Elusive Power Outlet 12v 10amp Fuse
Old 12-17-2014, 03:51 PM
7th Gear
Roadking66's Avatar
I cannot for the life of me find the fuse for the 12v power outlet Located in the center console. Anybody? Thx
Old 12-17-2014, 04:01 PM
3.2TLc's Avatar
Welcome Roadking66 !!!
Try checking the interior passenger side fuse box for #9 (20A). There's also a relay for it.
May also want to check #8 (7.5A) in the driver's side box.
01tl4tl (12-17-2014)
Old 12-17-2014, 04:05 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
^ What he said.
Oh, and the Radio, and front accessory socket are connected to that fuse as well.
Old 12-18-2014, 08:36 AM
7th Gear
Roadking66's Avatar
Thanks guys..I will look for the relay if these fuses are not the culprit. Going out to check now. Stay tuned, please.
Old 12-18-2014, 10:58 AM
7th Gear
Roadking66's Avatar
Ok, here's the back story: Days ago noticed the power converter I usually plug into the under-armrest 12v power outlet stopped working. Thought it was trashed. Later, the radio did not power up one day. Checked the #9 fuse on passenger side. Blown. Replaced...entered radio code...everything good...I thought. Plugged in the radar detector in the forward center console accessory outlet...no power. Discovered later the metal button from that old power converter plug was missing. Discovered it inside the under-armrest accessory outlet (could this have shorted everything in the beginning?). So, where the heck is that relay 3.2TLc? Thanks.
Old 12-18-2014, 01:37 PM
3.2TLc's Avatar
Should be in the passenger side's interior fusebox.
Old 12-18-2014, 02:27 PM
TLer trash's Avatar
^^It is, but it's on the inside (glove box side) of the panel. I'd bet money that your converter piece caused the short. It's pretty common with coins, especially in the front one. You probably won't have to mess with the relay.
3.2TLc (12-19-2014)
Old 12-19-2014, 08:50 AM
fsttyms1's Avatar
Ok, so your radio works, and your front accessory plugin outlet works? IF so, its not a fuse or relay. All those items are on the same circuit. If its only the acc outlet in the center console that doesnt you need to take the console out and check the wiring.
Acura604
20
08-05-2017 12:55 AM
knight rider
03-04-2016 08:59 AM
ripit
09-26-2015 06:19 PM
Quick Reply: Elusive Power Outlet 12v 10amp Fuse
