Help with P0420 code - AcuraZine Community
Go Back   AcuraZine Community > AcuraZine TSX Community > First Generation TSX Discussion (2004-2008) > Problems & Fixes
Log In
LinkBack Thread Tools Search this Thread
Old 01-27-2011, 01:54 PM   #1
Registered Member
Trader Rating: (0)
I just got the P0420 code meaning I need a new catalytic converter and/or O2 sensor. What should I replace first? The o2 sensors or cat? I was wondering if I should go with the aftermarket cat or OEM cat? Also where do you guys recommend I buy the parts from?
Thanks!
kmk42019 is offline   Reply With Quote
Old 01-29-2011, 02:44 AM   #2
Registered Member
Trader Rating: (0)
OEM cat or high flow? How many miles on the car?
Aftermarket High Flow cats will eventually trigger the code you are experiencing...
If you indeed have the original cat on the car, here would be the order I would proceed in:
1) Clear code from ECU with an OBDII scanner and see if it returns... if you can put a few thousand miles on the car without the code returning, it was likely just a hicup in the ECU (happens occasionally).
2) If you tried step 1 and code returns, I would then replace the secondary O2 sensor
3) If steps 1 & 2 dont work, then replace the cat. Aftermarket High Flow cats will give you some added power (especially on an 04-05), but get ready to live with the light coming on. The defouler trick does not seem to work all that well on the TSX. If you have an 04-05, you can get an OEM cat from an 06-08 which should free up a bit of power without the issues of triggering the light. If you have an 06-08, replace with OEM as it already flows pretty well...
Kris05TSX is offline   Reply With Quote
Old 01-29-2011, 07:33 PM   #3
still plays with cars
Trader Rating: (0)
How many miles on the vehicle? Emissions system warrantee is 8/80,000 I think.
Check your owner's manual to make sure.
__________________
Gort! Klaatu barada niktu!
nbtx is offline   Reply With Quote
Old 01-30-2011, 11:41 AM   #4
in the 24th and a half...
DuckDodgers's Avatar
Trader Rating: (0)
Poor fuel quality is the most common cause of this DTC. Note that P0420 does NOT indicate a bad O2 sensor, that is a different code. P0420 is simply the system running below a threshold that the system monitors.
DuckDodgers is offline   Reply With Quote
Old 01-30-2011, 12:12 PM   #5
Registered Member
Trader Rating: (0)
Quote:
Thanks!
mate try add a fuel injector cleaner and fill up with high octane fuel and dissconnect the battery and try a spirtive drive id say that should sort it.
nigelboyne is offline   Reply With Quote
Old 01-30-2011, 03:05 PM   #6
Registered Member
Trader Rating: (0)
My 04 Tsx has 135,000 miles on it. I treated the engine with some seafoam and reset the code and so far it hasnt come back on.
Old 02-01-2011, 04:24 PM   #7
Registered Member
Trader Rating: (0)
a lot cheaper then replacing cat converter and sensors, well done
Old 02-01-2011, 07:21 PM   #8
Registered Member
clutchlucky's Avatar
Trader Rating: (0)
I have an 04 tsx and when I had 103k my cat was out.... which was 3 days after I bought the car. That was $800 down the drain... I bought it wholesale though from my work.
clutchlucky is offline   Reply With Quote
Old 02-03-2011, 03:20 PM   #9
Registered Member
Trader Rating: (0)
Just came back on again. Looks like I need to replace that cat. Is it necessary to replace the O2 sensors too? Im kinda on a tight budget here.
Old 02-03-2011, 03:50 PM   #10
Someone stole "My Garage"
curls's Avatar
Trader Rating: (0)
I would start by trying new O2 sensors, or at least a pair from a known-good TSX if possible. If they still produce a code, then replace the cat and leave the sensors alone.
__________________
2004 TSX, PWP on Ebony, 6MT, #00032. 2006 short block put in at 92,000km --> warranties are a good thing!.
Hondata, Tein, Koni, Injen, Unorthodox Racing, Comptech, Powerstop, FLP Maven, Japspeed.
curls is offline   Reply With Quote
Old 02-03-2011, 03:57 PM   #11
Registered Member
Trader Rating: (0)
I dont know where I could get my hands on some O2 sensors without buying them new and they are quite expensive also. Hmm?
Old 02-04-2011, 10:16 AM   #12
curls's Avatar
Trader Rating: (0)
Have you tried top-tier fuel (from a near-empty tank), 91-octane? If after a full tank of that, the light still comes on after being reset, then look into a fuel injector cleaner as someone mentioned above.
If that still causes the light to come on, then the P0420 code should be taken as "legit" and you need to action accordingly. If it's "catalyst below threshold" then replace the catalytic converter.
__________________
Old 02-04-2011, 03:14 PM   #13
Registered Member
Trader Rating: (0)
I have had it come on twice so it must be legit. Here is the print out I got from Autozone.
Catalyst system efficiency below threshold bank 1
Probable cause
1. A/F ratio concern
2. Air leak near H02S(heated oxygen sensor) Bank 1
3. Ignition system concern
4. Faulty Catalytic converter
You think I just need a new Cat? Where do you buy parts from? Easy DIY install?
