Headlight ballast question, on part numbers
Old 09-15-2015, 04:53 PM
gehrlichman's Avatar
Can anyone tell me for sure if similar looking ballasts work interchangably? I find several with a close, but different part number than mine. Mine is X6T02991, Im finding X6T02981, looks identical.
Old 09-20-2015, 09:17 PM
01acls's Avatar
I would say yes. A ballast is a ballast and a igniter is just a igniter. In the same way one can interchange a HID bulb.
Old 09-20-2015, 09:58 PM
01acls's Avatar
When mixing ballasts, the only thing you need to know is their wattage rating. I believe there's only two types currently available a 35 watt and 50 watt rated ballast. Just get the correct wattage if you want them to match.
Old 09-22-2015, 10:07 AM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
35 watt ballast is stock rating, stock bulbs were 4300K color, harder to find that rating
so most use 5,000K and love them.
I would not buy a used or new OE ballast with their seal issues!
An aftermarket `kit` with 2 new everything including bulbs!! are only 60 to 150 dollars!!
depending on maker, see the many low beam threads for info
Not all bulbs work with all ballast- whatever issues they have- are real!
Old 09-22-2015, 10:08 AM
Received 8,582 Likes on 6,629 Posts
Agreed with above.. don't get OEM ballasts.. You're MUCH better off getting a quality aftermarket one.
The ones I use are from The Retrofit Source Inc.
tman570
06-11-2019 07:56 AM
jfman55
09-05-2015 02:55 PM
darksky
09-05-2015 03:11 AM
Quick Reply: Headlight ballast question, on part numbers
