DIY: How to replace FRONT power lock actuator - AcuraZine Community
Go Back   AcuraZine Community > AcuraZine TSX Community > First Generation TSX Discussion (2004-2008) > Problems & Fixes
Log In
LinkBack Thread Tools Search this Thread
Old 10-04-2008, 06:43 PM   #1
Registered Member
Tangoman's Avatar
Trader Rating: (0)
First off, follow
these ---> http://www.acurazine.com/forums/showthread.php?t=286537
instructions on how to remove the front door panel. Once you get it removed, you have to first peel back the plastic on the panel and look for the actuator connectors.
Click the image to open in full size.
You can see the power connectors circled in red, as well as the bolt for the window guide. You have to make sure you unbolt the 10mm bolt and loosen the guide (put the windows up!!) that runs down the cable from the interior door lock (one screw).
Next step - remove three countersunk screws that hold in the lock mechanism for the door (interior door panel). You need to push as hard as you can on these bad boys, because you will strip them fast if you don't.
Now, here is a step you can't see with pictures. If you stick your head through the big hole in the door panel, you'll see an arm that runs from the exterior door pull down to the locking mechanism.
Just to make sure you are looking at the right thing, pull on the exterior door pull and watch for the metal rod that moves, that is the one you must disconnect from its bottom connection point.
To do this, feel around inside the door until you feel where the rod connects to the locking mechanism.
There is a piece of plastic that is snapped around the end of the rod, it can only move one direction, this is one fastens the rod to the metal guide that allows the door pull to function.
Rotate the around plastic section 90 degrees towards you and it should pop off the rod. Once it does, you can slide the metal rod out.
Below is a picture of the guide for the exterior door pull. The pink plastic part is what you have to disconnect from the metal rod (talked about above) so you can remove the rod. If you don't remove the rod, you'll never get the actuator out.
Now you have to push the window guide as far towards the body panel as you can, rotate the locking mechanism, work with it a bit and finally you'll be able to get it out through the gaping hole in the door.
Now that you have it out, you have to remove the cover the is hiding the connection points for the actuator. Below you see which part of the mechanism is the actuator.
Remove the cover by removing this screw and popping off some tabs.
Finally, remove these two connection points and reconnect the new actuator. Reinstall in reverse order, obviously.
If anyone needs any help (it was hard to take pictures of what was going on inside the door), feel free to PM me.
__________________
Mechanical Engineer
2004 TSX 6MT, Carbon Grey Pearl, 171k miles
91 NSX, Formula Red
Tangoman is offline   Reply With Quote
The Following 2 Users Say Thank You to Tangoman For This Useful Post:
Karlo (09-09-2012), misterpinkey (02-23-2015)
Old 12-21-2008, 11:29 AM   #2
Balla!
Trader Rating: (0)
These are great instructions. One issue though. After I got everything back together, I was not able to attach the cable that drives the keylock. So now my keylock won't work. Any trick to putting that back in?
__________________
www.autotalk.com
Max4Speed is offline   Reply With Quote
Old 12-21-2008, 12:35 PM   #3
Registered Member
Trader Rating: (0)
Theres a plastic plug on the back of the door that when removed, lets you see the lock cylinder to linkage connection.
__________________
'04 TSX--Carbon Gray/Quartz/6Sp/No-Navi
poltergeist is offline   Reply With Quote
Old 12-26-2008, 03:03 PM   #4
dP-
Registered Member
Trader Rating: (0)
Thanks!
dP- is offline   Reply With Quote
Old 02-15-2009, 05:05 PM   #5
Registered Member
Trader Rating: (0)
awesome post...it was a lot more involved than I anticipated so this saved my bacon...thanks
Alwysfresh is offline   Reply With Quote
Old 02-17-2009, 06:37 PM   #6
New Member
Trader Rating: (0)
Get a brand new #3 philips screwdriver for this job!
My #3 screwdriver was older and suffered through replacing my brake rotors. The head was worn just enough to strip one of the three door latch screws. I then had a reverse threaded screw pulling bit shear off inside the shaft of the screw. After a set of drill bits and several grinding wheels for my Dremel I was finally able to remove the screw head and drop the latch mechanism inside the door. Had I just spent the $8 on a brand new #3 it would have saved a lot of headache and work. These screws are very difficult to remove and may even require a crescent wrench on the handle of the screwdriver to give you some extra torque, but be careful and push as hard as you can.
kkendall3141 is offline   Reply With Quote
Old 04-26-2009, 10:29 PM   #7
Slippy maybe...
ryanhook's Avatar
Trader Rating: (0)
Replaced my driver side actuator this afternoon. It took me almost 3 hours, but I'm happy to report it was a successful mission and I had no mishaps.
