How to install cabin filter in 2012 Acura TL
Old 09-09-2012, 10:51 PM
slickjem's Avatar
1. Open the glove box. Remove the glove box separator (A) by carefully pulling it straight back.
2. Remove the dust and pollen filter assembly (A) from the blower unit.
3. Remove the filter (A) from the housing (B), and replace the filter.
4. Install the filter in the reverse order of removal. Make sure that there is no air leaking out of the blower unit.
The following 5 users liked this post by slickjem:
bobdgolfer (01-16-2013), fwood (06-08-2013), Peter Pytlik (04-15-2013), RCJr324 (03-24-2015), Vidol642 (06-08-2013)
Old 09-09-2012, 10:54 PM
6th Gear
chris275's Avatar
I don't see pictures if you were referring to (a) and (b) as them
Old 09-10-2012, 11:53 AM
slickjem's Avatar
Pictures did not copy, just follow written instructions, you will have no problem
The following 2 users liked this post by slickjem:
bobdgolfer (01-16-2013), BT8 (02-04-2013)
Old 01-16-2013, 12:02 PM
bobdgolfer's Avatar
Easier than I thought - Cabin Filter Install
You actually do not need pictures to install a new cabin filter into the 2012 Acura TL. You just pull out the glove box divider ( the shelf in the glove box), and the filter presents itself for removal. I was quoted a price of $90 to have the dealer do the job - I bought an OEM filter from a Boston dealer (Bernardi ACURA Parts) for $26.63 and installed it in about five minutes. The hardest part of the job was emptying the glove box. Thank you slickjem.
BT8 (02-04-2013)
Old 01-16-2013, 10:46 PM
SteveBobo's Avatar
https://acurazine.com/forums/showthr...ight=cabin+air
Same as the 12
Old 06-08-2013, 07:46 PM
6th Gear
fwood's Avatar
They sould be so ashamed to charge for this.
Old 06-08-2013, 07:47 PM
6th Gear
fwood's Avatar
They should be so ashamed to charge for this.
Old 07-13-2013, 11:23 AM
4th Gear
todd-tl-12's Avatar
Pohanka Acura in VA wants $174.95 to replace the air filter and cabin filter. I'll just do it myself. Thanks for the post.
Old 07-26-2013, 06:37 PM
05RL in NH's Avatar
Brand?
What brand of cabin filter does everyone recommend?
OEM?
Other?
And why.
Old 07-28-2013, 03:34 PM
vinnier6's Avatar
i bought a new cabin air filter at autozone for 12 bucks....
Old 03-24-2015, 03:06 PM
5th Gear
Lucky7uciano's Avatar
Why did I do this at the dealership smh
So I just paid 150 to replace the cabin air filter and the engine filter at my dealership smh...I could of done it myself -___-
Old 03-29-2015, 01:34 PM
Reorge's Avatar
I generally use OEM parts for everything but not in this case. The Acura/Honda cabin filter is toooooo expensive ($38+ list, $26+ via online). My recommendation is Purolator for about half the price at local stores. But the cabin filter is not a critical item so I assume any brand will do.
Old 04-01-2015, 08:13 AM
SilverJ's Avatar
I used the Purolator one for about 15.00. You need to give a good pull to get the glove box separator out, just make sure you pull it straight out.
02-25-2020 09:57 AM
nanos
11-12-2015 08:41 PM
Nitin
09-30-2015 08:22 PM
kuzdu
09-10-2015 08:42 PM
Aleax
09-09-2015 08:04 PM
Quick Reply: How to install cabin filter in 2012 Acura TL
