Radio out, car won't shift out of park - AcuraZine Community
Go Back   AcuraZine Community > AcuraZine TL/TLX Community > Second Generation TL (1999-2003) > Problems & Fixes
Log In
LinkBack Thread Tools Search this Thread
Old 06-01-2010, 08:55 PM   #1
Registered Member
thaprinze's Avatar
Trader Rating: (0)
Exclamation Radio out, car won't shift out of park
Hey guys,
I've searched for this problem for a while now, and I found one other person with a similar problem, but s/he didn't provide a fix.
This weekend I turned on my car, but it wouldn't let me shift out of park. Normally you hear a click when you push the brake down, but this didn't give me anything. I also noticed that my radio wouldn't turn on either, but the Anti Theft light on it was on, even though the car was on. I pushed the eject button, and sure enough, the cd popped right out, so it is getting power. I checked the fuses, and replaced a blown ACC Relay on the driver's side, but I still have the same issues. Does anyone know what I should check/try next?
I don't think this is a brake sensor thing, because as I said, the brake lights turn on, and the deck is acting like the security system is still active. I'm not sure if there's something wrong with the security system that allows the car to turn on, but won't let you turn on the radio or change gears.
Also, I'm worried about trying to override the gear to neutral, turn it on, then try to shift gears to get it to a mechanic. I'm afraid of a bunch of wild scenarios running through my head.
Any help would be GREATLY appreciated!!
thaprinze is offline   Reply With Quote
Old 06-01-2010, 08:58 PM   #2
Registered Member
thaprinze's Avatar
Trader Rating: (0)
Crap... I just checked outside of the Problems & Fixes section and it looks like someone already asked this question a couple months ago & there is no solution.
Mods, feel free to delete this post. Thanks...
Old 06-02-2010, 07:00 AM   #3
Registered Member
Trader Rating: (0)
first- its no prob to do the nuetral override- put the car key in the slot to right of shifter
push down key- press brakes and shift into N
Hold brakes on- move key to ignition and start car
All shifting is now normal- when you next stop the car and turn key off- it will require the N override again
If even 1 brake light bulb is out it can cause this- ck all including center light
Next is loose sender for brakelights at the pedal -it happens- get under there and look-
one sensor for brake light the other is cruise control disconnect
If the battery is weak it causes many problems - parts stores wil test the system for free
01tl4tl is offline   Reply With Quote
Old 06-02-2010, 07:01 AM   #4
Registered Member
Trader Rating: (0)
what do you have added to the acc relay?
what caused its failure- thats not normal and may point to a short in the system~
Old 06-02-2010, 02:34 PM   #5
fsttyms1's Avatar
Trader Rating: (0)
fsttyms1
Check the fuses on the Passenger side fuse panel (thats where the radio and brake fuses are). Also make sure there isnt a Dime in the cig lighter socket.
fsttyms1 is offline   Reply With Quote
Old 06-03-2010, 12:01 AM   #6
eg5
user title goes here
Trader Rating: (4)
Quote:
...lol.speaking from experience?
eg5 is offline   Reply With Quote
Old 06-03-2010, 02:47 PM   #7
2003 TL-S w/Navi NBP
Trader Rating: (0)
Check to see if the relay has blown a second time. If it has, there is obviously still a problem somewhere in that circuit. Fuses and relays don't normally just wear-out, so simply replacing them may not do any good.
jdjohn84 is offline   Reply With Quote
Old 06-03-2010, 07:16 PM   #8
fsttyms1's Avatar
Trader Rating: (0)
fsttyms1
Quote:
No, but MANY others here have had that problem.
Old 06-13-2010, 09:08 PM   #9
New Member
Trader Rating: (0)
havin same issue .. im def having to use shift lock to get in gear
Da NeW sLim2 is offline   Reply With Quote
Old 06-13-2010, 10:49 PM   #10
fsttyms1's Avatar
Trader Rating: (0)
fsttyms1
Quote:
Your radio is out too, or you just have to use the shift lock to get it into gear?
Old 02-24-2011, 09:27 PM   #11
Registered Member
thaprinze's Avatar
Trader Rating: (0)
Funny story... Here's how absent minded I am! Today I was driving home when all of a sudden my radio & phone charger both go out. Then when I stop to get gas, I can't shift up passed Neutral & can't get my keys out of the car.
Long story short, I start googling my issues & I'm lead to this thread... WHICH I STARTED!!!
Anyway, I never wrote back with the resolution the first time, but it's the Accessory Relay fuse, which can be found in the fuse box on the driver side.
Old 02-24-2011, 10:34 PM   #12
Registered Member
Trader Rating: (0)
azine to the rescue once again!!
Old 03-05-2011, 11:49 PM   #13
Registered Member
Trader Rating: (0)
I have this issue, however, my radio and shifter usually work; I only have a problem once a week. I knock on the left-side of the radio and the power comes back and I can shift. The bulb to the driver's seat heater burnt out as well when this problem showed up. I doubt a fuse or relay is the culprit because the issue comes and goes. I am going to take the console apart and probe around for chaffed/bent wiring harness (es) etc...
sypher2020 is offline   Reply With Quote
Old 06-24-2014, 10:24 AM   #14
Registered Member
Trader Rating: (0)
Hey guys. Having this same problem with the ACC fuse blowing. I say blowing since it's done it 3 times in 2 days. I don't want to do another since it's obviously not fixing the problem.
My first thought was there is a loose wire somewhere grounding out, but no wiring changes have taken place, so there's no obvious place to start looking for that.
Does anyone have any suggestions as to where to start looking or what I should be looking for?
Difinity is offline   Reply With Quote
Old 06-24-2014, 10:56 AM   #15
Registered Member
Trader Rating: (0)
wow- heck of a thread revival!
just guessing but we have a problem with the cabin fan-blower motor power connector under front edge of glovebox, tight wires lead to loose connect and possible short as plastic melts away!
20-25$ for new connector setup at acura..ask for the Update Kit - just splice in
you may have to unplug the connector to find the loose wires or damage--hidden from view
__________________
at the end of your life,,it was all just stuff, so enjoy great toys!!
you can screw around asking buddies,
or you can believe acurazine- where info is based on thousands of users reports!
Old 06-24-2014, 11:26 AM   #16
Mr.Helpful Diagram
ErickUa5's Avatar
Trader Rating: (0)
Any aftermarket accessories ?
Radio, anything in the Accessory sockets (under the radio and behind the cup holder) check those and remove if any.
ErickUa5 is online now   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
3.7 shawd - tlx 3.5 kuzdu Fifth Generation TLX (2015+) 3 09-10-2015 09:42 PM
Peugeot: Fractal Concept News Yumcha Automotive News 3 09-06-2015 05:40 PM
2006 6 speed manual trans jfman55 Third Generation TL (2004-2008) 27 09-05-2015 03:55 PM
Car Was Smoking TL-Rocket Third Generation TL (2004-2008) 5 09-03-2015 11:43 PM
September 13th Sunday - Touge.ca Cayuga TMP track event 5-9pm! #18 of 20+ Events Mugen TSX Eastern Canada 0 09-02-2015 12:05 AM
Tags
06, acura, anti, breaks, car, cl, gears, park, press, radio, shift, slot, theft, tl, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Acurazine.com content, comments, or advertising. Acurazine.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Acurazine.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
