Drl hid problem
Drl hid problem
Ok so I got a ballast, anti flicker and bulbs.... Install them when DRL are on they turn on for a sec then turn off but when I put the hi beams on no problem... I've tried switching the plugs every which way I ordered a relay harness will that fix it or m I missing something else ?
The DRL is designed to operate the incandescent high beam bulbs at half intensity (Not sure of the exact mechanism used to accomplish this - either electronically modulating the 12 Volt DC or putting the bulbs in series. So HID will not work as DRL in this setup, unless of course you modify things.
ulrblitzer (08-14-2015)
<p>
</p><p><img alt="Werd" src="https://acurazine.com/forums/images/smilies/werd.gif" style="height:46px; width:44px" title="Werd" /></p>
<p></p><p> </p><p>Sorry I should've been more clear, LOL.</p><p> </p><p>I don't have VLEDS bulbs - just these modules, which run your DRL's at 12V constant, so you can use HID's as DRL.</p><p> </p><p><img src="http://cimg9.ibsrv.net/gimg/acurazine.com-vbulletin/600x600/80-undefined_f3bf70896f6676908ecbae138187ab34c65edfde .png" title="" /><br /><br /> </p>
xtcnrice (08-16-2015)
SidhuSaaB
05-30-2020 12:40 AM
AmplifiedDetails
09-24-2015 02:55 PM
4drviper
09-23-2015 09:00 PM
