VSA message 134
Old 06-09-2012, 09:49 AM
gmansr's Avatar
VSA message 134
2010 RDX w/nav. I'm getting a VSA 134 diagnostic message on my nav display even though the VSA is working properly (I think). How do you clear that message?
Old 06-09-2012, 03:46 PM
DRR98's Avatar
Best to learn what set this code. If you are into working on your own car then slide under and inspect everything related to the VSA system. Halifax sensors, wiring, etc. If nothing obvious is found, use your warranty. I could not find any reference for DTC- VSA 134. Someone with a service manual will be able to look up the code.
Old 06-14-2012, 07:03 PM
gmansr's Avatar
Thanx for taking the time to reply, I was able to find the reset answer on the forum. I bought the RDX used (33,000 mi) from my daughter , I didn't think it was covered under warranty that's why I was searching the forum.
Old 06-15-2012, 06:59 AM
DRR98's Avatar
So she has 33k mi on a '10?
Clearing the code was/is not the most important issue.
The questions you need to ask are...
Warranty covers until xxxx mi and xxxx date?
What is vsa 134 code?
What caused code?
Is the vsa fully functional now?
Does the code require anything to be replaced or repaired?
Old 05-08-2019, 12:12 PM
wusty23jd's Avatar
I'm bumping an old thread here, because my wife's 2007 Acura RDX also recently threw a VSA 134 code. I'm not exactly sure what this relates to, but I will keep digging into it.
Old 05-09-2019, 01:01 AM
CSmoney28
CSmoney28's Avatar
Did you reset the vehicle by disconnecting the battery and putting it back to see if it comes back...?
Old 05-09-2019, 11:47 AM
Tomtwtwtw's Avatar
The most common suggestion out there appears to be a speed sensor issue, but that's far from the only possibility. I'd recommend a proper diagnosis from a mechanic, otherwise you may just be throwing random parts at it without knowing the true cause.
Old 05-10-2019, 08:24 PM
CSmoney28
CSmoney28's Avatar
If you’re Acura dealership does free diagnostic why not ...
Jamus22
06-11-2023 10:08 AM
copmagnet82
4G TL Problems & Fixes
06-29-2016 08:09 AM
MilanoRedDashR
10-02-2015 10:49 AM
polish_pat
09-30-2015 12:22 PM
rockyboy
09-25-2015 10:44 AM
Quick Reply: VSA message 134
