Too Much Coolant, How to Extract?
Okay, this is gonna sound stupid but I let my buddy help me pour in some Honda Type 2 Antifreeze/Coolant and he filled it to almost the top of the resovoir tank! I checked the manual to make sure if that's correct and it shows that the max line is located just above the middle of the resovoir tank. (hard to tell where min and max is due to the compacted space).
Anyways, the real question is: how do I go about removing some of the coolant? I heard you could drain the coolant from the radiator by loosening the drain bolt or by simply using a turkey baster to suck some of the coolant out. Which is more effective?
probably the turkey baster straight from the reservoir.
The reservoir also slides off. You can do it that way and just pour out the extra. Might be a little messier though since it's at the top.
Just remove the res and pour some out. That is the easiest way.
cycdaniel
12-17-2019 10:58 AM
Username 0
2G TSX Performance Parts & Modifications
23
09-28-2015 09:09 AM
09-14-2015 10:48 AM
