ten years. Replaced battery, fuel pump. Fuel comes out of pump and doesn't seem to get to engine. Turns over won't start.
Old 07-16-2015, 10:03 PM
Padre's Avatar
checked for spark and have it. Confused.
Old 07-17-2015, 07:46 PM
01acls's Avatar
Try with starting fluid to see if it runs. My guess is your fuel tank is full of rust and it's clogging up the fuel lines... low fuel pressure. You might need to replace the fuel tank.
When you replaced the fuel pump did you inspect the tank?
Old 07-31-2015, 01:05 PM
Padre's Avatar
Yes, Inspected the tank and drained it and put new fuel in
Old 07-31-2015, 01:25 PM
01acls's Avatar
The only thing left is oxygen. Check the throttlebody, make sure the butterflies are not frozen.
Check the plugs see if its wet? If all plugs are wet then you have a spark problem.
Old 08-04-2015, 02:24 PM
mattcl-s's Avatar
get her fired up?
peti1212
ILX
22
01-05-2022 05:14 PM
PortlandRL
09-14-2015 12:01 PM
ninersfgiantsfan
09-09-2015 01:14 PM
08 NBP TL
09-08-2015 08:49 PM
NSolace
09-03-2015 08:14 PM
Quick Reply: 2001 TL new fuel pump, gas comes out at pump and does seem to reach the front
