09 TL-SH overheating when idle
Old 09-23-2015, 01:57 PM
6th Gear
mdlex389's Avatar
anyone else have experience with the car over heating when idle? this only happens when i am sitting idle in traffic for over 5 minutes but the car cools down once i start moving.
thank you.
Old 09-23-2015, 02:04 PM
Received 16,260 Likes on 11,971 Posts
When was the last time you checked the coolant reservoir?
is the coolant reservoir to the fill line?
last time you changed the coolant?
how many miles on the car? if over 100k miles, have you changed the timing belt and water pump?
Old 09-23-2015, 03:16 PM
fsures's Avatar
Are the fans running when the engine is overheating?
Old 09-23-2015, 03:18 PM
Received 8,568 Likes on 6,621 Posts
Sounds like your fans may not be kicking on... check the fan, the relays, etc..
check coolant as well but if it cools down when moving, I think the fans are the culprit.
Old 09-23-2015, 04:17 PM
Stay Out Of the Left Lane
NBP04TL4ME's Avatar
Received 1,236 Likes on 1,023 Posts
Check fans and coolant as mentioned above.
Old 09-23-2015, 08:16 PM
'20 TLX SH-AWD A-Spec
Tonyware's Avatar
Check thermostat too. Actually not easy to "check", you might as well replace it.
Engine coolant when spilled leaves behind some big green stains. Look under the car where you usually park for stains, also around the engine bay.
(if the fans fail for whatever reason, the engine light will turn on, so chances are its not the fans but the coolant/thermostat)
Old 09-24-2015, 09:10 AM
i'm interested in what the cause was.
OP come back!
Old 09-27-2015, 03:25 AM
BigTzzy's Avatar
I had the same issue on my 1999 TL. I fixed it by cleaning in between the radiator and the condenser coil. There was a build up of dirt and debris that got stuck in there. I couldn't see it until I removed the radiator.
I hope this helps.
Old 09-27-2015, 10:37 PM
Reorge's Avatar
H/A OEM coolant is blue so you could have either color if a leak is present.
Old 09-28-2015, 06:29 PM
Tonyware's Avatar
I kinda see green white-ish stains. Almost like the rust color on old copper.
DerrickW
11-15-2015 05:52 PM
012TL-GLM
10-05-2015 06:32 AM
Skirmich
10-01-2015 12:59 PM
prbori
09-27-2015 01:37 AM
TL14
09-24-2015 04:37 PM
Quick Reply: 09 TL-SH overheating when idle
