Tensioner Pulley Bounce - AcuraZine Community
Go Back   AcuraZine Community > AcuraZine TSX Community > First Generation TSX Discussion (2004-2008) > Problems & Fixes
Log In
LinkBack Thread Tools Search this Thread
Old 10-17-2011, 12:04 AM   #1
Registered Member
Trader Rating: (0)
I hear some noise under the hood when I accelerate. It's like a faint whirring/chirp.
Can't really tell where it's coming from if I look under the hood. It happens when driving as well as when I rev the engine in neutral.
Looking at it I can't tell where the noise is coming from, but I do see the tensioner pulley bouncing around. Is this bad? Could it be the cause?
Pokerpot is offline   Reply With Quote
Old 10-17-2011, 12:51 AM   #2
Registered Member
PACman's Avatar
Trader Rating: (0)
How many miles do you have?
PACman is offline   Reply With Quote
Old 10-17-2011, 05:30 AM   #3
Registered Member
Trader Rating: (0)
Quote:
78,000 on a 2006.
Old 10-17-2011, 11:56 AM   #4
Registered Member
PACman's Avatar
Trader Rating: (0)
The auto-tensioner pulley shouldn't be bouncing around at idle when you're looking at it.
Check the drive belt to make sure the tension is within spec. The owner's manual has the information on how to do this. Also consider having someone in the car rev the engine in park or Neutral (hand brake applied) while you try to isolate the sound under the hood.
Old 10-17-2011, 12:31 PM   #5
Registered Member
Trader Rating: (0)
Thanks PAC.
Had someone rev it and still couldn't isolate the sound. It's really faint in the cabin but it's high pitched so it drives me crazy. I'm going to just order a new tensioner and belt I think.
I'm just wondering if perhaps that will fix it or if it's the water pump? It sounds kind of like the loud fuel pump on my civic back in the day.
Old 10-17-2011, 03:10 PM   #6
Registered Member
Trader Rating: (0)
Hey, I uploaded a video with the sound...can hear the whine the best at about 12 seconds on. It's hard to hear but it's there if you strain
Thanks for checking it out - appreciate the help.
Old 10-17-2011, 03:11 PM   #7
Registered Member
Trader Rating: (0)
Tried to edit the previous post, couldn't figure it out... here is a working link.
http://www.youtube.com/watch?v=6vXlnrh1-zw
Old 10-17-2011, 07:14 PM   #8
Registered Member
Trader Rating: (0)
Video of the pulley bounce. Of course when I go to film it it's being pretty tame, but it was bouncing quite a bit more the other day.
http://www.youtube.com/watch?v=VjaRMuzUas0
Old 10-17-2011, 08:18 PM   #9
Registered Member
Trader Rating: (0)
If I picked the right sound out of your video, then it is very close to what I'm having right now. If it it the case, then here are some bad news: the sound is still there even in case driving belt is out (you can easily test it), so I assume it is either transmission, or timing chain related.
Karlo is offline   Reply With Quote
Old 10-17-2011, 08:41 PM   #10
Registered Member
Trader Rating: (0)
Karlo, mine makes the noise even in neutral and it does sound like it's coming from the drive belt side of the engine.
I'll try this weekend to take the drive belt off.
Old 10-17-2011, 10:34 PM   #11
Registered Member
Trader Rating: (0)
Mine is the same: RPM dependent noise even in neutral and park. Chain is the same side, under the cover
Old 10-22-2011, 02:45 PM   #12
Registered Member
Trader Rating: (0)
guys have you had a valve adjustment yet might be worth haven done plus you can examine the chain at the same time.
nigelboyne is offline   Reply With Quote
The Following User Says Thank You to nigelboyne For This Useful Post:
Karlo (10-25-2011)
Similar Threads
Thread Thread Starter Forum Replies Last Post
FS: BNIB AEM 30-3000 Methanol Injection, 3G TL Accord Inspire Fog Lights,3G Tensioner InFaMouSLink Car Parts for Sale 7 10-27-2015 07:51 PM
FS: 2003 Acura CL-S 6MT ABP ★★Location of Vehicle : Edmonton, AB, Canada★★ rp_guy Member Cars for Sale 1 10-22-2015 03:58 PM
SRS after collision brboy Second Generation RL (2005-2012) 5 10-05-2015 12:34 PM
Tracking down the goddamn engine whining noise. iCrap Second Generation TSX Discussion (2009+) 20 09-11-2015 07:21 PM
Tags
2004, acura, acurazine, alittle, bad, belt, bouces, bounce, bounces, bouncing, idler, pulley, tensioner, tl, tsx
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Acurazine.com content, comments, or advertising. Acurazine.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Acurazine.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
