Click!
Old 09-08-2015, 03:04 PM
4th Gear
Aging-Hacker's Avatar
Click!
I have fixed umpty-ump issues in my 2003 TL, just have one left.
If I accelerate briskly I hear a "click" from the passenger's front wheel area.
I thought the upper control arms were a bit loose, so I replaced those, no improvement.
All the other rubber parts look real solid. I did replace the passenger-side engine mount, it was failing, and that tightened up the throttle response, but the click is still there.
Any idea what could be clicking?
Old 09-26-2015, 01:18 PM
Eurotrash
Tosh's Avatar
Not quite the same symptoms as you describe, but my front brake pads regularly rattle when going over bumps.
Old 10-01-2015, 09:50 AM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
odd to have a side motor mount fail on its own, normal is front goes-- then after some months of driving that way- the side mount fails
Clicking can be in the CV joint bearings
Have you listened with a mechanics stethoscope yet? Easy way to find noises!
Steph-TLS (01-04-2016)
Old 10-05-2015, 11:44 AM
Chojun's Avatar
CV Joint failure is typically described as a 'click'.
Biggie_B
02-26-2017 11:14 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
Skirmich
10-01-2015 12:59 PM
thegipper
09-28-2015 01:01 PM
Quick Reply: Click!
