Sh!t noob tranny question
Old 03-24-2013, 10:20 AM
hondakid23's Avatar
I was just driving perfectly fine and I just accelerated a little and felt a quick jerk , I stopped at a red light and made a U turn to pull into a parking lot and the CEL light went on the D5 is flashing is my tranny gone!?
Old 03-24-2013, 10:41 AM
hondakid23's Avatar
I'm pulling 2 codes
P0715
Turbine shaft speed sensor
P1739
Old 03-24-2013, 04:25 PM
hondakid23's Avatar
Does anyone know how to fix this?
Old 03-24-2013, 05:40 PM
thewrangler99's Avatar
http://engine-codes.com/qa/7248/p173...part-%23-is-it
Order 3rd clutch pressure switch from ebay. I had that code p1739 pop up with p0401. I cleaned my egr port and cel never came back. I am still not sure about p1739 code as I never had shifting problem and I never went back to Autozone to have them check for codes. Also, check the sensor wiring is intact.
Old 03-24-2013, 07:38 PM
3.2TLc's Avatar
D-5 flashing is a warning related to the tranny.
The P1739 code indicates a problem in the 3rd Clutch Pressure Switch Circuit.
Other than the quick jerk and codes.....any other problems ?
Check the tranny fluid's condition and level. Other than that, you could check the solenoid's connection or replace it as Wrangler suggested.
Old 03-24-2013, 07:54 PM
hondakid23's Avatar
How do you find the part on eBay I tried to type in 2003 Acura tl 3rd clutch pressure switch and nothing pops up
Old 03-24-2013, 08:21 PM
3.2TLc's Avatar
Maybe just try a general "Google" search or check out an OEM Acura parts store for an actual part # for the switch.
Old 03-24-2013, 08:57 PM
I am going to Autozone to see if I still have that P1739 code. Otherwise I am ordering the part and here's the link http://www.ebay.com/itm/ACURA-MDX-CL-TL-OIL-PRESSURE-SWITCH-OEM-28600-P7Z-003-/170717702224?pt=Motors_Car_Truck_Parts_Accessories&hash=item27bf916850&vxp=mtr
Old 03-24-2013, 09:05 PM
hondakid23's Avatar
Is the oil pressure and 3rd gear pressure switch the same?
Old 03-24-2013, 09:06 PM
hondakid23's Avatar
Also how do i go about replacing the Turbine shaft speed sensor
Old 03-24-2013, 11:45 PM
I am pretty sure about the pressure switch. I did intensive research on that lol.
hondakid23 (03-25-2013)
Old 03-25-2013, 08:37 AM
hondakid23's Avatar
so does anyone know about the Turbine shaft speed sensor? Can I drive my car until these parts come in? Will it mess anything up?
TypeS860
09-03-2021 06:42 PM
Pham Alvan
03-16-2016 09:17 AM
navtool.com
3G MDX (2014-2020)
32
01-20-2016 11:43 AM
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
Quick Reply: Sh!t noob tranny question
