96 3.2 TL Will turn over but not run. - AcuraZine Community
Go Back   AcuraZine Community > AcuraZine TL/TLX Community > First Generation TL (1996-1998) > Problems & Fixes
Log In
LinkBack Thread Tools Search this Thread
Old 11-19-2010, 08:59 PM   #1
New Member
Trader Rating: (0)
Click the image to open in full size. 96 3.2 tl will turn over but not run
Hi everyone. Today i got up for work and my car wouldn't start.. its cold out but ran good the day before.. It will turn over and seem to start but as soon as i release the ignition the engine immediately dies and all the dash lights (except the radio) turn right off.. Its currently at a shop and they don't know what they are looking for so i thought i'd try here.
they said the checked for electrical problems but cannot find anything and want 800$ to do a full tune up including plugs and wires. you can smell gas when the cars tryin to start and its clearing firing but as soon as the key is released its all gone...
ANy suggestions???? is it ignition, fuel pump , relays.
Thanks for any help!!!
vanilla_ape_tits is offline   Reply With Quote
Old 11-19-2010, 09:34 PM   #2
Registered Member
Trader Rating: (0)
I've been here before. I spent 3 weeks of my time checking everything, from the all the wires on the ECU for ignition, to the main relay, to the ignition switch, to the ignition control module, and everything in between. I traced all the wiring for the entire ignition system. I couldn't find the problem. I replaced the ECU and the ICM. Didn't help.
I finally found it, and I should have known the whole time. I had a bad ground (The ground that was on the fuel rail on the passenger side). I checked that the first day when I checked the voltage on the ignition control module, but I was checking for voltage and when the ground had none I said "Well that's normal" and moved on. I didn't check for a grounded connection like I should have.
Jeffman is offline   Reply With Quote
Old 11-19-2010, 09:46 PM   #3
Registered Member
Trader Rating: (0)
$800 for tune up? What else in included other than just spark plugs?
Like you said, you smell fuel when trying to start. Obviously you are missing spark. Sounds like ignition switch to me from your description.
__________________
2001 BMW 325i MT
1997 Acura 3.2TL-RIP 08-03-10
1998 Acura 3.2TL
tmnhs81 is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
NavTool Video Interfaces For TLX navtool.com Audio, Bluetooth, Electronics & Navigation 31 11-16-2015 09:30 PM
FS: 3.2 Type-S Motor pieces kmarqueling Car Parts for Sale 1 10-03-2015 02:14 AM
Shifting Gears (6MT): Help diagnose the problem SidhuSaaB Problems & Fixes 0 09-22-2015 11:32 AM
2000 Acura TL 3.2 Reverse (Only) Slips Under Load Mike Bertram Second Generation TL (1999-2003) 9 09-10-2015 10:27 AM
Tags
1996, 2000, 32, 32tl, 96, acura, control, fine, icm, ignition, module, problem, start, tl, tune, turn, turns
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Acurazine.com content, comments, or advertising. Acurazine.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Acurazine.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