I would have probably finished sooner, but I has having the hardest time reconnecting the smaller of the two arms -- it probably took me over an hour to get it. Thank you for this post!
ryanhook is offline   Reply With Quote
Old 04-27-2009, 11:36 AM   #8
Registered Member
Trader Rating: (0)
Driver's Side actuator has two Rods to remove (External door pull and lock cylinder)
I'm not sure which end of the lock cylinder rod you disconnected but i think the bottom end is easier as you can easily reconnect it through a hole from the back of the door using a screwdriver..... it took me around the same time too because i didn't realize i had to remove two rods on the drivers side (lock cylinder and external door pull) luckily i didn't try to force it and do some real damage.
Aside from that little hiccup... thanks for posting for the instructions... extremely helpful!
Nickfit is offline   Reply With Quote
Old 04-27-2009, 12:01 PM   #9
2013 Fiat 500 Abarth
CarbonGray Earl's Avatar
Trader Rating: (0)
+1 for this thread. It helped me a couple of months ago. My busted at 75k.
CarbonGray Earl is offline   Reply With Quote
Old 05-25-2009, 04:10 PM   #10
Registered Member
Trader Rating: (0)
actuator replaced
Great thread, actuator replaced today. Interesting, though, my key fob will not lock and unlock right away. If I lock the doors, I have to wait several minutes to be able to unlock them.
Maybe the switches have to reset or be grounded before they will work again???
Thanks,
Jerry
2005 TSX CarbonGrey 6M
kiyoshige is offline   Reply With Quote
Old 06-15-2009, 07:48 PM   #11
Team Anthracite Webmaster
zeezz's Avatar
Trader Rating: (0)
dammit! i have a TL and just went through this same replacement, it would have been helpful if i saw this before hand :P but good write up. and i second the stripping screws, i did the very same thing (had to use a screw remover in the end)....
zeezz is offline   Reply With Quote
Old 06-15-2009, 08:38 PM   #12
Registered Member
Trader Rating: (0)
very nice post..too bad im not much of a DIYer..i took it into the dealership today it was still covered under extended warranty thank god would have cost $160
__________________
sig wont let me list all my mods hahaha
lets just say "too many to count"
deadlyklappy12887 is offline   Reply With Quote
Old 06-23-2009, 06:39 PM   #13
Registered Member
EuroRspec's Avatar
Trader Rating: (1)
Good write up and thanks.
EuroRspec is offline   Reply With Quote
Old 08-17-2009, 02:14 PM   #14
Registered Member
Trader Rating: (0)
I combined 3 different how-to threads to a single web page. Credit goes to the original posters.
http://dest.tv/acura/faulty_acura_actuator.html
dest is offline   Reply With Quote
Old 10-06-2009, 09:56 PM   #15
Registered Member
afici0nad0's Avatar
Trader Rating: (0)
i think my passenger door actuator is starting to go. it's getting the 'sticky' tendencies when i use the key fob to unlock the doors.
afici0nad0 is offline   Reply With Quote
Old 12-28-2009, 01:41 AM   #16
New Member
Trader Rating: (0)
My driverside lock actuator just went up yesterday!!! This write up is great, exactly what i was lookin for. Any info on how much the actuator costs? Thx
siggy833 is offline   Reply With Quote
Old 03-26-2010, 11:15 AM   #17
Registered Member
Trader Rating: (0)
Tangoman and others, thanks for the posts! Both of the front doors failed on me.
dest, thanks for putting all together.
philbur007 is offline   Reply With Quote
Old 04-26-2010, 12:06 AM   #18
TSX 2005 Manual
kanonen's Avatar
Trader Rating: (0)
Folks, I tried to fix my door actuator yeterday...I thought I did the job, until later on I realized that I can't open my passenger door from the inside (works from the outside). I pull the handle and nothing happens. I took the panel off today again, and looked at the cable connection to the inside door handle and it was fine. When I pull that cable after disconnecting it, the door opens...but it looks like when put back in its clip, the door handle doesn't have enough movement in it to pull the necessary lengh for the door to open...i just want to get some ideas before i go ahead and tale the lock/actuator thing itself (it was a hassle!!).
kanonen is offline   Reply With Quote
Old 04-26-2010, 02:10 AM   #19
Registered Member
Tangoman's Avatar
Trader Rating: (0)
This happened to me. The cable from the inside of the door isn't routed correctly, make sure you have it seated in the pieces of plastic that is came out of. Essentially, you have it taking a different "route" than from the factory, and that route is every so slightly longer in distance than it can be in order to open it up correctly. I think you'll find that if you take off your door, you will notice that somewhere near the door handle, the cable isn't where it should be. Shouldn't take long to fix.
