3rd clutch pressure switch replacement - AcuraZine Community
Go Back   AcuraZine Community > AcuraZine TL/TLX Community > Second Generation TL (1999-2003) > Problems & Fixes
Log In
LinkBack Thread Tools Search this Thread
Old 04-27-2010, 09:35 PM   #1
New Member
Trader Rating: (0)
Exclamation 3rd clutch pressure switch replacement
I have a 1999 3.2 TL. I have pulled a P1739 code. I see that I probably need to replace the 3rd clutch pressure switch. Can someone please post a diagram or picture showing where the 3rd clutch pressure switch is located? The Acura part # would big a huge plus.
I'm blown away that this appears to be a common problem but, I can't find the location or part number and my local Acura and Honda parts counters can't tell me which switch is the third. What gives???
Edward is offline   Reply With Quote
Old 05-01-2010, 11:11 PM   #2
Registered Member
piggylover1985's Avatar
Trader Rating: (0)
I don't have the part number on hand. but it locates in the lower back cover of the transmission. Should be black in color, if you look at the cover from the lower side, there is a small stamp of a number 3 means 3 gear next to it (oil passage) Any transmission part store sells it, sometimes it can be clean up with cleaner. It will set a code if there is some debris from the tranny get in to the switch and clog it up, doesn't take much to clogged it up.
__________________
99 TL w/nav. 220k miles, chrome 03 type S wheels. F&R slotted rotors. SS catback. 04 TL 6sp.
87 Mit Starion g54b turbo.92 Talon turbo.92 Stealth 6g72 Twin turbo
"Boost is the replacement for displacement"
piggylover1985 is offline   Reply With Quote
Old 05-09-2010, 08:20 AM   #3
New Member
Trader Rating: (0)
I jacked up the drivers side of the car and pulled the plastic covers loose around the transmission. I found the number 3 as described right behing the wheel and below the battery. I pulled the switch and cleaned it out with carb cleaner as suggested. Then I cleared the code and everything seems to be ok now. Thanks for the help.
Ed
Old 05-09-2010, 09:10 AM   #4
Registered Member
Trader Rating: (0)
Quote:
Ed
Hey no problem, we are all Acuramania right? lol j/k.
__________________
Old 09-01-2011, 09:22 PM   #5
2000 TL Black on Beige
Sperry's Avatar
Trader Rating: (1)
Never in life, I hope! What is Twitter ??? Is this, like, a sex club?
Update ???
Still lurking about?
If so, can you give us an update? Did the code stay away?
__________________
177,000 - TRADED 3/12/2013 @ Granite Run GMC. Bought by a guy from Delaware . . .
DIY: Fix banging, clattering wipers
DIY: Replace side engine mount
American Toolbox
Sperry is offline   Reply With Quote
Old 09-04-2011, 06:44 PM   #6
New Member
Trader Rating: (0)
Good point. The code came back in 2-3 months so, I had to replace the switch. At least it was easy to find the second time.
The Following User Says Thank You to Edward For This Useful Post:
Sperry (09-06-2011)
Similar Threads
Thread Thread Starter Forum Replies Last Post
The time has Come.. My car started dropped to 2nd. Skirmich Second Generation TL (1999-2003) 37 09-15-2015 07:41 PM
Reaching 82,600, what to expect/prepare for MyGuti Third Generation TL (2004-2008) 7 09-12-2015 07:52 PM
Transmission or Solenoid? DS2000TL Second Generation TL (1999-2003) 1 09-09-2015 10:26 PM
Tranny only 2 years old, pressure switches already bad??? HeloDown Problems & Fixes 4 09-08-2015 07:51 PM
Replacing rotted power steering pipes on my 2001 tl mike from annapolis Problems & Fixes 2 09-04-2015 04:34 PM
Tags
2000, 2003, 2003acura, 3rd, acura, clutch, diagram, gear, honda, location, pressure, replacement, switch, tl, trans
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Acurazine.com content, comments, or advertising. Acurazine.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Acurazine.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
