Check emission system light - AcuraZine Community
Go Back   AcuraZine Community > AcuraZine TSX Community > First Generation TSX Discussion (2004-2008) > Problems & Fixes
Log In
LinkBack Thread Tools Search this Thread
Old 01-29-2008, 03:12 PM   #1
Registered Member
Trader Rating: (0)
Hi guys, last week the check emission system light came on in my 06 TSX with 35000 miles. Today, I took it to acura and they told me that the reason the light is on is due to my K&N cold air intake. Is this possible? What do you guys think? Thanks.
dinodaitalian is offline   Reply With Quote
Old 01-29-2008, 03:39 PM   #2
Someone stole "My Garage"
curls's Avatar
Trader Rating: (0)
Doubtful but possible.
Did they give you the code value that it's throwing? If not, check it at Autozone or many parts places like that -- they'll pull the code for free. that code will pinpoint the component (with good accuracy) that's causing the fault. Then, diagnose from there.
curls is offline   Reply With Quote
Old 01-29-2008, 05:27 PM   #3
Registered Member
Trader Rating: (0)
Yes they did provide the codes which I will post later...they charged me $120 just for diagnostics since the problem is caused by an aftermarket part.
Old 01-29-2008, 05:41 PM   #4
Registered Member
PACman's Avatar
Trader Rating: (0)
^^Damn, $120 just to get a code? Next time, Autozone or a friend who has an OBDII scan tool.
BTW, I have a K&N Typhoon and have been running it for 70,000miles....no codes! Is your CAI installed right?
PACman is offline   Reply With Quote
Old 01-29-2008, 06:02 PM   #5
What Would Don Draper Do?
JediMindTricks's Avatar
Trader Rating: (0)
i had the emission light go off once because i didn't tighten the gas cap enough.
i think the manual says that the light will go off within 3 days after the gas cap is tightened. and sure enough, it did go away on the third day.
JediMindTricks is offline   Reply With Quote
Old 01-29-2008, 06:15 PM   #6
Registered Member
Trader Rating: (0)
I did check the gas cap last week and it still has not gonna off. I've had my typhoon intake in for almost 2 years and no problems. Im gonna convert it to short ram this weekend and see what happens.
Old 01-29-2008, 06:29 PM   #7
Registered Member
PACman's Avatar
Trader Rating: (0)
Post the code when you get the chance.
Old 01-29-2008, 09:19 PM   #8
Registered Member
Trader Rating: (0)
P2a00
P1172
Old 01-29-2008, 11:40 PM   #9
Registered Member
llwtsx's Avatar
Trader Rating: (0)
P0133, P1172 ('05-07 models), P1157, P2195, P2238, P2252, P2A00: Air fuel ratio (A/F) sensor (Sensor 1)
and also:
P2A00 Air/Fuel Ratio (A/F) Sensor (Sensor 1) Range/Performance Problem
llwtsx is offline   Reply With Quote
Old 01-29-2008, 11:49 PM   #10
Registered Member
PACman's Avatar
Trader Rating: (0)
Quote:
Originally Posted by dinodaitalian
P2a00
P1172
Looking at http://www.hondacarforum.com/honda-3...tic-codes.html , sounds like your primary O2 sensor (air/fuel ratio sensor). Other members should chime in on this to confirm. Any how, the sensor to replace is about $213 #36531-RBB-003 ; but this is an emissions defect and should be covered under emissions warranty, which you're well within.
Your K&N isn't the reason.
Old 01-30-2008, 08:49 AM   #11
curls's Avatar
Trader Rating: (0)
If it's the primary O2 sensor, it's not a cheap part. Advice to you would be to put the stock intake back on, drive to another dealer, and get the O2 sensor replaced under warranty.
I think it's only part of the 3yr comprehensive warranty though, NOT the 8yr emissions warranty. Actually I'm quite sure of that, since I had to replace the O2 sensor on my car last year -- the manual and the dealership both stated that the sensors aren't the full 8yr warranty, only the catalytic covnerter, and other major emissions components that aren't electrical.
The labour is simple (mere minutes) but it's the part that's pricey.
Old 01-30-2008, 10:11 AM   #12
Registered Member
Trader Rating: (0)
I asked the service associate if anything was wrong with my O2 sensors when I picked up my car and he told me they were fine...do you think he was lieing to me? They said the reason the light came on was due to too much air going into the engine.
Old 01-30-2008, 10:42 AM   #13
Registered Member
Trader Rating: (0)
... too much air going into the engine.
I suggest you whip out your junk and give that moron a nice mushroom bruise across his face.
Then take your car somewhere that the techs aren't legally retarded wards of the state.
LukeaTron is offline   Reply With Quote
Old 01-30-2008, 11:36 AM   #14
Registered Member
Trader Rating: (0)
yea i might have to do that... thanks for all your help guys.
Old 01-30-2008, 11:50 AM   #15
curls's Avatar
Trader Rating: (0)
Quote:
LMFAO!!
And yeah that tech is a complete moron.
Old 01-30-2008, 12:23 PM   #16
Registered Member
PACman's Avatar
Trader Rating: (0)
About 1 1/2yrs ago, I had a CEL...code P04XX (can't remember exactly since it was a while back). Took it in the dealer to get it checked out, told me they couldn't find anything wrong. They said they didn't think it was my CAI, cleared the code, and told me if it happened again, to come back (no charge on this visit). I did go back, and another SA was gonna charge me $ just to read the code, so I said screw it and bought myself a scan tool.
After posting here about my problem, which BTW curls, amongst others, helped me out, it was the air/fuel ratio sensor that was the problem. Got the part and changed it out myself - 30min job. Jacking up the car and going underneath took more time than replacing the part.
More often than not, I think our forum members know more about our cars than the Acura tech.
Old 01-30-2008, 10:39 PM   #17
Registered Member
Trader Rating: (0)
I disconnected my battery and the check engine light went away...if it doesn't come back on does that mean the problem isnt there? I called the dealer today and they said they were positive there was nothing wrong with my o2 sensors.
Old 02-09-2008, 04:06 PM   #18
Registered Member
Trader Rating: (0)
Does anyone know if the hondata ecu update will fix my problem?
Similar Threads
Thread Thread Starter Forum Replies Last Post
Triangle with "!" at startup, and VSA light after 30-40mph. Help! mada51589 Problems & Fixes 27 01-24-2016 03:42 PM
DIY: Converting DBW to Mechanical Cable Throttle with Working A/C cycdaniel Performance Parts & Modifications 2 10-05-2015 05:38 PM
Check Gas Cap Light? SpraykwoN Acura ILX Discussion 4 09-23-2015 12:44 PM
Peugeot: Fractal Concept News Yumcha Automotive News 3 09-06-2015 05:40 PM
Weird Errors After Battery Runs Out chrisrayala Problems & Fixes 7 08-31-2015 09:24 PM
Tags
09, 2008, acura, check, emission, emissions, emmission, light, mdx, p1172, rdx, rl, rsx, system, tsx
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Acurazine.com content, comments, or advertising. Acurazine.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Acurazine.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
