Radio Error Code E - AcuraZine Community
Go Back   AcuraZine Community > AcuraZine TSX Community > First Generation TSX Discussion (2004-2008) > Problems & Fixes
Log In
Radio Error Code E
LinkBack Thread Tools Search this Thread
Old 02-14-2009, 07:23 PM   #1
Registered Member
Trader Rating: (0)
Radio Error Code E
My battery was dead this morning due to me leaving the interior lights on all night. I now have an error code on the radio display. I mistakingly tried entering the navigation code instead of the audio code. Now I have an error code E and I can no longer enter a valid number.
Any suggestions on how to reset this?
I've seen the methods for other makes by removing the Backup fuse but this has not worked for me. I also do not have preset buttons so using that method to retrieve the serial will not work.
Does anyone have any information pertaining to the 2004 TSX that will help me fix this issue.
reaser is offline   Reply With Quote
Old 02-14-2009, 07:29 PM   #2
Need more room in
wong05tsx's Avatar
Trader Rating: (6)
wong_johnny
Have you tried disconnecting your battery ground, maybe it'll reset it again.
I'm guessing that "E" error is for preventive measures in event that your yeetie gets stolen (Locked).
If that doesn't work, your best bet is to bring your car to the dealership, tell them what happened, and they should be able to unlock it for you
__________________
http://distinctivdetailing.com
wong05tsx is offline   Reply With Quote
Old 02-14-2009, 08:34 PM   #3
Looking at the '15 TLX
Stevestr's Avatar
Trader Rating: (0)
You have entered the radio code incorrectly too many times and the head unit is now locked.
You can either a) leave the key in the "ACC" position with the head unit ON for one hour and COdE will appear on the display allowing you to re-enter the code or b) disconnect the battery for a few moments (making sure all electronics inside the care are OFF first) and then trying to reconnect.
I believe Honda has gone to a web retrieval for unlock codes now. If you don't have the serial number to the unit then there is a modified 1 & 6 technique for units with navi (using different key combinations). I used to know it by heart (I worked on the Honda side for a while) but I have forgotten it. Acura Client Services can walk you through the retrieval process but there is a way electronically to get the number from the radio.
Otherwise, look in the glove box for a small white sticker with a long number on it. This will be the serial for the radio. With the serial you can call Acura Client Services and they should have the unlock code. The sticker may also be in the center bin.
Good luck and WRITE THE NUMBERS DOWN!
__________________
2004 Carbon Gray/Ebony TSX A5 Auto w/Navi * 131,000 miles and goin' strong! * One of the first 5000 made - Assembled Apr 2003 - VIN 004654 - Home Jul 03! - I miss California!
Current Ride: 2011 Golf TDI
Future: Acura TLX?
Stevestr is offline   Reply With Quote
Old 02-16-2009, 07:14 PM   #4
Registered Member
Trader Rating: (0)
Ok I got the code reset. I have no tape deck so how do I get my serial code without taking out the radio.
Similar Threads
Thread Thread Starter Forum Replies Last Post
Help Please!!! ABS and VSA light with exclamation point ALL ON Jamus22 Problems & Fixes 15 12-14-2015 04:46 PM
Retrieve Unlock Codes for Radio and Navigation Devices dirleton Second Generation RDX (2013+) 8 09-28-2015 05:48 PM
Misfire DTC and TSB 03-033 question thegipper Third Generation TL (2004-2008) 5 09-28-2015 02:01 PM
EGR Valve /Extended emissions warranty shawnafoxx First Generation RL (1996-2004) 2 09-28-2015 01:33 PM
Audio problem Matthew Purpura First Generation CL Discussion (1997-1999) 3 09-25-2015 07:10 PM
Tags
2005, 2007, 2009, acura, code, e, error, fix, honda, leave, number, radio, reset, rl, serial, tsx
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Acurazine.com content, comments, or advertising. Acurazine.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Acurazine.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
