i4 idle rpm, steering wheel vibrate when stop
Hi folks,
Something have been bugging me for a while (besides the transmission issues). When stop and in gear, the steering wheel vibrate a little more than i like. Not terribly bad, but very noticeable. My idle rpm when in gear (drive) is around 750-800. Is this normal?
I might try doing the idle learn procedure.. or bring it back to the dealer.
If the idle isn't bouncing around it shouldn't be an issue. 750-800 RPM seems right.
How many miles are on the car? What fuel are you using? The steering shouldn't be vibrating too much since it's not directly connected to the front of the car, it's electric steering.
Does putting the car in Neutral help? If yes, the motor/transmission mounts may be moving and causing some issues.
The normal RPM during idling, when it is fully warmed, is around 700 rpm without air-conditioning or 700-800 rpm with air-conditioning. So your car's rpm is right.
However, my one has the same issue that the car is vibrating some times.
Abt 8000 miles. Always been using 91 octane fuel. The idle is steady, ie not bouncing.
Yes, putting on neutral help.
Acura Parts @ AcuraAutomotiveParts.org - Genuine Acura OEM Parts from Acura Carland
For the OP, I would also think that engine/trans mounts might be at play.
jim256 (08-04-2015)
Hi folks,
The CR-V complaints were in the national news not long ago.
Owners of best-selling 2015 Honda CR-V complain of vibration problems | News, Weather, Sports, Breaking News | WJLA News
If putting in in Neutral helps, you can have acura look at the motor/trans mounts to neutralize them to help with vibration. Other than that the other posters are right about the torque converter, balance shafts, etc. Nothing will ever be a smooth as an inline 6 or V12.
my mistake!
On the side note, got a loaner 15 MDX. It's awesome! I am actually thinking of getting one next year, so this extended test drive is great.
16's got the new 9spd transmission and apparently has good reviews.
the 15's drives surprising well for such a large vehicle. i should go test drive the 16's. Its hard to convince myself to write a 50k check for any vehicle.
Back to my TLX. The dealership called and said they need a couple of days. The tech cannot find the source of the vibration and calling Acura for help. Looks like i'll have the MDX for few more days.
My car is still with the dealership after 2+ weeks. They replaced all the engine mount and the problem seems to be getting better but not completely fixed yet. I noticed that vibration is minimum when AC is OFF. When the AC compressor kicks in, the RPM barely move and the vibration starts. I tried other new TLX on the lot; the vibration increase when the AC load but its much less compared to my car.
Hope they can diagnose the problem soon.
I left a couple of messages, hopefully they will call back. If not, i'll go to the dealership in person and demand to speak to the manager in charged.
They haven;t called me for a week. Have been busy myself as well. Its been almost 4 weeks now my car is with the dealership. I need to start reading up on lemon law!
Yea it's annoying. After about a month with the car, I realized it's only noticeably bad with a cold start up in the morning or at the end of the workday after sitting for 9 hours. Once I drive it for a while it becomes more subtle... I'm still gonna bring it up to the dealer next time I'm in for service and see what they say.