Old 02-04-2011, 11:49 PM   #14
Trader Rating: (0)
Dude, listen to what the printout is saying...A/F ratio concern is very likely to be fuel related.
1) Find a top tier station (list above) and a bottle of Techron Fuel System Cleaner.
2) Run tank to as empty as you feel comfortable (preferably need at least 15 gallons to fill-up.
3) Toss the cleaner in and fill up with PREMIUM gas.
4) Run car until nearly empty again.
5) Repeat at least the fill-up (Top tier PREMIUM)...more techron if you like, won't hurt.
6) Run it nearly empty again and fill-up again (Top tier, PREMIUM).
7) Reset CEL.
8) CEL resets, then you look at the air leak issue (should be noticable to the ear if you can check the vehicle from below safely at idle)...the ignition issue...and then the cat. A faultly O2 sensor (rather than an air leak) should return a different code.
Old 02-05-2011, 11:14 AM   #15
Registered Member
Trader Rating: (0)
91 octane is that the highest you can get, if so that is were your problem is you need at least 95octane in these honda/acura engines i run 99octane all the time thats the highest in ireland, germany you can get 104octane.
Old 02-05-2011, 11:01 PM   #16
Trader Rating: (0)
Nigel, it depends what method of calculating the octane the country uses.
In the USA, 91 octane is the Honda/Acura recommendation for the TSX. The US uses the AKI (or (R+M)/2) method of figuring octane (as does Canada). Europe uses just the RON number.
The 91 AKI is equivalent to a 95 RON European fuel...the 93 octane available in some parts of the US is like 98 RON fuel.
Old 02-08-2011, 09:40 PM   #17
Registered Member
Trader Rating: (0)
Just put some techron in and a full tank of BP 93 octane. Reset the light. Ill let ya know what happens.
Old 02-12-2011, 10:28 PM   #18
Registered Member
Trader Rating: (0)
i had the same code on my '02 nissan sentra Se-R a week ago. After trying to fix it cheaply costed me a motor. Now i have an '06 TSX. My cat was clogged and broken to peices because of that it clogged my second cat. By the time i fixed the first cat and drove to the mechani to fix my second cat, there was to much back pressure and my piston rings failed. Then the car was allowing oil in the cylinders and it was getting burned. Take it to a mechanic get a cat and make sure there isnt anything else clogged further down the exhaust line. It might cost you a motor going the cheap route. hope this helps!
jason1245 is offline   Reply With Quote
Old 02-14-2011, 09:32 PM   #19
Trader Rating: (0)
Jason, the issue is that this code is very common from poor fuel...
Old 02-21-2011, 11:08 PM   #20
Registered Member
Trader Rating: (0)
its been over 700 miles since I poured techron fuel cleaner in and filled up with 93 octane and still havent had the engine light come back on. How many more miles until I am in the clear?
Old 02-21-2011, 11:23 PM   #21
Trader Rating: (0)
I'd say that's "intermittent" and you found the problem. Now just avoid the cheap gas and use Techron about every oil change and it should help keep it away.
Old 03-07-2011, 03:15 PM   #22
Registered Member
Trader Rating: (0)
UPDATE
Driving to work this morning the light came back. I had put about 1300 miles on it before the light flashed back...
Old 03-07-2011, 10:33 PM   #23
Trader Rating: (0)
OK...what gas is in the car? If it's an off or unknown brand:
Run the tank low, refill with known good gas and reset...reset if it comes back before you've run the good tank out...then refill with good and see what happens...
If it stays off, you might have bad gas shopping habits...comes back on then try looking at the ignition for a possible fault...then it's cat time...
Old 03-08-2011, 03:30 PM   #24
Registered Member
Trader Rating: (0)
thanks duck. It went back off on my way home this evening...weird.
Old 03-08-2011, 09:40 PM   #25
Trader Rating: (0)
Nah, with a fault like that, if the performance is borderline you can certainly get that kind of issue. Try taking a look at your ignition wires when you have a little time, just in case.
Similar Threads
Thread Thread Starter Forum Replies Last Post
Help Please!!! ABS and VSA light with exclamation point ALL ON Jamus22 Problems & Fixes 18 02-07-2016 07:08 PM
Error codes stored in messages MilanoRedDashR Problems & Fixes 2 10-02-2015 11:49 AM
Misfire DTC and TSB 03-033 question thegipper Third Generation TL (2004-2008) 5 09-28-2015 02:01 PM
EGR Valve /Extended emissions warranty shawnafoxx First Generation RL (1996-2004) 2 09-28-2015 01:33 PM
Check Engine Light and P0683 Code mars First Generation TSX Discussion (2004-2008) 1 09-28-2015 12:03 PM
Tags
0420, 2005, acura, aftermarket, cleaner, clear, code, converter, flow, fuel, gas, high, higher, injector, octane, p0420, po420, quality, spec, tsx
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Acurazine.com content, comments, or advertising. Acurazine.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Acurazine.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
