'99 TL - Check Engine Light code:1709 - AcuraZine Community
Go Back   AcuraZine Community > AcuraZine TL/TLX Community > Second Generation TL (1999-2003) > Problems & Fixes
Log In
LinkBack Thread Tools Search this Thread
Old 12-29-2005, 02:12 PM   #1
Registered Member
Trader Rating: (0)
Hi all & thx to this site... My question is CEL code 1709, does anyone know what exactly it means? I believe its either tranny related or A/T assembly. But the dealer replaced my tranny few months ago and then I started getting the CEL. Unfortunately they couldnt diagnose correctly at first . But now they its assembely and its not covered in the work they did to the tranny. In any case I got it diagnose outside and they gave me the code 1709... If anyone knows, I'd really appreciate it
ez99TL is offline   Reply With Quote
Old 12-29-2005, 03:10 PM   #2
B93P TL Owner
mdavisii's Avatar
Trader Rating: (0)
OBD-II Diagnostic Code P1709:
Park Or Neutral Position Switch Out Of Self Test Range
Don't exactly know what this means, but that is what the code reads.
mdavisii is offline   Reply With Quote
Old 12-29-2005, 08:15 PM   #3
Registered Member
Trader Rating: (0)
p1709 is a "Problem in the Gear Selection Switch Circuit".
The trans. gear selection switch is located on the shift lever assembly itself. The mode switch turns on when the shift lever shifts to the sequential sportshift mode. If the shift lever is pushed forward, the UP switch turns on. If the shift lever is pulled backward, the DOWN switch turns on. The transmission then sends signals to the PCM.
Mode switch or up/down switch STUCK ON Failure-
If the mode switch stays on while the shift lever is in OTHER than d4 position or in the sequental mode, ON FAILURE is determined.
Mode switch OFF failure-
If the mode switch stays off while the shift lever is in the sequential mode and up/down switch is actuated several times, OFF failure is determined.
Remove the Battery and battery tray. Remove the air duct tube.
Unplug all the connectors on the transmission and plug them back in. Check to see if any are unplugged. Especially the range switch.
Then clear the code.
If that doesnt work, you need a gear selector switch which has nothing to do with the tranny installation.
good luck
loud_whispers is offline   Reply With Quote
Old 12-29-2005, 09:30 PM   #4
Skeet Skeet Skeet
Trader Rating: (0)
yea definately unplug and plug the connections on the trany, i had a code for p1773 and thats because one of the connectors was loose....good luck
honda_inspire99 is offline   Reply With Quote
Old 12-30-2005, 10:56 AM   #5
Registered Member
Trader Rating: (0)
Makes you think twice before going to the dealership don't it? I know I've been there.
melissasain is offline   Reply With Quote
Old 12-30-2005, 05:23 PM   #6
Registered Member
Trader Rating: (0)
Quote:
Try going somewhere else for a free transmission.
Old 12-31-2005, 10:40 AM   #7
Registered Member
Trader Rating: (0)
I don't know ANY dealerships around here that would give me a free one, and I have had problems out of mine. I also had a friend and they replaced hers in GA and guess what ...... she has more problems now than she did before. So does free sound better?
Old 12-31-2005, 01:10 PM   #8
fsttyms1's Avatar
Trader Rating: (0)
fsttyms1
Well if your within the 100k they are free, and free are alot better than paying 4k + for a new one. And if she has problems tell her to bring the car back to the dealer!
fsttyms1 is offline   Reply With Quote
Old 12-31-2005, 04:33 PM   #9
05 C230K & 09 135i 6MT
03CoupeV6's Avatar
Trader Rating: (0)
If she had it replaced at Nalley Acura they probably left pieces out or installed it incorrectly. They replaced my dash, my passenger airbag, and my headunit and all three were installed incorrectly. They also did damage to parts every single time.
03CoupeV6 is offline   Reply With Quote
Old 01-01-2006, 03:15 PM   #10
Registered Member
Trader Rating: (0)
Smile
I think 03coupe36 summed it up nicely, I would rather pay for it and get it done right than to keep having to cuss the Acura dealership to fix what they keep messing up. Yea, it's free; but we all know free isn't always better.
Old 01-04-2006, 02:52 PM   #11
Registered Member
Trader Rating: (0)
we know these transmissions better than anyone in the world. that's just foolish to take it somewhere else.
Similar Threads
Thread Thread Starter Forum Replies Last Post
Error codes meaning?? Car-shaker? MikeYutkin Second Generation TL (1999-2003) 2 09-10-2015 11:13 PM
Over heating blues Bahamanurse1 Second Generation TL (1999-2003) 17 09-10-2015 11:05 PM
Tranny only 2 years old, pressure switches already bad??? HeloDown Problems & Fixes 4 09-08-2015 07:51 PM
2008 Acura TL bryan zaragoza Problems & Fixes 3 09-08-2015 01:28 AM
O2 Sensor Issue Caused by Water? whitesoxsfan12 Problems & Fixes 0 09-07-2015 05:07 PM
Tags
1709, 2002, 99, acura, check, circuit, code, diagnostic, engine, gear, p1709, p1773, selection, switch, tl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Acurazine.com content, comments, or advertising. Acurazine.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Acurazine.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
