Squeaking belt - AcuraZine Community
Go Back   AcuraZine Community > AcuraZine TL/TLX Community > Second Generation TL (1999-2003) > Problems & Fixes
Log In
Squeaking belt
LinkBack Thread Tools Search this Thread
Old 02-18-2012, 05:18 AM   #1
Registered Member
Trader Rating: (0)
Squeaking belt
My 02 TL-S has this problem where when I start the car when it's cold there is this loud squeaking noise coming from the passenger side where the belts are at. After the car warms up the noise goes away. What could it be? Thanks in advance.
teohenwhy is offline   Reply With Quote
Old 02-18-2012, 11:32 AM   #2
Registered Member
Trader Rating: (0)
a worn out belt, the main belt tensioner failing, the ps belt not tightened correctly
(caution: it does need more play than a normal belt)
01tl4tl is offline   Reply With Quote
The Following User Says Thank You to 01tl4tl For This Useful Post:
teohenwhy (02-18-2012)
Old 02-18-2012, 11:39 AM   #3
Registered Member
AznWay's Avatar
Trader Rating: (8)
Aznway
try showing us youtube video so we can help you out better.
__________________
99 6speed Type-S SSM TL w/ Samsung Tab3 Navi replacement-OEM Bodykit-WW Rear Lip & Spoiler-Roof Spoiler-JDM Visor-SABER Grill-INSPIRE/32V/H Badges-02/03 Mirror & TailLight-CUCSO Strut Bar-NRG & Ingall Engine Damper-PnP Lower Runner-MDX Spacer-P2R Spacer/TB/Manifold Gasket- 3.5" CAI-XS Header-UR Stock Crank Pulley-XLR8 CAT & 62A Mount-Comptech Exhaust-F&F Type 1-RL BBK-Irotors Disc Brake-XXR 530 Chomium Black 18"
AznWay is offline   Reply With Quote
The Following User Says Thank You to AznWay For This Useful Post:
Old 02-18-2012, 07:35 PM   #4
Registered Member
Trader Rating: (0)
Could it be the timing belt? I will try and upload a video soon.
Old 02-18-2012, 07:44 PM   #5
Registered Member
Trader Rating: (0)
The funny thing is that this started after getting my oil changed at Jiffy Lube. Could something they did while doing inspections cause this? I know they inspected the belts.
Old 02-18-2012, 07:52 PM   #6
Registered Member
Trader Rating: (0)
Quote:
http://www.youtube.com/watch?v=8JrX4...ature=youtu.be
Old 02-20-2012, 02:16 PM   #7
Registered Member
Trader Rating: (0)
Quote:
No, a timing belt cannot sqeal.
almightycrunch is offline   Reply With Quote
Old 04-07-2012, 01:38 PM   #8
Registered Member
Trader Rating: (0)
I am having this issue on cold mornings as well - sounds like either a belt or maybe a bearing squeal - I had all belts/ idlers/tensioner, water pump, seals, etc. changed out when I had the timing belt service done 2 yrs ago @ 101k mi. Now at only 113k miles.
Ideas?
__________________
2000 TL - Nighthawk Black
Ronmarr1 is offline   Reply With Quote
Old 04-07-2012, 04:43 PM   #9
fsttyms1's Avatar
Trader Rating: (0)
fsttyms1
Quote:
Ideas?
Miles mean less than age. Was the belt a honda belt or a autoparts store belt?
fsttyms1 is offline   Reply With Quote
Old 04-07-2012, 08:36 PM   #10
2G TL-S / 2G MDX T&E Pkg
Skirmich's Avatar
Trader Rating: (0)
It doesnt sound like a Belt Tensioner problem... By looking in the video the PS Belt looks like the "Mitsuboshi" OEM.. but I dunno about the ACC belt.
IMO Use only OEM I had a Gatorback in there sometime ago and It did squeal alot...
__________________
2G Acura TL-S (WDP)
Mechanical Mods: All Bolt-Ons (Engine) to Straight Pipes!.
2G Acura MDX Tech & Entert Package
Bone Stock
Skirmich is offline   Reply With Quote
Old 04-07-2012, 08:57 PM   #11
Registered Member
Trader Rating: (0)
All parts for the timing belt replacement, including all belts, idler(s?), tensioner, seals, water pump, etc, were Acura OEM - only 2 yrs ago and about 12k miles since the install. Belts look fine and tension "appears" correct. Wonder if it might be alternator or power steering pump bearing? Noise is only when cold.
__________________
Similar Threads
Thread Thread Starter Forum Replies Last Post
Ready To Take the Plunge but With Questions 08KBP_VA Second Generation RL (2005-2012) 33 01-08-2016 03:22 PM
FS: 2003 Acura CL-S 6MT ABP ★★Location of Vehicle : Edmonton, AB, Canada★★ rp_guy Member Cars for Sale 1 10-22-2015 03:58 PM
SRS after collision brboy Second Generation RL (2005-2012) 5 10-05-2015 12:34 PM
SOLD: Aisin OEM Timing Belt Water Pump Kit Jboat Car Parts for Sale 6 09-30-2015 11:58 AM
Price for oil pump, timing belt, water pump Boraxo 1G & 2G MDX Discussion (2001-2013) 2 09-29-2015 05:35 PM
Tags
1999, 2002, 99, acura, alternator, belt, cl, cold, loud, squeaking, squeal, squealing, squeck, squeeking, start, tl, tsx
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Acurazine.com content, comments, or advertising. Acurazine.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Acurazine.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