__________________
Mechanical Engineer
91 NSX, Formula Red
Old 04-26-2010, 12:42 PM   #20
New Member
Trader Rating: (0)
I had my friend replace the actuator on my drivers side 05 TSX and now the door wont' close properly and wont open from the inside. Any suggestions on what he did wrong?
playabill19 is offline   Reply With Quote
Old 04-26-2010, 07:03 PM   #21
Registered Member
Tangoman's Avatar
Trader Rating: (0)
Quote:
See my previous post on the thread, just one up from yours - you will have to take the door apart and make sure the cable for the door pull is seated where it should be, otherwise the energy used to pull the door handle won't transfer into the cable, it will just shift the cable around, making it so the door won't open.
__________________
Mechanical Engineer
91 NSX, Formula Red
Old 04-26-2010, 07:05 PM   #22
TSX 2005 Manual
kanonen's Avatar
Trader Rating: (0)
Tangoman, yep. Got it, thx. The cable housing must be attached to the door too. I forgot about that.
The DIY is very helpful...the number of clips on these newer cars is crazy though...I miss the time where you only needed to unscrew things.
Old 05-16-2010, 12:56 PM   #23
New Member
Trader Rating: (0)
One thing that I used to loosen the lock and latch assembly screws was a couple shots of WD-40. Waitinged a couple minutes and the screws came out not problem. I wish i did this before I stripped the frist two screws....
burnzi is offline   Reply With Quote
Old 06-03-2010, 04:47 PM   #24
New Member
Trader Rating: (0)
Hey Tangoman,
Thanks for adding this, saved me a ton of money.....
RonnyQ is offline   Reply With Quote
Old 06-10-2010, 09:16 PM   #25
New Member
Trader Rating: (0)
Tangoman, thanks for the info. Actuator failed on my '05 TSX with 67k.
inobmaz is offline   Reply With Quote
Old 06-14-2010, 01:42 AM   #26
Registered Member
fekabeka's Avatar
Trader Rating: (0)
Gabor Beka Szamosi
My passenger side actuator gave up on me a couple days ago. It doesn't respond neither open or lock function only manually. My question is did this problem affect on my trunk? Because if I pushed the unlock button twice before it used to unlock the trunk to but now it's not working. Any suggestion? Sorry if I wrote something incorrect but english is my second language!
fekabeka is offline   Reply With Quote
Old 06-17-2010, 10:42 PM   #27
Registered Member
Tangoman's Avatar
Trader Rating: (0)
Well, if you click the door unlock button twice, it should NOT unlock your trunk. Electrical issues? You should have your own button for the trunk - did you install an aftermarket alarm system?
__________________
Mechanical Engineer
91 NSX, Formula Red
Old 06-22-2010, 02:49 AM   #28
New Member
Trader Rating: (0)
Quote:
Normally when you press the door unlock button twice it should unlock all the doors and the trunk but since one of the actuators doesn't work, when you press it twice one of the locks stays down thus leaving an open circuit to the trunk release button. I know exactly what you are talking about I have the exact same issue on my 05tsx. I will be replacing my actuator soon
Flesh is offline   Reply With Quote
Old 06-22-2010, 11:15 PM   #29
Registered Member
Tangoman's Avatar
Trader Rating: (0)
I'm confused though, when you say "unlock" the trunk, do you mean, "pop" the trunk?
__________________
Mechanical Engineer
91 NSX, Formula Red
Old 06-24-2010, 08:44 PM   #30
New Member
Trader Rating: (0)
I mean unlock the trunk, allowing the the trunk release button above the license plate to pop the trunk.
Old 06-24-2010, 11:12 PM   #31
Registered Member
Tangoman's Avatar
Trader Rating: (0)
Ah, yes. I never use that, I always end up using the remote. Yes, my brother had the same issue on his CR-V as well. It seems like crappy door actuators is something Honda has become accustomed to.
