Radio Code - AcuraZine Community
Go Back   AcuraZine Community > AcuraZine TL/TLX Community > First Generation TL (1996-1998) > Problems & Fixes
Log In
Radio Code
LinkBack Thread Tools Search this Thread
Old 05-19-2006, 01:06 PM   #1
Registered Member
Trader Rating: (0)
Radio Code
I Lost The Radio Code Someone Help Plz Where The Hell Is It
jgtl25 is offline   Reply With Quote
Old 05-19-2006, 02:12 PM   #2
Registered Member
copy252's Avatar
Trader Rating: (0)
jkbradburd Jae_Bradburd jae0922
mine was on a piece of masking tape on top of the unit
copy252 is offline   Reply With Quote
Old 05-19-2006, 02:44 PM   #3
Registered Driver
UnsanePyro's Avatar
Trader Rating: (0)
Some people have found it in the glove box/fuse box, but if you can't find it written there, I made a thread on how to get the serial number, which you will need if you contact the dealer to get the code
UnsanePyro is offline   Reply With Quote
Old 05-19-2006, 07:44 PM   #4
Registered Member
Trader Rating: (0)
Mine was on a plastic card in the owners manual portfolio.
good luck
TexasHonda is offline   Reply With Quote
Old 05-19-2006, 07:45 PM   #5
Ken1997TL's Avatar
Trader Rating: (0)
ken1997tl
Others have seen it underneath the coinbox..
Ken1997TL is offline   Reply With Quote
Old 05-20-2006, 02:54 PM   #6
Registered Member
copy252's Avatar
Trader Rating: (0)
in other words.... its in the car somewhere
Old 11-01-2006, 04:04 PM   #7
Registered Member
Trader Rating: (0)
Hey I haven't seen this answered.... although I am sure it is an obvious one. My deck now is not allowing me to enter the code. How can I reset this to allow me to enter the code?
Thanks!!
theinfamousrobbdeep is offline   Reply With Quote
Old 11-01-2006, 07:53 PM   #8
Registered Member
Trader Rating: (0)
Quote:
Thanks!!
You need to pull the BackUp fuse and reset the radio. After several attempts to enter the code it locks the radio until a reset is done.
good luck
Old 11-02-2006, 10:19 AM   #9
Registered Member
Trader Rating: (0)
Thank you TexasHonda! Is this BackUp fuse located with all the other fuses or on the connection for the deck?
Old 11-02-2006, 05:52 PM   #10
Registered Member
Trader Rating: (0)
It's an under the hood, 10A fuse labeled BackUp. Your ECU will also reset so don't plan on an emissions test till you drive for an hour or so.
good luck
Old 11-23-2006, 11:53 PM   #11
Registered Member
Trader Rating: (0)
Help! I Purchased My 1996 Acura Tl 3.2 As A Used Vehicle Without The Owners Manual And My Radio Is Not Working It Displays The Word Code, How And Where Do I Find This So Called Code?
OCSHELLY25 is offline   Reply With Quote
The Following User Says Thank You to OCSHELLY25 For This Useful Post:
AMart83 (09-07-2014)
Old 11-24-2006, 12:10 AM   #12
Khmer Pride
KrayzieDxC's Avatar
Trader Rating: (0)
Quote:
check inside glove department on the side..should be a white label,might
KrayzieDxC is offline   Reply With Quote
Old 11-24-2006, 05:20 PM   #13
Registered Member
Trader Rating: (0)
Why would they even put the Radio Code anti-theft feature on the stock (non-Bose) radio? It's not like it's a premium sound system. The sound out of mine is mediocre at best.
hoser is offline   Reply With Quote
Old 11-25-2006, 12:50 PM   #14
Registered Member
Trader Rating: (0)
I just had to replace my battery and needed the code...thank god the previous owner kept the code in the manual...
JetBlackAC is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
Help Please!!! ABS and VSA light with exclamation point ALL ON Jamus22 Problems & Fixes 18 02-07-2016 07:08 PM
Retrieve Unlock Codes for Radio and Navigation Devices dirleton Second Generation RDX (2013+) 8 09-28-2015 05:48 PM
Misfire DTC and TSB 03-033 question thegipper Third Generation TL (2004-2008) 5 09-28-2015 02:01 PM
EGR Valve /Extended emissions warranty shawnafoxx First Generation RL (1996-2004) 2 09-28-2015 01:33 PM
Audio problem Matthew Purpura First Generation CL Discussion (1997-1999) 3 09-25-2015 07:10 PM
Tags
1998, 2004, 2005, 2006, acura, acurazine, anti, bose, cl, code, mdx, radio, reset, rsx, serial, theft, tl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Acurazine.com content, comments, or advertising. Acurazine.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Acurazine.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
