1997 Acura 2.5 TL Vehicle Speed Sensor
Hi everyone, sorry to bother again!,
I'm having an issue with my V.S.S in my 97 acura 2.5 TL
Diagnostic codes: P1791 / P0700 / P0500 / P0135 ( which is o2 sensor a totally different issue I'm guessing )
Issues that are noticable by me: No Speedomter / odomoeter / trip counter
Could someone please link me to the correct parts
( oem or replacement without much side work to be done)
I've checked a the forum posts, there's a few guides and other people having the same codes / issues, but I'm truly a novice, a direct link to the part(s) I need would be a great thing you could do for me, as I've looked around and don't have the time to ship back if I fail , I have a 20-30 mile trip 3-4 times a week to take and are trying to get this done asap! I have an experienced mechanic but he's not comfortable with electrical work and or rebuilding parts ( as noted in TexasHonda's post, and we both feel we might waste time / money / and be worse off than we started.
Please help asap if you can! Thank you so much!!
1997 Acura 2.5 TL Vehicle Speed Sensor Location Also?
Also if you could give a detailed explanation of where the V.S.S is located and or a picture that would be great, I see a few sensors around the area where we think it's located, but not entirely sure.
Thank you so much everyone!
~Chris
~Chris
Found the location exactly! Noticed that the ground wire was the only wire in the pigtail.. the other 2 had been forcefully pulled out when the last shop did an oil filter change.. HOW RUDE! I simply put the 2 wires back in, unhooked my battery ( to clear the error codes since I don't own a diagnostics machine) hooked my battery back up and BOOM! we have a sensor working again, even fixed my cruise control . TY ALL!!!! hope This can help someone in the future!
Help?
There located next to the calipers . I have the same problem ! I ordered the new sensor but my question is how can you tell which side needs the new sensor ?? There's four . one on each side ..
AndrewS
19
03-14-2024 06:59 PM
mada51589
05-03-2022 08:54 PM
