Headlight HID Prob. - Turns on, Flickers, Then Dies. - AcuraZine Community
Go Back   AcuraZine Community > AcuraZine TSX Community > First Generation TSX Discussion (2004-2008) > Problems & Fixes
Log In
LinkBack Thread Tools Search this Thread
Old 01-27-2011, 04:15 PM   #1
Registered Member
Trader Rating: (0)
So I have a problem with my 04 TSX. I recently just replaced the HIDs on my low beams and everything went fine. When I tested the HIDs, the bulbs would turn on and be fine for like 10 seconds, then start to flicker (sometimes one would flicker first then the other or sometimes both start to flicker at the same time), and then would die in less than a minute. It happens to both sides and both would eventually die out. Does anyone know what could be wrong with the setup I have? I bought HID bulbs from hidextra.com. Any input would be appreciated. Thanks.
honda_nerd is offline   Reply With Quote
Old 01-27-2011, 05:47 PM   #2
CGP Ebony
xenonhid's Avatar
Trader Rating: (0)
What happens if you put in the OEM HID bulbs back? If the oem ones work fine, then you can deduce its the aftermarket hid bulbs as the issue.
__________________
05 CGP Ebony [Pioneer Avic Z3 Navi w/ Bluetooth + MP3 AUX]
xenonhid is offline   Reply With Quote
Old 01-29-2011, 05:42 PM   #3
Registered Member
Trader Rating: (0)
My oem HIDs went out, that's the only reason I am getting another set. Any other ideas?
Old 01-29-2011, 08:07 PM   #4
Registered Member
Trader Rating: (0)
Are the low and high headlight relays identical relays?
If they are identical, switch them. Then see if the low beam lights stay on and the high beams quit when turned on?
PaHonda is offline   Reply With Quote
Old 02-05-2011, 01:48 PM   #5
Registered Member
Trader Rating: (0)
Some people replace their fuse with a higher amperage when they have this problem with HIDextra kits, i returned the ballasts under warranty and they sent me a new ones promptly. Good customer service but product quality may need improvement a bit
dreloc is offline   Reply With Quote
Old 02-10-2011, 01:17 PM   #6
Registered Member
Trader Rating: (0)
This problem can be caused by the relay, or the ballast. Changing the fuse won't have effect except if the fuse is burning. (by the way I don't recommand to change the fuse for a bigger one)
Did u buy the same voltage and wattage as oem ?
If your light flicks, it's because it doesn't have enough power to the light.
ziboy is offline   Reply With Quote
Old 02-12-2011, 07:50 PM   #7
Registered Member
Trader Rating: (0)
to me it sounds like the ballasts
arahim32 is offline   Reply With Quote
Old 02-14-2011, 07:28 AM   #8
Registered Member
Trader Rating: (0)
i am having the same problem.. OP did you fix your problem... mine only happens on the driver side.. i have 6000K and they worked great upon until recently. the passenger which has a 6000K doesnt give a problem so i dont believe its the bulb
cassinova73 is offline   Reply With Quote
Old 02-15-2011, 09:07 PM   #9
New Member
Trader Rating: (0)
New Ballaster and Ignitor
I just took my 04 TSX to the dealership for the fix on the high pressure power steering hose and had them also look at my HID Low Beams because i'm having pretty much the same issue. My passanger side light might come on might not, most of the time my driver side does come on, but if I turn the lights off for 10 sec and then back on, none of them work. After 90.00 to have them test to see if it's the bulbs, they gave me a quote 1,200.00 for two new ballaster's and ignitors, plus 200.00 per bulb, for a total of ~1,600. So when I got home I went to e-bay and found a seller with new ballasters and ignators for 198.00 each, so needless to say i'm going that route and from my readings it fairily easy to take the front bumper off and take out the headlights to get to the ballaster.
http://cgi.ebay.com/ebaymotors/ws/eB...m=250772589481
Chris M is offline   Reply With Quote
Old 03-09-2011, 12:52 PM   #10
Registered Member
CometVR4's Avatar
Trader Rating: (0)
Quote:
That's your problem, I purchased bulbs from there too for my TL. Right away both bulbs started flickering when I switched them on. I quickly put in Morimoto from theretrofitsource.com before it killed my ballast and they worked perfect. I 100% positive it's the bulbs. I think they got a bad batch or something. There are several members on clublexus forums that are having same problem with OEM replacements as well.
__________________
'04 Acura TL Navi SSM 5AT
'98 Mitsubishi 3000GT VR-4 6spd
'07 Kawasaki Ninja ZX-14
CometVR4 is offline   Reply With Quote
Old 03-14-2011, 11:32 AM   #11
Registered Member
Trader Rating: (0)
Just wondering what you did to fix this. My new HID's are doing the same thing.
dalco2208 is offline   Reply With Quote
Old 04-04-2011, 12:42 AM   #12
Registered Member
Trader Rating: (0)
Hello, anybody remedy this problem. i purchased D2S 6000k bulbs from HIDExtra and i'm having the same issues with the bulbs flickering on both sides within a minute. I've emailed them many times and they keep referring me to there FAQ's on there website. I could understand if i bought a kit from them, but this is just a bulb replacement. I've reinstalled my OEM bulbs and no problems what so ever with flickering. Hopefully they replace my bulbs or refund my money.
BERTSX is offline   Reply With Quote
Old 04-12-2011, 02:06 PM   #13
Registered Member
PACman's Avatar
Trader Rating: (0)
Quote:
Originally Posted by Chris M View Post
Any feedback on how these are? I'm in the same situation, but can't afford to get these parts from the dealer.
PACman is offline   Reply With Quote
Old 05-06-2011, 09:29 AM   #14
New Member
Trader Rating: (0)
Quote:
PACman, i've had these in my car for that past 4+ months and have had no problems.
Old 05-06-2011, 07:14 PM   #15
Registered Member
PACman's Avatar
Trader Rating: (0)
Thanks!
Old 05-22-2011, 01:35 PM   #16
Registered Member
Quest227's Avatar
Trader Rating: (0)
I had the same problem, diagnosed by Bosch Service Centre as poor OEM ground...stronger ground was created and she works fine now.....my RHS HID low beam was arcing with the high beam alongside trying to find a stronger earth.
Hope this helps someone
__________________
Honda Accord K24A3 CL9
To steal ideas from one person is plagiarism; to steal from many is research. Steven Wright
Quest227 is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
Picked up 2007 rl last year, having a few minor issues tman570 Audio, Bluetooth, Electronics & Navigation 9 12-17-2015 10:20 AM
SOLD: 3G TL type S modified headlights JnC Car Parts for Sale 3 09-11-2015 07:06 AM
Electrical issues? Phambam12 Problems & Fixes 4 09-06-2015 07:57 PM
I guess someone is selling my headlights for me voigt Third Generation TL (2004-2008) 12 09-02-2015 11:44 PM
2015 TLX Fog Lights - Only on when headlights set to auto? prox Problems & Fixes 6 09-01-2015 03:03 AM
Tags
05, acura, beam, bulb, connect, dies, flicker, flickers, headlight, hid, light, lights, low, problem, tsx, turns
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Acurazine.com content, comments, or advertising. Acurazine.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Acurazine.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
