TSX Navigation/Audio Codes - AcuraZine Community
Go Back   AcuraZine Community > AcuraZine TSX Community > First Generation TSX Discussion (2004-2008) > Problems & Fixes
Log In
LinkBack Thread Tools Search this Thread
Old 12-14-2006, 06:00 PM   #1
Registered Member
Trader Rating: (0)
Hello
I was abel to enter the Navigation code in our 2004 TSX however I can NOT get to a screen that allows me to enter the AUDIO code.Once the navigation code is entered the map comes up and I can NOT find a way to get any audio screens.Any help you can offer will be greatly apreciated!
Thank you
Christian
schulze is offline   Reply With Quote
Old 12-14-2006, 06:15 PM   #2
Registered Member
jmathew34's Avatar
Trader Rating: (0)
try and press the am/fm button and see if that works...
jmathew34 is offline   Reply With Quote
Old 12-15-2006, 10:08 AM   #3
Reach's Avatar
Trader Rating: (0)
You enter the audio code by rotating the station select knob to select a number (the right one, not the volume one) and then depress it to enter the number you've selected.
Reach is offline   Reply With Quote
Old 12-15-2006, 11:45 AM   #4
Registered Member
Trader Rating: (0)
TSX Codes
Hello
Thank you for the replys.I tried the AM/FM button Nothing.I can NOT get a screen that will even allow me to put the code in. The screen is the map or BLANK.Thank you!
Old 12-15-2006, 03:28 PM   #5
Summer is Coming
Rocket_man's Avatar
Trader Rating: (0)
From the Owners Manual
"If your vehicle’s battery is disconnected or goes dead, the audio system will disable itself. If this happens, you will see ‘‘CODE’’ in the frequency display the next time you turn on the system. Use the preset buttons (icons on vehicles with
navigation system) to enter the fivedigit code. The code is on the radio code card included in your owner’s manual kit. When it is entered correctly, the radio will start playing. If you make a mistake entering the code, do not start over; complete the five-digit sequence, then enter the correct code. You have 10 tries to
enter the correct code. If you are unsuccessful in 10 attempts, you must then leave the system on for 1 hour before trying again. If the code card is lost, a dealer can access your code with your radio’s serial number. To access the serial number, turn the radio on. It must display ‘‘CODE’’, then turn the radio off. Push the preset 1, preset 6, and power buttons at the same time, then quickly release.
You will have to store your favorite stations on each side of the preset buttons (1 6) after the system begins working. Your original settings were lost when power was disconnected."
You can power off the system by pulling the #7 (10A) fuse in the under-dash box and start over again. If the power was off long enough it may take some time for the GPS system to initialize.
Rocket_man is offline   Reply With Quote
Old 12-15-2006, 11:30 PM   #6
Reach's Avatar
Trader Rating: (0)
Quote:
Originally Posted by schulze
Hello
Its not on your nav screen. Its above it, where the clock / temp display is.
Old 12-19-2006, 05:09 PM   #7
Registered Member
Trader Rating: (0)
Thank you!!
Hello
Thank you for that info! The lights do NOT work around the clock so I didnt even think to look there! I was abel to use a flashlight and enter the code and all is well! Right now Im waiting for a letter from the original owner to transfer the Acura Certifed 100K warrentty. Honda /Acura Of America make you fight for that! I was abel to get the original owners info from USER 1 of the Navigation system.Hoping taht goes well so we can get the light problem fixed.Anyways THANK YOU again for ALL of the info above!
Christian
Old 12-16-2010, 01:03 AM   #8
New Member
Trader Rating: (0)
Hello.
I am glad to join you. I bought Acura TSX 2004. I have a problem with navigation code and radio code. I am from Belarus and there are not present Acura's diller. Please help to receive this codes. VIN JH4CL96934CO29171. code U1000, L3398.
If someone would be so kind as to send this to my email DrozdovAM@yandex.ru I would be extremely greatful. From me Russian beer.
Los Che is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
My personal comparison between 3g TL and TLX (mostly negative side) mlody Fifth Generation TLX (2015+) 66 02-01-2016 10:26 AM
J32A2 swap info needed TypeS860 Second Generation TL (1999-2003) 32 01-13-2016 06:35 PM
Error codes stored in messages MilanoRedDashR Problems & Fixes 2 10-02-2015 11:49 AM
P1457 = A gently Reminder to Check your Gas Cap Skirmich Second Generation TL (1999-2003) 4 10-01-2015 01:59 PM
2008 acura TL P0847 code and blinking D Mike Pilipenko Problems & Fixes 3 09-27-2015 06:10 PM
Tags
2004, acura, buttons, card, code, enter, lost, navi, navigation, number, preset, radio, serial, system, tsx
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Acurazine.com content, comments, or advertising. Acurazine.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Acurazine.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
