1997 2.5 tl idle problems, runs rough then stalls
Old 01-14-2015, 08:22 AM
acura master tech
240sx acura tech's Avatar
I have a customers car in the shop. its been to three other shops in the pass month. Brought its here as a last effort. Unfortunately in the 9 years of being a master tech ive only work on a couple of these and never have seen this issue.
car starts and runs fine. Bring it to op temp. no problems. turn it off. let sit 5 mins. start it up. it will run fine for about a minute then start to idle low and lope and will eventually die...
ive done the usually stuff. replaced rear o2, egr port clean, plugs, cleaned the iac and throttle, coolant temp switch, swap coils, checked cold valve, checked for intake leaks and checked fuel pressure.
no check engine light. any help would be a greatly appreciated
nich0085 (11-17-2017)
Old 01-29-2015, 07:57 AM
acura master tech
I think I figured out the problem. found the front o2 sensor reading high after warming up. replaced front o2 and has not done it since.
Old 01-29-2015, 12:25 PM
main70072's Avatar
That should do it. Front o2 sensors can can be a headache on these cars.
Old 01-29-2015, 12:49 PM
acura master tech
yeah it never thru a light. rear o2 was stuck lean. both were ntk brand.
mada51589
05-03-2022 08:54 PM
Powder Monkey
2G CL Problems & Fixes
09-09-2018 12:55 AM
Laoch
1G RL (1996-2004)
10-02-2015 03:27 PM
kuzdu
09-10-2015 08:42 PM
NSolace
09-03-2015 08:14 PM
Quick Reply: 1997 2.5 tl idle problems, runs rough then stalls
