humming noise at high speed - AcuraZine Community
Go Back   AcuraZine Community > AcuraZine TL/TLX Community > Second Generation TL (1999-2003) > Problems & Fixes
Log In
LinkBack Thread Tools Search this Thread
Old 01-15-2011, 09:28 AM   #1
Registered Member
Trader Rating: (0)
i got this humming noise at speeds over 35/40 mph.i can tell its strictly comming from the wheels not sure which one.its not operational cause she drives and performs great,its jus that the nois is annoying and i have the slightest clue
type sexy is offline   Reply With Quote
Old 01-15-2011, 09:53 AM   #2
Registered Member
totaledTL's Avatar
Trader Rating: (0)
Could be a wheel bearing- if front bearing- does the sound change when you slightly turn the wheel?
Might also be a tire. Belts sometimes can separate & the tire makes a noise. sHad any tires replaced?
totaledTL is offline   Reply With Quote
Old 01-15-2011, 12:18 PM   #3
Registered Member
Trader Rating: (0)
or rotated the tires and noise appeared?
Have the tire shop ck the all the wheel bearings for you
RR likes to fail for some reason and noises transmit in strange directions in a car
it helps to list your car year-type S if so and current miles when asking for help
how long its been doing the current problem
any work done on it recently
thank you!, it can speed diagnosis by the group- some detail triggers a memory in a ziner and says- yes!- I had that and it cost xx to replace xyz
01tl4tl is offline   Reply With Quote
Old 01-15-2011, 12:20 PM   #4
Registered Member
Trader Rating: (0)
might be a cv/axle bearing too- the inner ones will act like that
outer bearing failure you usually hear click click click with wheels turned hard, at very low speed- as you start rolling
ck the cv rubber boots for grease trails = broken boot let grease out and grit in
Old 01-15-2011, 02:35 PM   #5
Registered Member
Trader Rating: (0)
just got brand new tires,had the prob for about 6mos now,but its louder when im making hard or fast right turns or curves...03 tl-type s 116xxx 2nd tranny no mods still beautiful...thanks
Old 01-15-2011, 09:44 PM   #6
Registered Member
Trader Rating: (0)
get to the shop that does front end work-
that sounds like a major bearing prob you dont want failing at speed
Old 01-16-2011, 07:13 AM   #7
Original Owner / Oct 1998
Carbuff's Avatar
Trader Rating: (0)
Our TL needed a LF wheel bearing at ~ 130K miles. Same symptoms as yours.
__________________
Atwell "Buff" Haines
'99 Acura TL (RIP, deer strike 11/2012)
'07 Fit Sport, 5 speed MT!
'06 AWD CR-V, 5 speed MT!
NJ
Carbuff is offline   Reply With Quote
Old 02-14-2011, 12:00 AM   #8
Registered Member
slvrcrunch's Avatar
Trader Rating: (0)
bad alignment? tire noise is most noticeable around those speeds. if your previous tires didnt have much tread on them then you wouldnt get any noise. check for cupping, stepping in tread. or wheel bearings.
__________________
waNttoB6SpD
slvrcrunch is offline   Reply With Quote
Old 02-14-2011, 12:03 AM   #9
Registered Member
kidduce's Avatar
Trader Rating: (1)
Most likely wheel bearings. I had the same issue.
kidduce is offline   Reply With Quote
Old 02-14-2011, 01:04 AM   #10
Registered Member
Trader Rating: (0)
the fun is finding which one- the sound travels and a front noise may be a rear bearing
Old 02-14-2011, 07:41 PM   #11
Registered Member
kidduce's Avatar
Trader Rating: (1)
I tend to be seeing the front ones going first though.
Old 02-15-2011, 11:56 PM   #12
Registered Member
Trader Rating: (0)
i had the same issue got it done for 240 front drivers side bearing
__________________
02 TLS 5-AT 115000 Miles, Stage-4 Exhaust Mod, Short Ram Intake w/custom ram air kit, Drilled & Slotted Front & Rear Brakes w/ceramic pads & painted calipers,pioneer radio w/(2) 12 inch power acoustic subs & 1000watt kenwood amp w/ a Rockford Fosgate capacitor, 25K HID Fogs, Front turn signals are switchbacks led, front parking lamps led, backup lights led, blue interior & trunk led.
alhalljr1980 is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
New TL owner, kind of frustrated Frathora Fourth Generation TL (2009-2014) 23 09-29-2015 12:29 AM
Share your best MPG and how you achieved it. peti1212 Acura ILX Discussion 14 09-24-2015 01:22 PM
Rock chips from driving on the highway? Sixers12 Acura ILX Discussion 4 09-06-2015 08:54 PM
Peugeot: Fractal Concept News Yumcha Automotive News 3 09-06-2015 05:40 PM
September 13th Sunday - Touge.ca Cayuga TMP track event 5-9pm! #18 of 20+ Events Mugen TSX Eastern Canada 0 09-02-2015 12:05 AM
Tags
car, fast, high, higher, humming, making, noise, noisy, sound, speed, speeds, tire, tires, varies, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Acurazine.com content, comments, or advertising. Acurazine.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Acurazine.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
