Steering wheel vibration
If idle speed is dipping below 600 rpm, suspect a very dirty throttle plate/body. Clean carefully using throttle pedal w/ key on to open throttle plate (don't force open). Idle should be around 700-800 rpm.
If no improvement inspect motor mounts for problems.
good luck
good luck
Bliyun
05-21-2012 11:23 PM
