How to install cabin filter in 2012 Acura TL
1. Open the glove box. Remove the glove box separator (A) by carefully pulling it straight back.
2. Remove the dust and pollen filter assembly (A) from the blower unit.
3. Remove the filter (A) from the housing (B), and replace the filter.
4. Install the filter in the reverse order of removal. Make sure that there is no air leaking out of the blower unit.
The following 5 users liked this post by slickjem:
bobdgolfer (01-16-2013),
fwood (06-08-2013),
Peter Pytlik (04-15-2013),
RCJr324 (03-24-2015),
Vidol642 (06-08-2013)
The following 2 users liked this post by slickjem:
BT8 (02-04-2013)
Easier than I thought - Cabin Filter Install
You actually do not need pictures to install a new cabin filter into the 2012 Acura TL. You just pull out the glove box divider ( the shelf in the glove box), and the filter presents itself for removal. I was quoted a price of $90 to have the dealer do the job - I bought an OEM filter from a Boston dealer (Bernardi ACURA Parts) for $26.63 and installed it in about five minutes. The hardest part of the job was emptying the glove box. Thank you slickjem.
BT8 (02-04-2013)
I generally use OEM parts for everything but not in this case. The Acura/Honda cabin filter is toooooo expensive ($38+ list, $26+ via online). My recommendation is Purolator for about half the price at local stores. But the cabin filter is not a critical item so I assume any brand will do.
nanos
11-12-2015 08:41 PM
Nitin
09-30-2015 08:22 PM
