Steering wheel shake 40 - 50 mph - AcuraZine Community
Go Back   AcuraZine Community > AcuraZine TL/TLX Community > Second Generation TL (1999-2003) > Problems & Fixes
Log In
LinkBack Thread Tools Search this Thread
Old 08-07-2008, 10:51 AM   #1
'02 TL-S
jeffrop's Avatar
Trader Rating: (0)
Recently I've noticed my steering wheel will shake back and forth starting at around 40 mph and it gets worse around 50 mph then starts to diminish when approaching higher speeds. The wheel will also do this pretty bad when braking from around 40-50 mph.
I just recently installed EBC rotors and Hawk pads, new wheels(yesterday) that were balanced. I jacked up the front end and pulled on the wheels to check for loose tie rods/ball joints and couldn't find any.
After reading through some of the car shakes threads it sounds like the CV joints are probably the cause.
Are there any other indicators this is the problem? Could it be something else? I can't believe my brand new rotors would be warped already.
The car has 154,000 miles on it. Oh, and a few days ago I "curbed" the right front wheel while turning a corner and it seemed to worsen the situation.
jeffrop is offline   Reply With Quote
Old 08-08-2008, 11:51 AM   #2
Lower IS Better!
death's Avatar
Trader Rating: (0)
I had a similar issue and compiled this list of things to check as well as a troubleshooting guide pulled from a sister site.
Symptoms:
Pulls to the right (Alignment first - DONE)
Grinding, rubbing noise
Vibration 45-60mph
Fix:
Bent Control Arms?
CV Joints?
Tie rod ends? $29.94 each (L/R)
Warped Axles? (Search CL forum... there are a couple threads which point to this issue)
Motor Mounts
Check suspension - Stuts still good?
Purchase New:
Camber Kit
Ruled Out:
End Links
Lower Ball joints
Front & Rear Ball Joints
Alignment
Quote:
Trouble shooting guide:
Vibration that increases with speed or kicks in at different speeds
Excessive play in the inner or outer joints or a bent driveshaft
Replace worn shaft assembly
Clunking noise when engaging automatic transmission.
Worn inner or outer joints.
Replace worn shaft assembly.
Continuous knock at low speed
Indicates a worn CV joint
Replace worn assembly.
Continuous humming or growling noise.
Inadequate lubrication on inner or outer joints (check boots for leaks). May also be worn gears or wheel bearings.
Inspect CV joint - replace necessary.
Clunking noise during acceleration or deceleration.
Worn inboard joint or differential problem in the transaxle.
replace worn shaft assembly or repair transaxle as necessary.
Clicking or popping noise.
Worn outer joint.
Shudder while acceleration or deceleration.
Worn inner CV joint.
Cyclic vibration.
Worn inner tripod CV joint.
death is offline   Reply With Quote
Old 08-08-2008, 01:12 PM   #3
2011 BMW 335i
carlos9827's Avatar
Trader Rating: (2)
Probably need an alignment. Or if you have aftermarket wheels they could be a lil bent....I know of someone who had this SAME EXACT issue.
carlos9827 is offline   Reply With Quote
Old 08-08-2008, 05:29 PM   #4
Acura Master Tech
Trader Rating: (0)
You answered your own question. You probably shifted a belt in the tire when you hit the curb.
JTS198 is offline   Reply With Quote
Old 08-08-2008, 07:01 PM   #5
'02 TL-S
jeffrop's Avatar
Trader Rating: (0)
Ok just FYI - I have brand new wheels and tires on the car AFTER I curbed the stock wheel.
I just got done installing the passenger side CV Axle assembly and I have a NEW PROBLEM..arrrrrghhh!
There is a loud squeal coming from the front right wheel area. Im positive it is the outer joint carrier(dont know what else to call it) that is rubbing against the steering knuckle as it was extremely close upon assembly.
Could I have the wrong CV axle assembly? I bought it from NAPA Auto parts(reman).
How do I fix this???
Just a note: I plan on replacing the driver side CV axle assembly too.
Old 08-08-2008, 07:41 PM   #6
'02 TL-S
jeffrop's Avatar
Trader Rating: (0)
Here's a pic
Click the image to open in full size.
Old 08-09-2008, 12:15 PM   #7
Registered Member
MurdaZ's Avatar
Trader Rating: (1)
does it squeel all the time or only on turns or straights?
MurdaZ is offline   Reply With Quote
Old 08-09-2008, 07:25 PM   #8
'02 TL-S
jeffrop's Avatar
Trader Rating: (0)
Quote:
All the time.
Old 08-11-2008, 08:17 AM   #9
'02 TL-S
jeffrop's Avatar
Trader Rating: (0)
Ok I fixed everything. The abs sensor ring was not seated all the way on the outer CV joint, thus it was rubbing on the inside of the steering knuckle (see pic above).
I replaced with a NEW CV axle assembly - that problem solved.
The other issue with the steering wheel shaking is resolved too. I examined the hub centric ring on my new wheel, and the hub and noticed the ring(aluminum) was galled a bit from not fitting properly on the hub.
I cleaned up the ridge on the centering ring I.D. with a dremel and went around the hub O.D. (on car) with the dremel to smooth it as it appeared to have a ridge around the outside.
Reassembled everything carefully and the car goes down the road with no vibrations or noises.
Thanks to those who tried to help.
Old 09-23-2009, 09:22 PM   #10
New Member
Trader Rating: (0)
Solution..!
I went to the Acura dealer (finally), and they found both CV joints broken.
My mechanic changed them, and guess what...?
Vibration is gone forever.
Even when they don't look broken, they may be in the inside.
Mrkanela
Mrkanela is offline   Reply With Quote
Old 09-24-2009, 01:41 AM   #11
Told Ya'LL...DYNASTY !!
XxXboboXxX's Avatar
Trader Rating: (2)
do you by chance have the part numbers for the cv joints?? might be my problem too...
XxXboboXxX is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
2016 RDX Elite explained for people looking for their first luxury vehicle rockyboy Second Generation RDX (2013+) 157 10-04-2015 11:28 AM
Rental Review: 2016 Hyundai Sonata Hybrid PortlandRL Car Talk 2 09-14-2015 01:01 PM
Steering Wheel Clock Spring 04tler Problems & Fixes 5 09-10-2015 05:03 PM
Peugeot: Fractal Concept News Yumcha Automotive News 3 09-06-2015 05:40 PM
FS: Acura OEM Leather Steering Wheel. MyKids&Cars Car Parts for Sale 0 09-02-2015 01:03 AM
Tags
2000, 45, 50, accelerating, acura, axle, car, continuous, end, excessive, front, mph, noise, play, shake, shakes, steering, tl, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Acurazine.com content, comments, or advertising. Acurazine.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Acurazine.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
