PO131 PO171 codes help!
Old 03-22-2013, 10:37 AM
BxTrini_TL's Avatar
Hey im getting codes PO131 PO171 also random misfire codes..when its warm out I get no cel and car runs fine no misfire.. It says bank1 sensor butI wanna be sure.. my tl is California emissions I saw denso sensors on eBay for a good price.. would they work? Or do I have to go to dealer cuz its California emissions? Anyone can help? Thanks I appreciate it..
Old 03-22-2013, 05:42 PM
3.2TLc's Avatar
P0131>Primary O2 sensor reading low voltage could be a fuel supply problem. Check the fuel pressure. If ok, then check the sensor.
P0171>Fuel system too lean may be the fuel pump, filter, pressure regulator or EVAP purge control valve. If ok, then check misfire or sensor.
Old 03-25-2013, 12:58 AM
BxTrini_TL's Avatar
Thanks Bro i will surely check those out..
Jamus22
06-11-2023 10:08 AM
MilanoRedDashR
10-02-2015 10:49 AM
thegipper
09-28-2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
09-28-2015 12:33 PM
mars
09-28-2015 11:03 AM
Quick Reply: PO131 PO171 codes help!