__________________
Mechanical Engineer
91 NSX, Formula Red
Old 07-09-2010, 06:59 PM   #32
New Member
Trader Rating: (0)
Subborn screws
I can't get the screws that hold the door latch/lock mechanism on the passenger side door to loosen. I weigh 200lbs and workout and put all my weight into it and can't get them to loosen. I'm worried I'm gonna strip them and will then be up a creek. Any tips?
wadep66 is offline   Reply With Quote
Old 07-12-2010, 12:50 AM   #33
Registered Member
Tangoman's Avatar
Trader Rating: (0)
Try some penetrating oil or something like that, you are right to be worried about stripping the screws, it is easy to do. Make sure you are using a large phillips head, don't skimp on the size, it matters - try getting an impact screw driver or something like that, you will probably need the impact to get it out.
__________________
Mechanical Engineer
91 NSX, Formula Red
Old 07-19-2010, 07:07 PM   #34
Registered Member
Trader Rating: (0)
Both the front driver and passenger actuators on my wife's 04 TSX went out within about 1K miles. I've thought of taking care of the problem myself with the help of this forum, it looks like I could.
Being that this is a known problem and seems to be a common occurrence, has anyone had luck with contacting Acura to see if they'll cover the repair and replacement? Either fully or partially?
sabi is offline   Reply With Quote
Old 07-22-2010, 03:13 AM   #35
Registered Member
Trader Rating: (0)
I called Acura's customer service number the other day. The representative on the phone took down my complaint about the actuators in my 05 TSX. I'm sure after I got off the phone, it probably went right into the trash.
mplssetter is offline   Reply With Quote
Old 07-30-2010, 06:19 PM   #36
Registered Member
Trader Rating: (0)
I called Acura Customer Care and did not have any luck. I had to go to the dealer this week to bring the car in for the power steering hose recall and did not feel the love from them either.
It seems that Acura is just ignoring that there is a problem and hopes that it'll just go away.
Old 08-09-2010, 09:47 AM   #37
New Member
Trader Rating: (0)
Thank you for the instructions. They were great in disassembling/assembling everything again. Actuator works great again.
One slight problem: When using the key manually it appears to be a bit tricky to hit/miss to open the door. I am afraid that I did not assemble the rod from the lock 100% correctly. When I took the whole actuator piece and put it back I popped the rod from the lock back in but it appears quite loose - was there a plastic piece or something that I am missing between the lock rod and the little manual lock arm at the end fo the actuator??
treo22 is offline   Reply With Quote
Old 08-09-2010, 01:09 PM   #38
Registered Member
SimpleWhite's Avatar
Trader Rating: (0)
Quick question and I know this will sound stupid, but, what does this repair fix? Is this when the key FOB doesn't open the car anymore? Cause I have a similar issue, when I use the key fob to unlock or lock the doors it doesn't work, there is a sound in the locks, like it's trying to open or close. My trunk button works so there isn't an issue with it just being the FOB. I hope someone can help.
__________________
04 PWP TSX
SimpleWhite is offline   Reply With Quote
Old 08-10-2010, 04:08 PM   #39
Registered Member
Trader Rating: (0)
Good write up, my friend needs to replace his passenger side actuator. I'll make sure to refer him to this site so he knows what to expect
mt3c is offline   Reply With Quote
Old 08-11-2010, 09:57 PM   #40
Registered Member
Trader Rating: (0)
Quote:
This replaces the door actuator. You know it is out when the keyfob does not unlock/lock the doors as well as the power door lock option. Must manually put the key in to unlock/lock the door and manually pull the door lock up and press it down. I just changed my driver side actuator and now I can lock/unlock the doors with the keyfob.
NAMEL355 is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
Triangle with "!" at startup, and VSA light after 30-40mph. Help! mada51589 Problems & Fixes 27 01-24-2016 03:42 PM
Picked up 2007 rl last year, having a few minor issues tman570 Audio, Bluetooth, Electronics & Navigation 9 12-17-2015 10:20 AM
Peugeot: Fractal Concept News Yumcha Automotive News 3 09-06-2015 05:40 PM
FS: 2005 Acura TL Anthracite Metallic San Diego, CA asahrts Member Cars for Sale 0 09-04-2015 06:55 PM
Replacing rotted power steering pipes on my 2001 tl mike from annapolis Problems & Fixes 2 09-04-2015 04:34 PM
Tags
04, 2001, 2005, actuator, actuators, acura, door, forum, lock, mdx, power, problem, replace, replacing, tl, tsx, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Acurazine.com content, comments, or advertising. Acurazine.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Acurazine.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
